DISCLAIMER: This thread is intended to organize all discussion regarding the 3DPUP ("3D Printed Upgrade Parts") Sets for the Freewing 90mm F-22 Raptor, including other modifications such as custom paint, decals, lighting, and other DIY additions.
Accordingly, all photos in this thread that I post will show a Customized Model, and do not depict the stock model customers will receive. The point is to showcase the model's cosmetic potential.
If you've created 3DPUPs for the F-22, please feel free to post the .STL files here to share with the community!
Category Links:
Custom 3DPUPs:
Custom Paint:
Custom Canopy:
Custom Decals: Active Squadrons andTransformers
Custom Lighting:
Custom CenterBurner and ReHeatz:
Custom Weapons Bay Modification:
Upgraded Power Systems:
3DPUPs
The Freewing 90mm F-22 Raptor provides many opportunities for personalization. We have created a number of 3DPUP Sets for customers wanting to customize their F-22. All of these 3DPUP Sets are available for free download. For those of you without a 3D printer, some of these 3DPUP sets will be made available as factory printed sets.
1) Cockpit Set:
Print, paint, and glue these parts into the stock canopy. A simple installation video will be posted here when complete.
2) Pitot Set and Generator Set
Print, paint, and hot glue these pitots near the nose of the F-22, one per side. The generator is glued onto the belly of the F-22. While this is scale, it does negate the ability to lay the model down on a flat surface, so it isn't a very function-friendly print.
3) Intake Cover Set:
This set is intended as a STATIC DISPLAY ONLY. Print, paint, and stick these in the intakes while your model isn't flying. The file is relieved with the classic F22 logo. An alternative smooth version is available if you want to add the squadron insignia of your livery. See Callie-Graphics.com for options.
4) AIM-9 Launcher Set:
This set is intended as a STATIC DISPLAY ONLY. Comprised of six parts, this Set uses two magnets to attach to the side of the fuselage. An AIM-9X head is also in the works if you want to depict the F-22's recent HOBS capability.
6) Outer Main Gear Door Set
This is a work in progress, and will be a sprung door set with simple lever arm.
7) Canopy Frame Set:
This is intended as the base for an extensive DIY modification to create an opening canopy function. Completion pending.
