3d Printed Part Sets - Freewing 90mm F-22 Raptor
    Tom,
    That pic is just a dirty mock-up using the wing from my crashed F-22. I will be doing a scale placement and angle when I install these on my new one coming tomorrow.
    • D@v
      • Dec 2018
      • 5
      hello guys,
      and thanks for your answer on the external tanks ...
      can you said me what are the difference between the old and new version of F22 freewing kit ?
      thanks,
      D@v
      • Pogo
        • 452
        • Waterford, Ontario, Canada
        Tom,
        Yeah, I figured. Glad your new one is almost there!:Cool:
        Tom
          Originally posted by D@v
          hello guys,
          thanks,
          D@v
          Not really sure I understand the question. Freewing has two F-22 jets. One is an old 64mm that's been around for a long time, and this new 90mm version. You can get the new one in either a 6S or 8S setup.
          • D@v
            • Dec 2018
            • 5
            ok Pat,
            I understood that the F22 90mm had existed in another version, but no, it's a new model simply.
            thanks
            D@v
              You may be thinking of the LX Models F-22. It was a twin 70mm, but about the same size as the new Freewing 90mm.
              • C17loadmaster
                Retired USAF Aircrew
                • May 2018
                • 371
                • Auburn, CA
                They look great! However 50 bucks for the 90 mm Viper weapons set! Are there .stl files for these??? :-)
                I’ll sell you the F-16 tanks if you want. I have an unused set... of you want
                • e4dragongunner
                  Living the dream!
                  • 876
                  • Arlington Heights Il.
                  Yes please !
                    Here is the file for the nose strut dual LED housing. I used 1 W LED's and just wired them in parallel.
                    • Radar-Guy
                      AirBorn Jetworkx
                      • 364
                      Thanks Steve!
                      • e4dragongunner
                        Living the dream!
                        • 876
                        Steve, you are clearly " designing" :-) ... what software are you using?
                          Fusion 360. So much to learn. I can do some basic relatively simple objects. Perhaps one day if I work really hard at it I could be about as good as Dirty Dee, rcfiddy1 or Radar-Guy! :)
                          • e4dragongunner
                            Living the dream!
                            • 876
                            Thanks brother! :-) Always looking to add to the skills tool box!
                              Per Todd's post on the regular F-22 thread.
                              Main gear outer door 3DPup files are now available at this link.
                                Gear doors are currently printing, 6 hour job. Will post pics of how they turn out.
                                  This should give you guys an idea of what they look like and how they operate.
                                  • WAY BAD
                                    • 69
                                    • Bossier City, LA USA
                                    Could I pay one of you guys to print me the wheel inserts, the dual light pod for the nose gear, and the new gear doors?
                                    • Visva11
                                      • Nov 2018
                                      • 44
                                      Am I the only one that think, the horn is on the upper side of the door? Is it meant to be there or a mistake? If correct, so is it supposed to be for some sort of sprung mechanism door?
                                      and if it's supposed to be going to the down side, isn't it too close to close the door? And see the curve in the underside of the door.
                                      someone please clarify this. Thanks in advance
                                        I was kinda thinking the same thing myself. Just under an hour left on the print, then I'll mock it up and see how to install.
                                        It could be that the servo has to mount under the wind to the outside of the pocket, so the control arm and pushrods are exposed. We'll see.
                                          Hinge plate mounts in wing and door mounts with arm exposed. Servo mounts in wing and an external pushrod goes from the servo arm to the arm on the gear door.
