  • mick8488
    • Mar 2020
    • 23
    Originally posted by seaviper
    Just be careful with the voltage drop.
    I kicked off this BEC discussion on this thread, but I probably didn't explain myself very well. Currently in my Freewing F-4, I have an ESC with BEC plugged into the receiver. This BEC is set to 6 volts I believe. Then I have a second backup BEC plugged into another receiver port set to 5 volts. This backup BEC is powered by a small 220mah 2s LiPo. I have tested it and it works a treat when the main flight battery is disconnected. It also gives me reassurance in the air should my main flight battery completely fail or the ESC cooks off together with the main BEC. This is what I want to do with the MiG-29.
    • mshagg
      • 541
      • South Australia
      Originally posted by Necroscope
      Well our club in the UK (LDF) has four of these hopefully coming its way, off the pre-order.
      I am thinking of using a Spektrum AR637T RX with a SPM9745 Sat. I will use a low key AS3X program from my F22 (that works really well).
      Coupled with 2-off Turnigy 6S 5K HD packs.
      Does anyone see any problems with this setup?
      Sounds like a great setup. Notwithstanding the twin motor setup it's a pretty straightforward jet. AETR, gear and flaps.
      I would drop an AR636 straight in there but I'm hooked on telemetry and opentx radios can't forward program the 637T. So, frsky it is.
      • Necroscope
        • Mar 2020
        • 38
        Is the AR636 getting discontinued in favour of the AR637T do you know? I run the 636 in all of my other birds.
        • DMich55
          • 5
          Any chance this gets delivered early?
          • James
            Administrator
            • Aug 2017
            • 1543
            Always a chance, but in the current climate, who knows. We ship pre-orders straight off the container as soon as they arrive
              • 2137
              • On planet earth....right
              Originally posted by Alpha
              As is our M.O., we wanted to give users a sensible degree of choice for their MiG-29. So, out of the box, the MiG-29 wears standard digital camo on the vertical stabs, pre-installed from the factory. The tiger decal is one large waterslide piece and the rudder piece, and is included in the box, uninstalled. If you want to stay with a standard digital camo bird, leave the model As Is, Out-of-The-Box. If you want to add a bit off flash to your tail, the tiger decal is included, ready for your quick install in a couple minutes.
              Out of the box, "0921", port and starboard:
              Click image for larger version Name:	Out Of the Box - 0921 - Port.jpg Views:	0 Size:	219.2 KB ID:	267875Click image for larger version Name:	Out of the box - 0921 - Starboard.jpg Views:	0 Size:	145.4 KB ID:	267880
              Apply the included waterslide Tiger decal, port and starboard, to depict this livery:
              Click image for larger version Name:	Tiger CAG - Port.jpg Views:	0 Size:	277.0 KB ID:	267876Click image for larger version Name:	2317404.jpg Views:	0 Size:	150.9 KB ID:	267881
              Here are the decals themselves, out of the box:
              Click image for larger version Name:	IMG_20200810_092045.jpg Views:	0 Size:	77.6 KB ID:	267878Click image for larger version Name:	IMG_20200810_092106.jpg Views:	0 Size:	64.1 KB ID:	267879
              And showing the Tiger decal's placement (self-explanatory... just apply it directly over the existing camo decal on the vertical stab)
              Click image for larger version Name:	IMG_20200810_092158.jpg Views:	0 Size:	78.3 KB ID:	267877
              I can't decide if I like the base camo or the Tiger. Probably base camo without the Tiger for me. Or not. I don't know. Anyway, y'all have options for both. There's no wrong answer!
              *Credit to Airliners.net for the reference photos used above of the full size aircraft
              Perfect, thank you!
                • 4878
                If there's sufficient interest, I can draft a 3DPUP for the seat on a future Twitch livestream
                Yes, there is sufficient interest, Sir. Best, LB
                • Gringotuerto
                  • 409
                  • San Diego
                  "Another receiver port" means they are shorted together. If you open a receiver and look at the circuit board, you can see all the power pins are tied to all the power pins, and all the ground pins tied to all the ground pins. This means you are shorting 6v to 5v. The 6v BEC will try as hard as it can to pull that power bus up to 6v, while the other BEC is trying as hard as it can to pull the same metal down to 5v. If that path through both BECs is 1 Ohm, then the result is that your 6v BEC is constantly supplying 1Amp (V = I x R) and your 5v BEC is constantly sinking 1Amp, just to maintain that 1 volt difference. If that path is less than 1 Ohm, the situation gets worse quickly. If you put an amp meter you will see high current draw when there is no activity. This causes heating, transistor aging, loss of capacity to supply the system, and faster battery drain.
                  Do whatever you want, but two BEC's constantly fighting each other seems very undesirable to me. As another user mentioned, you can put a diode on the 5V line to prevent this back-current (although you have to know what you are doing with the diode selection, otherwise you can introduce other problems). Anyway, I've been an electrical engineer for 40 years, and I generally leave these RTF power systems alone, because I figure mucking around without knowing all the detailed design of the specific regulators used in the system could end up making it worse instead of better. I don't mean to be a downer here, but just thought folks should know that shorting two power supplies together has some issues, FYI.
                  OK back to on-topic - I have never flown a plane with anhedral on the wing. Does this make is somewhat less stable? Is this a good case for a gyro? (and I don't mean to kick off the old gyro-vs-no-gyro religious war in general, I just mean specifically as relates to a plane with anhedral).
                  • Quickstop
                    • 275
                    at least with full size aircraft, although model has a much thicker wing
                    https://howthingsfly.si.edu/ask-an-e...mance-aircraft
                    • Beeg
                      • 1335
                      • Texas
                      The only anhedral RC model I've flown is the larger FW F-104. It has a tendency to dutch roll which may be exacerbated by the anhedral. I've flown this model with and without it's gyro to dampen this in this particular model and it's definitely desirable to have it on.
                      • Gringotuerto
                        • 409
                        • San Diego
                        Thanks, I didn't know that term. Wikipedia has a good article on "Dutch Roll", and links to several other terms (phugoid, etc.). This will be my first plane shaped like a modern fighter jet. So far have only flown the A-10, the Me-262, and many sort-of-Avanti-shaped sport jets.
                        • Flanker271
                          Spool up that fan!
                          • 81
                          • Gilbert, AZ
                          Not sure if anyone plays DCS, it's one of the most realistic combat sim available today. Here is a 1-on-1 MiG-29 vs F-18 fight. It's amazing how much off-boresight targeting a modern missile is capable of.
                          • Reaper911
                            • 90
                            • Winterpeg, Canada
                            Hi Alpha, this is great news to have the option but I note during the unboxing by James the fins were blank on the outboard sides? Is that because this was a pre-production unit?
                            • Big12fan
                              mrt1035
                              • 33
                              • KS
                              Alpha, what are your thoughts on this with the high performance 80’s with 12 blades installed? Have you tested it with this set up? I’m thinking I have really loved the way it’s changed some old dogs into new dogs (f-86 etc). Think that’s the way I’m going or want to go anyway.
                                Big12fan The PNP MiG-29 utilizes the 9B Inrunner setup used on recent pre-upgraded PNPs such as the T-33. It hits the ideal balance we're looking for, which is why it's being gradually standardized into all 80mm jets over time.
                                I prefer this inrunner 9B system over the inrunner 12B system incrementally for top speed, but in practice, either system will power the MiG-29 very well for speed and acceleration. It is difficult to convey just how easy it is to fly in normal attitudes; the difference in blade count becomes evident only during abnormal attitudes, such as powering out of a flat spin.
                                  Yes, as noted, his was a pre-ship production version. It is identical to the shipped production version in all others areas except the fin decal situation.
                                  • Reaper911
                                    • 90
                                    • Winterpeg, Canada
                                    Excellent, Thx Alpha
                                    • Swarick
                                      • 36
                                      Originally posted by Skosh25
                                      Which one do you use? The Admiral?
                                      https://www.motionrc.com/products/ad...aba-connectors
                                      No. I use the two cell LiFe packs from Spektrum. No stepdown transformer required.
                                      • Corsair nut
                                        Jets...warbirds...mmm hmmm
                                        • 218
                                        • Tehachapi ca
                                        Might stay with the digital now that i know the kitty cat isnt on the tail :p
                                        • Corsair nut
                                          • 218
                                          • Tehachapi ca
                                          Alfa...yeah the 9bl inrunner setup is awesome!! Heck...even the 9bl outrunner from the a10 is impressive. It flew my freewing f18 pretty dang good!
