I have been coming back to the Mig-29 since the pre-order came out ordered yesterday hope I am not too late for the first batch.
Here is another picture with more size info for decals. I put a side view at the same scale and it looks to me like the vertical stab roundel should be around the same size as the smaller of the two example wing roundels. Also I indicated some other boxes in the drawing, but some are specific to this DPRK livery. The dimension on the 3 digit number on the intake is the size of a rectangle bounding all 3 digits. Sorry for the spam, I tried to replace the drawing several posts ago, but apparently "edit" does not allow different attachments.
Look on page 16 and 18Does anyone know the actual main wheel size???? I pre-ordered mine, I have been reading this post and have read everything from 65mm to 80mm. also the actual AXLE size 4mm 5mm I want to go ahead and get a set of brakes for this, but don't know what size to get. Any help will be appreciated
Now that we know the axle sizes what break/wheels are you all looking at? I am thinking of using the JP Hobby ones but they are 65mm wheel diameter. Anyone found larger wheels with breaks that don't weigh as much as a battery pack? LoL!Comment
I found JP brakes and wheels 5mm axle and 70mm wheels but not sure for purchasing them as stock wheels are about 80mm as said here and nose is 65mm. Thinking that if 70mm are good then nose should be reduced to 60mm at least? The nearest JP wheel diameter i have found is 75mm but for 6mm axle.Comment
I thought it was interesting that the 5100 batts had same flight time 5:30+ and active throttle ~4:00 as the 6000 batts. Must have reached the depreciating returns on weight to power. Since I plan on running 5000s this isn’t bad new at all.Comment
dsmithwc04 - Don't read too much into it. The 5100 carbons and 6000's weigh about the same. It comes down to the fact that you saw just 1 flight on 3 different sets of packs. No two flights are the same so impossible to extrapolate an average flight time based on just these flights. In total, the aircraft now has 17 flights on it. 3 prior to the announcement where we were very conservative, just wanted to get some flying footage and pics for the big announcement. 10 on the day with Patrick where he flew 4 flights on 4000, 2 on 6000, 2 on 5100, 2 on 5000. Then I just did my first 4 flights yesterday on the same aircraft, 2 with 5100 and 2 with 4000. I wish the only part of my job was to just be at the field all day every day, but it's not. But, either way, what you should take away from these videos is that for a large twin EDF jet, the flight time has come a long way and the days of 2-3 minute EDF flights are over.Comment
I'm sure 3 batteries would fit in the bay at one time, but you'd be adding a ton of weight to the tail to get it to balance. You'd also be hard pressed to find room for the BB and you RX.PatComment
Interestingly enough, there is a great amount of space on the sides of the back battery compartment. We have our receiver tucked in there with plenty of room and the eagle gyro is under the back battery compartment. So you could totally fit the blue box back there and your RX / gyro and have the entire top/middle compartment clear if you wished. Might just need a few extensions for the nose gear and steering.Comment
Wow, this thing has way more room than I thought!
But...three 4000's up front? CG would be impossible to achieve without adding a tone of tail weight. Although I'd love to see someone prove me wrong.
PatComment
Yeah, I am not recommending 3 batteries in any way, but modelers will do whatever modelers will do. I'd happily watch someone try it
