Originally posted by HangarQueen
View Post
100% I've had a few HSD F16s and as good as they are, they are not freewing and parts are difficult to get easily. I would be up for larger1k jets with 120mm edfsOriginally posted by flyAA View Post
I would totally be on board for a bigger EDF in the $1k range. I keep wanting to pull the trigger on the HSD F-16 but i just don’t get a warm feeling about it.
All the things that scare me about the HSD and other big models would be absent in a freewing/ motion release (parts, support, quality, reputation, etc).
Great job on the mig!
twin 90 or bigger eurofighter for me would make me part with cash pretty quickly!!
Freewing has done a great job! Already have 2 of them coming and I will be putting 2 X-45 turbines in her with two 30 ounce fuel tanks for 5 min flights! I've already converted the FW F-22, A-4, two T-bird F-16's with operational speed brakes and canopy, and the F-14. This will be another great one! Fid of the FW T-Brid Viper cutting through the air.Scale Master at the sticks! RC Jet turbine
Alpha can you please let me know the diameter and width of the main gear wheel? I found 5mm axle brakes with 55-65-70mm wheelsOriginally posted by Alpha View PostMavernick* We're not offering brakes at this time. But I posted the axle diameters up above for anyone pursuing aftermarket brake sets.
Aros Alpha To add quickly to my previous suggestion, I think it may be beneficial to also make a "Wheel/Axle Size" category in the Specs. section under, yet separate from the "Landing Gear" specs. The main wheel and nose diameter can then be specified, as well as the axle diameter. Aftermarket brake use appear to be popular and the question comes up a lot with every jet announcement, just as BEC question does.Originally posted by T-CAT View PostMotion RC,
Aros May I make a small suggestion on the website product pages?
It seems the question regarding BEC inclusion type comes up often, especially when a new Freewing jet is announced.
It may be worthwhile to include the BEC specs. in the chart that is found on the product pages. The new category can be named "BEC" which would be separate, yet underneath the "ESC" section. Then, it can be shown as necessary, such as Internal or External, number of BEC's, linear or switching, ratings, etc., and however you feel it should be listed properly.
Example: |BEC|------>|1X External Switching 8A. 5V output (2-6S LiPo input)|
Maybe that will even lessen some questions CS has to answer.
T-CAT those are good ideas...If I am provided with the accurate data I would be happy to add those fields to our specification tables!My YouTube RC videos:
According to James the main tires are 80mm (it's the nose tires that are 65mm). The main axles are 5.05mm.Originally posted by raron455 View PostDoes anyone know the actual main wheel size???? I pre-ordered mine, I have been reading this post and have read everything from 65mm to 80mm. also the actual AXLE size 4mm 5mm I want to go ahead and get a set of brakes for this, but don't know what size to get. Any help will be appreciatedPat
Configurations PNP:Main Specifications PNP: Wingspan: 1257mm
Length: 1878mm
Take-off weight: 4300g
Material: EPO Material
EDF: 9 blades 80mm EDF X2
Motor: outrunner 3658-1920KV X2
ESC:100A ESC 8A UBEC X2
2pcs 9g metal servos 9pcs 17g metal servos
Ladning gear system.
Flap
LED system
6S 4000---5200MAH Lipo battery (not included)
2.4Ghz 6 channel RC (not included)
Charger: B6 Multi-functional Balance Charger (not included)
Electric Retractable Landing Gear Installed==================================
PNP: includes Everything Except RC, Battery, Charger
Configuration KIT+S:
Not inlcuded any electronic device, only airplane frame and landing gear and with servos.
More photos as Below:
See post #405 for all these dimensions.Originally posted by raron455 View PostDoes anyone know the actual main wheel size???? I pre-ordered mine, I have been reading this post and have read everything from 65mm to 80mm. also the actual AXLE size 4mm 5mm I want to go ahead and get a set of brakes for this, but don't know what size to get. Any help will be appreciated
I wanted to order some decals from Callie, and wondered what size. So I copied the previously-posted dimension picture in Visio, captured the scale of the drawing, then put two roundels on the wing to see what diameter looks appropriate. The bigger one on the left is 93.8mm diameter (~3 and 11/16 inches), and the smaller one on the right is 83.2mm diameter (~3 and 9/32 inches).
Will make two of us then :DOriginally posted by Scale Master View PostFreewing has done a great job! Already have 2 of them coming and I will be putting 2 X-45 turbines in her with two 30 ounce fuel tanks for 5 min flights! I've already converted the FW F-22, A-4, two T-bird F-16's with operational speed brakes and canopy, and the F-14. This will be another great one! Fid of the FW T-Brid Viper cutting through the air.
I kinda have some ideas for DJI FPV and vectoring too, but first things first :)Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
