Perfect!
That was the piece I needed, thank you for taking the time!
I thought the gyro wasn't as sophisticated as it is. So the easy way to achieve what I want will be to add up elevon without sending that signal to the gyro, thereby the gyro will work to maintain 0deg/s but the elevons will give the aircraft a nose high attitude with stick centered. It will be the same as moving the CG further aft but having full control. Nonetheless it will be a very incremental process to get it to work. Looking forward to this!
and assume too much, sorry
