Those are elevons
The wings were midbody-mounted to provide clearance for underwing stores, each wing having a leading-edge flap, plus two trailing-edge drooping "elevons" to improve short-field performance and maneuverability.Comment
Ok, then what are the outboard devices that look like aileronsComment
They likely didn't because it would add weight cost and complexity, that many would deem unnecessary for the model.
And indeed the jet certainly does not need them to fly fantastically.
Personally I would have digged the jet having the split full-span elevons, but I bought regardless so...
How many people would have been turned off by the wings having 2 servos each instead of 1 and all mixing associated?
Certainly more than those who will not buy the jet because it didn't feature split elevons (if any).
I would also have prefered full span elevons with 17g servos too, if split elevons were not to be, but then again... not like I'm complaining! ;)
ROFL.
That made my day.
That is sweeeeeeeeeet! :DDDDDDDD
Notice how 'scale' it looks dragging its arse around!
There's why I love deltas!
James could tell what the landing speed is. That's important. The flaps on the Mig 21 were effective when landing.Comment
I worry that the bottom thrust vector servo and push rod will drag on the grass in high angle of attack take offs and landings. I don't have a nice paved runway, but this is advertised as a grass capable jet. Alpha, has the TV unit been tried on grass?
Thanks, RT.Comment
I really miss my Eurofighter(nothing crashes like EPS). The TV tail was the deal maker on my gripen pre-order. Are you going to make enough of the TV tail? How about a pre-order for them? To add to the nose gear placement discussion...my euro was as tipsy as my ex wife at all day cocktail hour. I had to keep a supply of canards on hand. Don't underestimate how careful you have to be with a tippy aircraft. And what a PITA its is.(just like my ex-wife.)Thank you alpha for the compromise.Still flying P.15, avanti(#2), mig 21, yak 130 70mm(#2), f35, f9f panther, a10 64mm, F8 crusader/ PA ultimate amr /HK skipper, durafly dh vampire, p 51,spit mk24, corsair, flybeam/ BH f86 50mm, deltawing 50mm/ HH su 26 mm,umx pitts,umx sbach, blade nano cp s,blade 450x, inductrix 200, inductrix pro, umx yak 54,umx f27 fpv/ electrifly 4s L39/ flyzone beaver/ volantix asw 28, /dynam B26
RIP.. roc hobby waco,strega #2(you will be missed), Fw 90mm eurofighter.Comment
I saw this performance with my own eyes, something incredible. This is the expected GRIPEN. Just for the sake of interest.
