I put together my Gripen stock setup to run a quick test your experience with increasing the timing on the ESC.
I did not record static thrust back to back to determine if the extra power was translating into extra thrust or speed, but there does appear to be an increase on the face of it, although your stock ESC might not be up to the task as I imagine on 25V+ at peak that you'll be over the 100A limit.
- On Medium timing at 23.08V, I recorded 1944W and 90A draw using the stock 9-bld inrunner and Hobbywing ESC.
- On High timing at 23.06V, I recorded 2099W and 97A draw
- So there's a 7% increase in watts and amps going from Medium to High timing
