  • killickb
    One of his videos does show him lighting these off. I did use his link to find those that he uses. My smallest smoke cartridges are 3.50” long x 1.20” diameter and last about 2 minutes. Have Red, Orange and White but no idea where I got them. One version has a “fuse” the other you just light the flat end face, they do get hot ! Also have some reloadable rocket motors but the best are only a few seconds of burn. I use a HK solid state switch thru a 3 cell lipo to fire off in my Me 163 —- not very efficient or spectacular though.
    Originally posted by kallend
    I've done that for the large cartridges we use in skydiving, but the ones on his Gripen are much smaller than any I've seen.
    The ones I've used were mounted on an RC plane. They were about 4" long, burned for about a minute. Purchased from hobby shop.
  • kallend
    It doesn't show them being "lit". I've used the kind that you pull a wire at the end of the cartridge and that triggers the ignition.
  • killickb
    Looks like he uses cigarette lighter ?
  • kallend
    Have some more Gripen joy!
    This jet makes it so convenient to attach smoke cartridges on the wingtip rails...
    Use some isolation though if you do, or you will melt them.
    I asked previously but didn't see an answer. How are the smoke cartridges ignited?
  • HaroldAnderson
    Nice flights. The smoke looks especially good down low when you have a background. It looks like you don't get many sunny days in your region that are great for smoke. It would be cool to see it backlit with smoke on.
  • Airguardian
  • janmb
    Originally posted by Pogo
    Well it took longer than I'd thought (go figure) but the leading edge flaps are done. Thin plastic from a Xmas wrap box was used to cover the bottom wing gaps- these slide back over the wing as the flap comes down. I have them on a 3 position switch and deployment is slowed to 2 seconds- flight modes are also being used, allowing for separate trims in each position (Hugh W. will approve :).
    Weight gain is about 20 grams per wing- haven't re-checked the CG yet but may be able to remove most of the lead added for the maiden flights.
    I'm really looking forward to trying the flaps out in flight, but that will probably have to wait 'till spring. Now on to the wing pylons...
    Merry Christmas all!
    Tom
    Looks great, looking forward to hear the results!
  • Pogo
    Tom
  • Airguardian
    Thank you for the feedback! :)
  • Dan McKeag
    Thank you for the great videos---impressive!
  • Airguardian
    Smoke for the Smoke God!
  • HockeyMac!
    Lmao!!!
  • RCJetFanatic89
    Couldn't miss the chance!
    I would’ve done the same!!
  • Airguardian
  • RCJetFanatic89
    Have a hell!
    LOL! Didn’t even realize there was a typo. That’s too funny
  • Airguardian
    Originally posted by RCJetFanatic89
    Any hell is greatly appreciated!
    Have a hell!
  • kallend
    Originally posted by Apriliamgt
    So what's the best recommend rates ??
    Define "best".
  • janmb
    Originally posted by JLambCWU
    ANY aircraft will be lacking in control when the AoA gets too high. (hence the wing drop) A single TV nozel won’t change this.
    Yes and no.
    Roll and pitch authority stays fine into really, really high alpha, both with vectoring and without. All that requires is good CG, which you probably have never tried.
    Yaw authority on the other hand goes down the drain without vectoring, and remains solid with. So for yaw, which this really boils down to, vectoring is day and night difference.
