  • rms
  • rms
    Originally posted by HockeyMac!
    Wow! What's your flight time you're getting with those?? Looks pretty good to me.
    Timer is on 3,5 min. 3min until 5 min depend how the throttle is used ;-) I have telemetri so I fly it down to 3,70v each cell so it creeps up to 3,75v with out load ..
  • Mizer67
    For out-of-the-box performance, the Mirage is hard to beat.
    The Gripen has its charms too, but they're very different.
  • janmb
    Originally posted by Captain Moron
    Is it worth buying the Gripen. I have the high performance Mirage with the 80mm inrunner motor.and by all accounts the Mirage I am told fly better then the Gripen. Would I be wasting my money buying the Gripen {if they ever come back in stock in Europe).
    The Mirage has far better thrust to weight ratio - that much is a clear fact.
    On the other hand, the Gripen is a fair bit larger, and has both canards and vectoring to play around with.
    Especially if you like to fly high alpha, the Gripen will have a distinct advantage with vectoring for yaw control.
  • HockeyMac!
  • rms
    I`m using this SLS 6s 3500 witch was the lighest I could find for a normal price. Also that they come out good in test. I have been very satisfied. The 6s 3500 30c id 505gram and the 2s 3500 is 198gram....something I consider to get 8s. And make space in the wing/ fuselage to keep the CG aft.
    https://www.stefansliposhop.de/en/ba...60c::1675.html
    I fly with this 6s witch is a light setup, aft CG, no lead in the tail gives very good handling on the Gripen. Flying weight 2860gram
    A film of my Gripen.
    Not really. I was with earlier ones but later ones just aren’t holding up as well. I’m using power hobby ones right now in 6s and am looking for better 2s. The Admirals are too heavy. I don’t think they’ll fit either.
  • Skosh25
    JF/ HET 1738kV Plush 120HV ESC 6+2 5200 lipo.
    Thanks Evan. I see you have the HS lipos. Happy with them? I used 6+2 Admiral 5000's in the Raptor.
  • Skosh25
    Get a Gripen and get the TVs... And make it 8S.
    What's your 8S setup? I'm flying it in Colorado and 6S isn't cutting it. I thought it was slightly underpowered at sea level but up here in the thin air, no way is 6S enough. I have the stock 8S system in the Raptor but that's my only experience with anything higher than 6S.
    Hey which is better, the L-39 or the T-33...
    They are two different aircraft and fly different. If you want to compare the non TV Gripen stock PNP to the stock HP Mirage and have limited funds it would be $429 to $325 and imo the Mirage would be the no brainer, especially if you want a fast little sports car of a jet. But if you wanted something newer, something more all around, something you can put bigger batteries in , something you can add TVs to... Well then the Gripen would be my choice. Really my only gripe is with the power. 6S is just not the level of power THAT I WANT... Add TVs and it robs some of that power... There it is... Underpowered especially with the TVs, I said it... But that's my opinion...
    At the end of the day they are two different planes with different skill sets and I'd have to say buy both and see which you fly more.
    You already have the Mirage... When I bought my Gripen I had two Mirages, I love them... I crashed once since so I only have one now, a HP one... I never fly it anymore, that's unfair... I don't fly it much though...
  • Captain Moron
    One the one hand, 65g isn't a huge amount of weight. It just looks like a lot and it's awkward. I suppose when it's flying, they aren't that noticeable.
    That is very surprising. I would have never guessed you'd need that. Maybe when John makes a 3D printed exhaust it'll let you remove the lead.
    Not liking the foam nozzle I put the plastic from my old one on the TV nozzle today...
    . Click image for larger version
ID:	293168Click image for larger version
ID:	293169Click image for larger version
    I never weighed it and now their stuck onto the plane. I used thin lead sheets that we used to use for radioisotope shielding when I worked in medical research. The sheets are about 2mm thick and I cut out what I estimate to be a strip about 3/4" wide and 12" long, cut into 3 pieces, 2 of which was doubled over. Weighing a similar strip of lead, it was 65g.
    You can see the 2 double thickness strips on the bottom. There is one more single layer strip on top.
    How much weight did you add?
    My Gens are 45C, 725g, 45mm X 45mm X 155mm. It's shoved right back to where the foam angles inward. I didn't weigh the weight, just kept adding till it balanced at the marks. It already looked like a lot so I didn't add any more to get the balance aft of the marks. Will fly it first (carefully) and see if I like it that way. It just seems like a terrible thing to have to add so much weight.
    I may change my mind about the Assan. I have other planes that are quite darty on the ground that can use one. (I did buy the 5 pack.)
    Thanks.
    The picture was taken before the TVs. I would say it's average weight. The JF is about the same as the stock fan and shroud. The HET may be a little more than the stock inrunner but not much. I have a Turnigy 120HV ESC about the same weight as the stock 100A HW. My batteries and series adapter are 880g. Paint added a little, maybe more paint aft of the balance point??? I think I added 75-80g of lead in the stock rear fuselage to balance it at 15-18mm behind the mark. The TV rear part is 13g heavier than the old rear with lead. My batteries are 48mm wide so maybe I am able to push them back a bit more?
    My receiver is aft under the battery tray. I shortened any extensions I could. My satellite us under the vertical fin. I do have a steering gyro up front and if I was building it again I wouldn't use it since the Gripen's forward gear position isn't as tippy as I thought it would be.. What is the weight and dimensions of your battery? I assume you have it laying in a way that's the most narrow.
    Edit... if you are using the 45C battery yours is narrower and should go back further but are 20mm longer than mine so extend further forward... But they are only 716g? But they have others with other C ratings...
    There is a balance mark molded in the foam under the wing that I use as a reference. I am 15-18mm behind the mark.
    Is your EDF a lot heavier than the 6s one? I can't get my battery as far back as yours without cutting into the foam that separates the internal compartment from the air intake plenum. I'm using the Gens Ace 5000. I don't want to cut into the foam to get the battery further back so I've added some tail weight and that only achieves balance at the marks (and that's with the VT nozzle installed). I see you've got the Assan steering gyro. How does that work for you? I also have one on mine but some say it's not required. I can't maiden till spring.
    I am using a 6S plus a 2S. They are one atop the other. I'll find a picture. I post more in RCG than here and have more information and pictures there.
    Originally posted by rms
    Are you using 6s not 4s x 2 batteries? Do you have both batteries in front?
    15-18mm behind CG recomandation?
