  • rms
    Hard questions... I don't have the answers to the total weight. I am balanced 15-18mm behind the marks under the wings.5200 6+2 @ 880g. 12S can work. I have 3500 6S 60C packs that fit. They are 890g for two.
    Are you using 6s not 4s x 2 batteries? Do you have both batteries in front?
    15-18mm behind CG recomandation?
    Originally posted by rms
    Very nice. where du you have the batteries og what is the CG? Is it flying good?
    What is the total weight of your Gripen? Weight, size of the batteries?
    I`m considder to go 8s or even 12s if I find a good solution for the CG...
  • janmb
    Originally posted by kallend
    Here is the revised version. Same Thingiverse location.
    Looks great :D
  • rms
    Between being a delta, canards, thrust vectoring and 8s power I’m not bored.
  • Nigel
    Hi hope the thrust vectoring unit turn up before spring because I have told every one in my club who would listen about this and I am starting to have people ask me through you are going to fit this kit you keep banging on about ? Foot note don’t jump to early
ID:	293091Click image for larger version
ID:	293090Click image for larger version
ID:	293089Click image for larger version  Name:	89950730-0AF0-4884-A702-5D16CEA822F1.jpeg Views:	0 Size:	195.9 KB ID:	293087
    On the plane in the picture above. Flew a bunch of flights with it and like it. I put more info about my set up and numbers on RCG.
  • SanExup
    Did you receive the TV unit!?
  • kallend
    Thanks. I finally got a good dimension for the long lateral fins. The narrow chord ones at the tail are still a bit of a guess. Updated the Thingi files.
  • janmb
    If you get bored with the Gripen ;-)
    Did som flying with a FW Mirage i bought used from JanMB here now.
    Nice scenery light :-) https://www.youtube.com/watch?v=kjmVR29xxKM
    Low, hige alpha training, but bad light with overcast..https://www.youtube.com/watch?v=L3HO8pWhFE0&t=208s
    Nice flying - glad to see you are enjoying her :D
  • janmb
    Quite likely - I couldn't find a 3-view or definitive dimensions for the vanes so I guesstimated.
    Try now! (Pretty easy to clip them off with an STL editor if you still think they're too long.)
    Thanks.
  • rms
    Just finished installing the VT nozzle and setting it up in the TX. The actual butt end swap took 15 minutes. Hooked up the ELE servo to AUX2 and mixed it. The rudder servo is just "Y'd" to the rudder channel. No reverser was necessary. As mentioned before, the color of the VT section doesn't match the color of the fuse it grafts onto. The nozzle is much lighter in color. Doesn't bother me but for some, this will be very irritating. It won't see any air time till spring, unless the dreaded climate change warms everything up and clears the runways.
  • kallend
    Originally posted by SanExup
    Having replicated things for my work, I know proportions and dimensions can be tough. Especially when working with limited resource, like not having the true dimensions. I actually reproduced the aft end of a JDAM to true scale on a wood lathe for a subcontractor doing some systems design and development for the navy. The navy liaison actually called to find out where the heck we got the JDAM tail section. Anyway, I was using photos and scaling it up with known dimensions of other objects in the photos. The object was to impress the navy so the company that hired me didn't want to ask for dimensions. I ramble, I apologize. Maybe it's more interesting than bickering but who knows.
    I wish I had a 3d printer, it is in my future for sure..To be able to produce scale objects for planes seems very fun and rewarding.
    Here are a couple of photos that maybe will help see the proportions. Different angles and lighting helps. With the IRIS it's hard to see the fins when the missile is mounted with the fins at a 45. I've been trying to find a view of it with the fins in the vertical position. But no luck, I hope this helps. Thanks kallend I know once I dive into purchasing and using a 3d printer the existing designs out there will be much appreciated, just saying thanks in advance.
  • HockeyMac!
    I'll be doing some pylons now that the tanks are on the printer. I have a great side view drawing of them, does anyone have a good front/bottom view?
    The drawing I do have does include the meteor rail we see on the pylons too so I'll be working on that as well.
  • SanExup
    Here are a couple of photos that maybe will help see the proportions. Different angles and lighting helps. With the IRIS it's hard to see the fins when the missile is mounted with the fins at a 45. I've been trying to find a view of it with the fins in the vertical position. But no luck, I hope this helps. Thanks kallend I know once I dive into purchasing and using a 3d printer the existing designs out there will be much appreciated, just saying thanks in advance. Click image for larger version
ID:	292996Click image for larger version
Name:	DSC_1056 IRIS-T missile right front seeker head l.jpg
ID:	292997Click image for larger version
Name:	DSC_1034 IRIS-T missile left front l.jpg
  • kallend
    Originally posted by janmb
    Instead of bitching and sounding ungrateful, I'll go make my own. No worries.
    The body diameter is according to what you wrote above, so that means the issue is the vanes (and possibly also fins) protruding a bit too much.
  • janmb
    According to Wikipedia the diameter of the IRIS-T body is 127mm. At 1:9 scale that makes 14.1.mm for the model, which is what I made it.
    Thingi is having problems. Try re-loading, you may have a cached version.
  • janmb
    Proper nouns that are pronounced differently in English than in the country of origin: Paris, Germany, France, Spain, Sweden, Norway, Denmark, Rome, Naples, Mexico, The Hague, China, Japan, Athens, Greece, Venice, Orleans, Ypres . . . .
    Translating proper nouns should qualify for death sentence.
    Regardless, that's not what's being discussed here. In this case, it is a matter of a noun not being translated or deliberately pronounced in any English "version". It is a matter of people just not knowing better. Which is perfectly fine in the first place, but willingness to learn should be expected.
