Official Freewing Vulcan 70mm EDF Jet Thread
  • Ron1950
    Didnt get vid of take offs but this low pass and landing is about it
    Vulcan low pass -
    YouTube
    Vulcan landing on maiden - YouTube
  • Ron1950
    Ya pavement makes a big difference in speed with these crazy planes. F86 would not takeoff today either it is short grass but super thick. Both planes have fairly small wheels and wind was calm
    3/8" behind is a little more than where I did my maiden and then I moved it another 5-7 and then another 3-5mm so I think I'm about 3/4" behind the wire channel which is where the molded mark is and I am still moving it back. As I said it was a very bumpy day yesterday so I didn't want to go too far back. I didn't fly today (gun day) but plan on a bunch of flying tomorrow. I fly off pavement so it may make a big difference. The plane has a very definite nose down stance on the ground which probably makes take offs on grass worse.
  • Ron1950
    Evan we tryed mine today also. It had dificulty getting airborn at cg. Moved the 3300 back 3/8 in tryed it again with no wind and full up elevator it got airborn. Moved battery back to about 1 in from the tray forward hole and dropped flaps to full it took off nice flying. Tryed 3 takeoffs all much better with full flaps. First takeoff attemps when it did get airborn broke hard right just off ground. Much better with full flaps.
    we tryed take offs with take off flaps. No go. Tryed with no flaps. No go. So we tryed full flaps and we got 3 good take offs. U got me. Im stumped. Maybe a longer nose gear strut would take some of the negative insidence out for grass take offs
  • Ron1950
    finally got mine today.. took about 20 min to get it ready for flight tomorrow..fit and finish were great the decal where it goes into the intake is peeling but not a problem at all
    It flies well. I up’ed all the throws and put the ailerons on the outer hole of the servo and @130%. Also had it balanced 5mm behind book. My ailerons were too touchy..
    But it flew great and really wrung it out. Bad day with lots of wind and turbulence but it’s good. Also flew the Avanti so I could compare… the Avanti flies nicer… but not much. It is quite fast and surprisingly quiet. Timer was set for 5 but I landed early during a break in the wind and still had 60% on a 5000.
    Click image for larger version  Name:	5EE63294-FA91-4F76-8E9D-C4568DF91166.jpeg Views:	0 Size:	190.7 KB ID:	323871
    These are a bit different, they are the chrome strips... They did not stay stuck checking on them this morning. I did a light dab of the glue that FW includes in most kits, I find it perfect for things like this and as a thread locker for screws into plastic, and other uses...
    Originally posted by paulrkytek
    Low level heat with hobby iron sticks back decals, try on spare foam to ensure temp is not too high to bubble foam
  • kallend
    Click image for larger version Name:	C65A7136-84E4-4261-AB15-02A814BE7D08.jpeg Views:	0 Size:	61.8 KB ID:	323813
    It's calling out for a nice nozzle on the rear end.
  • paulrkytek
    [QUOTE=Evan I am very very impressed with the Vulcan. The first thing that I saw in the online pictures is the silver canopy which I assumed was just silver paint, it’s not, it’s a plastic canopy over the foam, very nice. I’m unboxing mine I don’t see anything I don’t like. Very well done Free Wing and Motion RC.
    I wondered about that, I have sprayed clear canopies silver from the inside before using spare car wheel aerosol to get similar finish. Cheaper and lighter than pilots and leaves more space for batteries and radio gear out of view. Also less prone to accidental damage using the foam carcass. !
  • paulrkytek
    Mine is built and ready for tomorrow. Complaints are super minor. The decals that are sticky back had to be smoothed back down at the ends, super minor but I hope they stay down, may have to tape the ends. The other is the best alignment for the elevator and rudder pushrods. To get the best alignment they need to go into the servo arm from the rear and to do that I had to pull the servo covers and the servos out.
    Both these things are very nit picky, the quality is that good!
    Oh, and I put a 7ch receiver in for separate steering adjustment. There are really cool spots in the turtle deck to put the receiver if you are putting it towards the rear. I didn't use the BB and used Y's for the Ailerons, flaps and elevators and a triple for the LG. I put a satellite in the nose gear retract well. I am using a 575g 5000 pack and was surprised by the size of the battery bay and that I didn't have to shove it way back to balance. Nice engineering.
  • HIGH NOON
    Got my Vulcan yesterday and have it ready for maiden tomorrow. While the Flaps have plastic hinges already installed all other control surfaces do not. I applied hinge tape to the A, E and R. There is a bag with plastic hinges in it, optional. You will need to plug all your servo leads to the Blue Board. There is no mention of the Blue Board in the manual and how to plug in but it was not hard to figure it out.
  • Ks.jetflyer
    Ditto what Evan said. Very well packaged. Only had the end of one decal sticking out. The finish is very good. Haven't started putting mine together yet, decided to put on a coat of clear water based p/u first.
  • James
    Glad you like it thus far Evan D. I wasn't sure what to expect when alpha said this was next but I was pleasantly surprised opening the box. It looks really nice coming out and couldn't be more straightforward as far as assembly and organizing the wiring etc.
    Keep us posted on your maiden
    Great to see these in the wild! Excellent report and things to keep in mind. Looking forward to the flying reports.
  • joshc011
    Evan D I totally agree with you about HH in general.
    My most recent aircraft have been the Nexa F6F from motion, and the PA Addiction X. Both experiences have been a step up (or 2) from HH in terms of quality and support.
    If I get the Vulcan I will probably only be flying off the paved runway @ RCSMP or Floyd Bennett in Brooklyn.
ID:	323805Click image for larger version
ID:	323806Click image for larger version
ID:	323804Click image for larger version
ID:	323807 I am very very impressed with the Vulcan. The first thing that I saw in the online pictures is the silver canopy which I assumed was just silver paint, it’s not, it’s a plastic canopy over the foam, very nice. I’m unboxing mine I don’t see anything I don’t like. Very well done Free Wing and Motion RC.
    I know there was a delay over the boxes. I think the original box would have been just fine for 99% of the shipments.
  • James
    Yeah, two completely different aircraft types joshc011. You have to decide what type of flying you want to do and go with the aircraft that suits that. As far as your "rough" field, there is really no way for me to know how the Vulcan would handle it to make an informed decision. I would be merely guessing.
    I will say, without cheater holes on the bottom of the Vulcan, it will be more favorable on rougher fields than other EDFs where debris could more easily get ingested into the fan.
    I assume by saying that you have batteries for either you know they are different in what they use. As far as 5000 in the Vulcan my opinion is different than what James just said (mine is sitting in my dining room having just been delivered). Extra weight typically does not effect top speed. It will effect over all flying quality and vertical, a heavier airplane flies, well... heavy. But, and the main reason for the post is that extra weight will effect take offs and especially if flying off grass. And that's if the larger/ heavier battery will fit and balance which I assume if anyone would know James would.
    But let me add that they are two very different aircraft. I would say both would require very short grass with the Vulcan being a bit better off grass. I also want to add that I have become quite opinionated about HH, they discontinue aircraft quickly and have comparatively higher aircraft and replacement parts prices (if you can even get them). About the only aircraft they sell that I would consider is the Avanti which is an excellent trainer and worth the price.
    Originally posted by joshc011
    Thanks James, this would be my first EDF..
    Trying to decide between the Vulcan and the E-flite Ultimate 3D (biplane). Would be exact same price as I have a set of batteries for either frame. I'm ready to try an EDF, but the field I use that's closest to me is probably too rough for the Vulcan and the biplane I could fly from just about anywhere.
  • joshc011
