  • CFIT rob
    Thanks gooniac on the advice. Recieved fms 80mm 2000kv edf two days ago( they even gave me a spare fan as a gift). Flew it stock saturday so i could make a good comparison. Had to remove some foam to get access hatch to fit right(soldering iron made quick work of it). Moved battery back to keep my cg. Going to move tray back as battery tiedown now misses end of my hk turn 5000hd. Sunday.. Take off was shorter (30ish feet). Seemed faster straight and level. Flew my normal routine with it 3:45 on timer. 4 flights.Upon landing battery was barely warm. Only used 2500-2700mah out of batts.(before it would be 3600-4000 used and batts were quite warm , 120 ish degrees.
  • gooniac33
    Originally posted by CFIT rob View Post
    Thanks gooniac, thats what i was looking for. Will get one on the way. Timing is perfect because the wife just went on an amazon spree. Yes honey i do need a new fan for the mig....did you need the shoes and make up? (Click goes the land mine....)
    Sounds like an even exchange to me!! LOL Get it while you can and then she makes you feel bad for reminding her of her deeds...LOL I also wanted to note that even when flying hard the 5000packs come down barely even warm. The fan combo only pulls about 85-90amps at full throttle. And since you don't need as much throttle with this unit as stock you will be much easier on the battery.
  • CFIT rob
  • gooniac33
    Mine also flys well at 265mm. Any one flying with a less "power hungry" set up? My turnigy 5000 HD 60c batts get hotter than in my avanti or my eurofighter. Mig is heavier of course. If i can trade 12 blade sound for better efficiency i would. Wondering how the 80mm a-10 9 edf would work. Stock mig mtr is 12 blade 3530-1800kv. A-10 stk is 9 blade 3530-1900.
    I fly mine with the FMS 80mm 12 blade with 2000kv inrunner. I get about 5 mins flight time with my Turnigy Heavy duty 5000 packs. The FMS set up is quite a bit lighter than the stock unit, makes more thrust with less amps at half throttle and makes a lil more thrust at full throttle. It sounds good too! Here is a video of me flying mine if you have missed them from earlier.
  • 4923crew
    I just compleeted two more custom Mig-21’s. The green nose is my buddy Tom Mansell’s
  • lmramos44
    This jet is a *****cat in the air, thanks Alpha and Motion
  • foxbat
    Moved back the CG to 275mm. Love how it rides the glide slope in High Alpha.
  • CFIT rob
    It's actually right on 265mm as per the manual. But if you look at the picture in the manual, it's not at that spot, so it's a little misleading. But 265mm is right where you want to be for the CG.
  • foxbat
    Cheers! , what's the mm mark from the LE. for that red line ?
    Thanks
    I kept moving my CG back a little at a time until I found a comfortable spot. It ended up right in the middle of the hump (circled in black) along the side of the fuse, which is the wheel well for the retracts on the full size bird. The red line is where my CG is at currently.
  • foxbat
    Did a test flight recently , The CG was on the small horizontal slots just behind the 265mm mark indicated in the manual. Right after takeoff it dipped dangerously . Through out the flight i had to use full up trim and full flaps. The first photo is how it was configured through the full flight. . What could be the reason? , shall i move the battery back ?. I was using nantotech 4200 6 cell pack just about in the middle of the tray.
    Is it required to be flown with some uptrim on the elevator at all times?
  • joe671
    Mike one of the guys on our field converted this MIG 21 into a turbine.
  • sfninerfan69
  • gooniac33
    FMS 70mm F-18 chasing the 80mm Mig-21
    Thanks for sharing, GBLynden! I wish you'd post more often!
    I appreciate hearing the aircraft without excessively loud music.
  • GBLynden
    This is another fun flight with the MiG-21 and the F-16 doing some Formation Flying!
  • GBLynden
    This is a cool jet! I don't have one, but my buddy does and I caught some fun flights with it.
    This was a flight from this Freewing MiG-21 80mm EDF Jet Fighter at Warbirds Over Whatcom this past summer.
    Very nice for a first try... :Cool:I love camo schemes on the Mig.
  • bruceW
    MIG-21 ROMAINIAN CAMO PAINT WITH AIRBRUSH..FIRST TRY
