Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
  • kallend
    Originally posted by moti
    Hi, the servo almost don't move when it on stab. mode red and green led.....why?
    Thanks
    Moti
    Why? Because that's the way it was programmed.
    If you don't like it you can bypass it.
  • moti
    Thanks
    Moti
  • wstimax
    So did anyone figure out the problem with the twitching Hitec Servos as i just finished my build and the same thing is happening.
  • nuts-n-volts
    Nice nozzle, Kallend. I'll use it. Thanks!
    And, here's my trick... To take the stock nozzles off easily, I used acetone. I spray a small stream around the inside of the nozzle in between the plastic and foam. You can then just tug around the outside diameter and she'll loosen right up and off. The acetone won't hurt the foam. Only use a small amount to get the parts to loosen. You don't want streaks running through your paint! That is, unless you're going to re-paint anyway. The acetone could damage the nozzles, altho I used only a small amount and had none. The cool thing is that the glue stays put. I lined my ducts in foil tape for afterburners and needed to get the nozzles out of the way. I put them back on by simply "painting" the glue with acetone, which thinned it out. Stuck them on within a few seconds and presto!
  • kallend
    The stock nozzles on this F-14A are incorrect, they just look like scaled down parts from Freewing's twin 80mm F-16D. The nozzles on the A version were quite different - see image below .
    Here is a STL file to 3DP a (more or less) correct nozzle. Exit diameter is unchanged from stock.
    Here is a (more or less) correct nozzle for the twin 64mm Freewing F-14A. (Slight deviation from scale was needed to get the exit area correct for the fan size.)Print light.The file "Nozzle" is simply to replace the entire stock nozzle(foam and plastic skin). Cut off the existing nozzle and glue this in its place.IF you can peel off the plastic skin without damaging the foam underneath, use the guide to trim the foam stub to length, and mount the "noz c file" over the stub. This makes it slightly lighter and a bit easier to align. It is necessary to trim the stub to accommodate the different shape of the F-14A nozzle.The petals are very thin and some slicers may not slice them well. The "A" nozzle is a bit more robust than the noz_c
  • rlcamden
    Finally got my F-14 complete and was able to get the maiden out of the way. I needed a lot of up trim with the book recommended CG and stabilator neutral position. But no issues.
    Maiden was a non-issue. I run flight modes on my flaps, so I was able to get all the trims set and fold the wings back on the maiden for a few passes. This thing flew like it was on rails on a 10-15mph windy day, without the gyro on.
    2nd flight was seeing how the gyro affected the flight characteristics. It seemed a little sluggish on the controls, but that may have been me. Get a few fast passes with the wings in and out. I even inadvertently checked the sturdiness of the airframe and the upgrades to the landing gear.
    She covers a lot of sky in a short amount of time, so be prepared for that. All in all, I like my 80mm better, just didn't like having to do all the upgrades to get it to fly the way it should. This 64mm version is a winner due to the ease of transport, the flight envelope, and the appearance. Kudos to Freewing and MotionRC.
  • Chris_WaterGuy
    Originally posted by rlcamden
    After reading a few posts about the flap hinges, I decided to check mine out of an abundance of caution. I discovered that the right wing had very little glue on the hinges, and the left wing had a tad bit more, but all the hinges were relatively easy to pop off. This is definitely something you need to check if you own this plane. I haven't flown it yet, but I am glad I decided to check those hinges. Waiting to upgrade the swing-wing push rods.
    Pretty much as expected, the hinges on my example pulled off very easily. In fact they just 'popped off' with a little force with a blade underneath each of them. As I think I mentioned before, it's something I've learned to do with all my EPO models when they are new.
  • rlcamden
  • thedarkwraith
    Originally posted by Rayant
    What range do you have set on the flaps? In the manual it says LOW RATE 11 mm. and at HIGH RATE 19 mm. They are right?.
    The one thing that is really critical with the flaps is ensure that they don't allow the wings to sweep back with them deployed. You need to ensure this on both low rate and high rate. The onboard gyro takes care of the logic for this so you just have to ensure that you have enough travel in low and high rate for the gyro to 'see' flaps are deployed.
    Motion has yet to post any reviews though the site says 4.7stars with 34 reviews.
    Edit- Reviews are up. 34 reviews and only two are critical.
  • Rayant
  • Cape Jets
    Originally posted by thedarkwraith
    Found a great video showing a modification you can do to the wing sweep ball links/control rod to improve it tremendously:
    According to his video there have been others that have experienced ball links popping off the wing sweep servos and resulting in a crash. This is something I will be doing to my next one for sure.
    Heard of the same issues with the wing sweep stock ball links. This was my solution. Du-Bro ball links with 2-56 treaded rods with carbon fiber tubes over the treaded rods to keep from flexing.
  • kallend
    You all might find this interesting. I believe one of the reasons why my F-14 went down was due to inadequate glue on left flap hinges. I repair electronics and used my microscope to zoom in and take a close look at the left flap hinges and hinge pockets on flap and wing.
    You aren't the first to report this.
    Mine had almost no adhesive on the stabilator where the control horn attaches.to the foam.
  • Cobbster
    I'm so glad I'm not having the troubles some of you are.Mine has been nothing but wing sweeping joy and top gun quotes since day one.I've got 14 flights on her so far. The changes I've made are:
    moved aileron pushrod to second to innermost hole on the servo end,took out elevator up mix w flaps, dampened bounce on nose gear{HUGE HELP on landings} added RIO. Ive written two reviews for motion,two weeks ago, I guess they didn't like them.
  • thedarkwraith
    Follow-up video where I look at the flap pockets on the left wing
  • thedarkwraith
  • Rayant
    Thanks for the help
  • Rayant
  • thedarkwraith
    The rear landing gear rubs on the fuselage when I pick it up. Do you have this problem too?
    I had no problems with any of the landing gear. Rears when retracted had ample clearance from body and fit nicely in the spots provided in the body. Do you have pictures to show what you are referring to?
  • Rayant
