Official Freewing 90mm PLAAF J-10A EDF Jet Thread
    • 5401
    Stock fan and ESC? Good, fresh charge battery? Calibrated throttle?
    • Didonat
      • Feb 2022
      • 2
      Originally posted by Nino
      I have the 6S version. The ESC is cutting in and out during take-off and some various throttle setting
      This happened to me on the Eurofighter. Check that reverse thrust is properly setup.
      • shortround91
        • Nov 2023
        • 301
        • Princess Anne, Maryland
        Got to finally speed test the J-10 today along with the 90 F15, super happy with the J-10 she’s stock except a KMC blue burner and custom paint job. Here’s a full throttle level pass with slight tailwind
        • Icarus the 2nd
          • Aug 2018
          • 164
          • Pajottenland, Belgium
          So little interest in this super cool jet ???
          Here's one of my flightvids during an EDF meeting in Bavaria, Germany 2 weeks ago.
          Perfect landing thanks to the reverse thrust option
            • 5401
            The plane flys well… not much else to say…
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              <RC4ever enters the chat>
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1676
                • Catalonia
                Merry Xmas everyone!!
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  Crazy jet!
                  • Andy B
                    • Dec 2020
                    • 10
                    • Hemel Hempstead - England - UK
                      • 5401
                      Sure, bypass the control box.
                      • shortround91
                        • Nov 2023
                        • 301
                        Well sorry so many bust on the J10 I have to say I bought the very first batch when 6s was only available. I recently converted to a FW 8s EDF and talk about a screamer . For me landings are even smoother to perform takes so much less throttle and an oops moment she has more than enough to pull out of anything I’ve done so far. My only issue with mine has been the retract plastic plate that is not sold separately. After 70 flights or so the bracket finally cracked then split on a second landing, a little fast on grass but smooth. No damage other than gear doors steering buckle and surround plate, even the nose cone not a scratch!! So anyways to my point I am designing a reinforcement plate for such issues ( sorry we all have bad landings ) and a fuse running $180 with no other damage doesn’t make sense to me. Right now the plate is ply but after some more testing I’ll be doing a thin aluminum plate that I’ll share dimensions with. For now here’s a pic of the ply with a few other pics, this was a slow dive wanted to break 160mph but the gear issue wasn’t going to change anything.
                        • shortround91
                          • Nov 2023
                          • 301
                          Crazy jet!
                          Always so graceful bro all your flights look like there scripted practiced over and over. Amazing hope to be half the pilot you are one day
                          • Andy B
                            • Dec 2020
                            • 10
                            Hi all, I ordered the 8s, but think I have been sent the 6s, it only has 1 ec5 connector in the fuse. Any help on how to tell if its 8s?
                            And if it is 8s, I'm guessing i will need to make a series connector for the packs? Should that not be in the kit?
                              • 5401
                              Only difference is the motor on the fan. Take off the fan cover and look at the numbers.
                              • Andy B
                                • Dec 2020
                                • 10
                                The cover is glued on.
                                8s there normally a series connector in the fuse for 8s?
                                • shortround91
                                  • Nov 2023
                                  • 301
                                  The ESC should be Blue ( hopefully) and just look inside the bottom cheater if the housing ( EDF ) is black that’s 6s if it’s metal ( silver ) it’s 8s
                                  • f4u ausie
                                    • 1240
                                    • Melbourne
                                    Can't imagine cover is glued on.
                                    If it's 8 s it will be 1350 kV.. U normally supply ya.own series connection.. .I for one certainly did on my f4
                                    • Andy B
                                      • Dec 2020
                                      • 10
                                      Definitely glued on... OK I'll make one and see if it kills the motor
                                      • shortround91
                                        • Nov 2023
                                        • 301
                                        No you will need a series connector if running 2 4s packs don’t get the small one like this and wire wise I ordered mine with 8g instead of the normal 10g. I run 2 4s packs much cheaper in my opinion SMC 49/4200 hivolt packs 4400 regular SMC packs and the occasional 59-5100 SMC hi volt packs are the sizes I fly with. The 49/4200 4400’s are great plane crazy agile the 59/5100 you can feel the weight turns a little more sluggish. Not bad but can be felt, I did trim my canard servo ends to make sure they didn’t rub using the 59/5100’s.
                                          • 5401
                                          The only difference is the motor. Same ESC in both versions and as noted you need to have a proper series adapter if you will use multiple batteries to get 8S. This is not included. There are 8S batteries that won't need the series adapter.
                                          The cover is not glued on. There are screws and the cover may be sticky.
                                          If I were you I would assume that if you got a box marked 8S version it's 8S. Another way to test is simply put a charged 6S in it and see how much thrust you have.
