F-22 Raptor 80mm EDF Jet with Gyro - PNP from Freewing - FJ22311PG
PNP: https://www.motionrc.com/products/fr...-pnp-fj22311pg
ARF+: https://www.motionrc.com/products/fr...o-arp-fj22311a
The Freewing F-22 Raptor 80mm EDF Jet captures the iconic presence of the world’s most advanced air superiority fighter with exceptional scale detail in a pilot-friendly design. This EDF jet delivers unparalleled realism and flight experience with features like molded-in panel lines, rivet details, and fully sequenced gear doors for a sleek, aerodynamic, and authentic look.
Designed for convenience and performance, the F-22 features screwless, quick-release wings for effortless assembly and transport. Its 12-blade 80mm EDF power system, paired with a high-performance 3658-2150Kv inrunner motor, ensures smooth, powerful thrust and breathtaking speed. Stability is enhanced with the pre-installed Freewing EG01 6-axis gyro, making this jet accessible to both experienced pilots and those new to EDF flying.
With shock-absorbing CNC-machined aluminum struts, spring-loaded battery access hatch, and LED navigation lights, the Freewing F-22 Raptor is as practical as it is stunning. From precise aerobatics to smooth landings, every flight feels as advanced as the jet it replicates.
Visit the Official Freewing F-22 Raptor 80mm EDF Jet Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A. ![]() |
Screwless, Quick Release Wings Enjoy effortless assembly and disassembly with the innovative quick release wing system. |
Pre-Installed 6-Axis Gyro The Freewing EG01 6-axis gyro is included and pre-programmed providing a more stable and enhanced flying experience. |
Scale Detailing Highly detailed surfaces with molded panel lines, rivets, and other details for a realistic appearance. |
Tight Closing, Sequenced Gear Doors Full gear doors, both inner, outer main gear and nose gear automatically sequenced for enhanced scale realism and reduced drag. |
Well-Protected Plastic corner protection is located in key areas to help prevent hangar rash and general wear and tear. |
Complete LED Light Package Full navigation lights, landing lights, and lighted heads up display (HUD) provide enhanced realism and visibility. |
- Screwless, quick-release main wings simplify assembly and transport
- Freewing EG01 6-axis gyro provides a stable and enhanced flying experience
- CNC-machined aluminum oleo struts for smooth, durable landings
- Inner and outer gear doors are fully sequenced for reduced drag and enhanced scale appearance
- LED navigation and landing lights improve visibility and enhance the scale appearance
- Highly detailed surfaces with molded panel lines and rivet details elevate scale realism
- Detailed cockpit with painted pilot figure and illuminated heads up display (HUD)
- High-performance 12-blade 80mm EDF for powerful, smooth thrust with an authentic jet sound
- 3658-2150Kv inrunner motor for high-performance, speed and efficiency
- 100A ESC with 7A UBEC, thrust reversing and EC5 connector for advanced control
- Plastic corner protection helps prevent hangar rash and wear
- Spring-loaded battery hatch allows quick and easy battery access
- Carbon fiber wing spars add strength while minimizing weight
- Ball linkages on all control surfaces ensure precise control
- Nylon hinges provide long-lasting durability
- Freewing F-22 Raptor 80mm EDF Jet with Gyro - PNP
- 12-blade 80mm EDF power system (installed)
- 3658-2150Kv inrunner motor (installed)
- 100A ESC with reverse thrust and EC5 connector (installed)
- Electronic, retractable landing gear (installed)
- LED lighting (installed)
- Servos (installed)
- 6-8 channel radio (8 required for thrust reversing) - Select a minimum 6 channel radio from our Radio Collection
- 6-8 channel receiver (8 required for thrust reversing) - Select a minimum 6 channel receiver from our Receiver Collection
- 6-cell 5000mAh LiPo battery with EC5 connector - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery with EC5 Connector
- Minimum 6 Cell Battery Charger - Select a minimum 6 Cell battery charger from our Battery Collection
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :1 Hour
| Scale | 1/16 |
| Wingspan | 935mm / 36.8in |
| Length | 1300mm / 51.2in |
| Flying Weight | 2530g / 89.2oz |
| CG (Center of Gravity) | 115mm from the leading edge of the wing at the wing root |
| Power System | 3658-2150Kv inrunner motor |
| Electronic Speed Control | 100A brushless with 7A UBEC and thrust reversing |
| Propeller / EDF | 80mm EDF with 12-blade fan |
| Servos |
| Landing Gear | CNC-machined aluminum, shock absorbing, retractable landing gear |
| Required Battery | 6S 22.2V 4000-5000mAh LiPo with EC5 Connector (EPR50006) |
| Required Radio | 6-8 channels (8 required for thrust reversing) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | Yes |
| Hinge Type | Nylon |
| Material | EPO foam |
| Skill Level | Intermediate |
| Build Time | 1 Hour |
| Recommended Environment | Outdoor |
