Official Freewing 80mm F-22 Raptor EDF Jet Thread
  • 3D-Seth
    • Mar 2023
    • 35
    Click image for larger version  Name:	master.jpg Views:	0 Size:	63.9 KB ID:	417184
    F-22 Raptor 80mm EDF Jet with Gyro - PNP from Freewing - FJ22311PG
    PNP: https://www.motionrc.com/products/fr...-pnp-fj22311pg
    ARF+: https://www.motionrc.com/products/fr...o-arp-fj22311a
    The Freewing F-22 Raptor 80mm EDF Jet captures the iconic presence of the world’s most advanced air superiority fighter with exceptional scale detail in a pilot-friendly design. This EDF jet delivers unparalleled realism and flight experience with features like molded-in panel lines, rivet details, and fully sequenced gear doors for a sleek, aerodynamic, and authentic look.
    Designed for convenience and performance, the F-22 features screwless, quick-release wings for effortless assembly and transport. Its 12-blade 80mm EDF power system, paired with a high-performance 3658-2150Kv inrunner motor, ensures smooth, powerful thrust and breathtaking speed. Stability is enhanced with the pre-installed Freewing EG01 6-axis gyro, making this jet accessible to both experienced pilots and those new to EDF flying.
    With shock-absorbing CNC-machined aluminum struts, spring-loaded battery access hatch, and LED navigation lights, the Freewing F-22 Raptor is as practical as it is stunning. From precise aerobatics to smooth landings, every flight feels as advanced as the jet it replicates.
    Visit the Official Freewing F-22 Raptor 80mm EDF Jet Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Screwless, Quick Release Wings
    Enjoy effortless assembly and disassembly with the innovative quick release wing system.
    Pre-Installed 6-Axis Gyro
    The Freewing EG01 6-axis gyro is included and pre-programmed providing a more stable and enhanced flying experience.
    Scale Detailing
    Highly detailed surfaces with molded panel lines, rivets, and other details for a realistic appearance.
    Tight Closing, Sequenced Gear Doors
    Full gear doors, both inner, outer main gear and nose gear automatically sequenced for enhanced scale realism and reduced drag.
    Well-Protected
    Plastic corner protection is located in key areas to help prevent hangar rash and general wear and tear.
    Complete LED Light Package
    Full navigation lights, landing lights, and lighted heads up display (HUD) provide enhanced realism and visibility.
    Features:
    • Screwless, quick-release main wings simplify assembly and transport
    • Freewing EG01 6-axis gyro provides a stable and enhanced flying experience
    • CNC-machined aluminum oleo struts for smooth, durable landings
    • Inner and outer gear doors are fully sequenced for reduced drag and enhanced scale appearance
    • LED navigation and landing lights improve visibility and enhance the scale appearance
    • Highly detailed surfaces with molded panel lines and rivet details elevate scale realism
    • Detailed cockpit with painted pilot figure and illuminated heads up display (HUD)
    • High-performance 12-blade 80mm EDF for powerful, smooth thrust with an authentic jet sound
    • 3658-2150Kv inrunner motor for high-performance, speed and efficiency
    • 100A ESC with 7A UBEC, thrust reversing and EC5 connector for advanced control
    • Plastic corner protection helps prevent hangar rash and wear
    • Spring-loaded battery hatch allows quick and easy battery access
    • Carbon fiber wing spars add strength while minimizing weight
    • Ball linkages on all control surfaces ensure precise control
    • Nylon hinges provide long-lasting durability
    Includes:
    • Freewing F-22 Raptor 80mm EDF Jet with Gyro - PNP
    • 12-blade 80mm EDF power system (installed)
    • 3658-2150Kv inrunner motor (installed)
    • 100A ESC with reverse thrust and EC5 connector (installed)
    • Electronic, retractable landing gear (installed)
    • LED lighting (installed)
    • Servos (installed)
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :1 Hour
    Scale 1/16
    Wingspan 935mm / 36.8in
    Length 1300mm / 51.2in
    Flying Weight 2530g / 89.2oz
    CG (Center of Gravity) 115mm from the leading edge of the wing at the wing root
    Power System 3658-2150Kv inrunner motor
    Electronic Speed Control 100A brushless with 7A UBEC and thrust reversing
    Propeller / EDF 80mm EDF with 12-blade fan
    Servos
    • Nose gear steering — FSS31093-500
    • Nose gear door — FSS31091-600
    • Left and right aileron — FSS31093-200
    • Left and right flap, left and right rudder — FSS31093-100
    • Left elevator — FSS31232-100
    • Right elevator — FSS31232R-100
    • Left main gear door — FSS31091-300
    • Right main gear door — FSS31091R-300
    Landing Gear CNC-machined aluminum, shock absorbing, retractable landing gear
    Required Battery 6S 22.2V 4000-5000mAh LiPo with EC5 Connector (EPR50006)
    Required Radio 6-8 channels (8 required for thrust reversing)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Yes
    Hinge Type Nylon
    Material EPO foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Environment Outdoor
  • kallend
    • 1877
    Just what we need. ANOTHER F-22.
    They'll soon be like P-51s, everywhere in all sizes.
    • colinski
      • Sep 2021
      • 2
      I like it!
      Everything that was missing on the 70mm, such as nav lights, and nosegear lights, is on the 80mm. Love all those plastic edges around the intakes and battery bay.
      Hope it flies of grass well. Nose wheel seems not much bigger than the 70mm F22 version. And that cheater will probably suck op dirt or grass in to the fan.
      Also hope that the gear door sequence can be changed, allowing after deploying of the gear, those gear doors will close again, so they won't catch on the grass while landing.
      It was said in the video that CG battery position was tight on a admiral 5000 pack, hope they kept in mind that not everybody flies that brand, and some other brands 5000's are heavier and would need to shifted back a bit more. Hope there is some room left to do so!
        • 5401
        It looks like it has a MCBe which has two stage doors in it. I also like the plastic covers on all the servos. Not only all the things the 70 lacked but also the 90!
        I do wish Flightline would come out with a nice P-51D similar in size to the big Spitfire. Never too many Mustangs!
          Speaking of that, it would be cool to have a v2 of the 90, with all the new features, and maybe also incorporate optional thrust vectoring parts with it?
          • e4dragongunner
            Living the dream!
            • 876
            • Arlington Heights Il.
            Amen Evan! We need a Flightline 1600 mm P-51 and a Zero and dare I say a BF109G!
            BTW! love the 80 mike mike F22 offering!
              • 5401
              Yes to the V2 90mm but I wonder if this new 80 is their way to do that. The 90's are getting very close to $1k.
              e4, yes to the Zero and Messerschmitt too.
                • 2818
                • Arlington, TX
                The full gear doors and realistic sized/located gear seals the deal for me. I've planned on moding the 90mm F-22, but this gives the complete package in a more convienent size.
                  • 8228
                  Never too many F-22 size offerings in my book. Love the F-22 and this 80mm has all the latest updates and amenities and a better size for my field. Look forward to picking one up in late Spring!
                  • EDF-Jetpilot
                    Jets are a lot of fun
                    • May 2024
                    • 135
                    • Aarburg, Schweiz
                    This is very good for me. ;-)
                      True story on the 90mm pricing.
                      • EDF-Jetpilot
                        • May 2024
                        • 135
                        • Aarburg, Schweiz
                        Haa, laakiin 80mm aad ayuu uga fiican yahay 90mm, aad u faahfaahsan, aad u qurux badan, aad u deggan, aad u waara oo leh waxqabadka duulimaadka. Markaa waxay ku kici kartaa ilaa 90mm duug ah.
                        • EDF-Jetpilot
                          • May 2024
                          • 135
                          • Aarburg, Schweiz
                          Yes, but the 80mm is much better than the 90mm, more detailed, more beautiful, more stable, more durable and with better flight performance. So it can live up to 90mm.
                            • 5401
                            You have flown the 80 and 90? Which 90 are you saying flies much worse, 6S or 8S? Why?
                            In other words I don't believe you at least for flight performance. More durable how? More stable, how?
                            • EDF-Jetpilot
                              • May 2024
                              • 135
                              • Aarburg, Schweiz
                              The flight performance of the 90 is not really good, but the 8S is not bad. the 80 has a better power-to-weight ratio. The flight characteristics of the 90 are of course very good, that's not what I meant. In terms of stability, handling and durability, the new 80 owes its success to the many plastic reinforcements and the simple wing assembly, as well as to the better undercarriage. But in the end it's purely a matter of preference as to which one you like best.
                                • 5401
                                You have flown the 80? Do you have an 80? Do you have a 90 or the new 70?
                                Flight performance in what way? I have the 90, on #3 and have a spare in the box #4. I've flown the 90 6S, 8S, 10S and 12S and have put TVs and lights on all of them and think it's the best flying EDF that FreeWing makes. I also have the 70 and for what it is it's pretty darn good. My 80 is due in tomorrow but it'll be a few days before I can fly it with the weather.
                                How does "simple wing assembly" have anything to do with stability, handling and durability or "plastic reinforcements" for stability and handling? And how do you consider the undercarriage better? I think the 80 has a lot of improvements over the 90 but none for stability (except that it comes with a gyro, if you get the PNP, I can't use how I'll set mine up) or handling and yes durability should be a bit better with the plastic edging.
                                • EDF-Jetpilot
                                  • May 2024
                                  • 135
                                  • Aarburg, Schweiz
                                  Years ago I learned to fly jets with various Freewing F-22s. It is an absolutely great flying model and easy to control because, like the F-16, it does not stall. I can still remember the feeling of flying the Freewing 64mm without a gyro. All I meant was that the new 80 stays nice longer thanks to the plastics, that the 80 has more power out of the box than the two old 90s, similar to the new 70. The undercarriage is reinforced with metal plates and mounted more solidly (plastic), so it is better and also nicer (scale) with the additional flaps. That's all. So you are an F-22 fan... I can understand that, just as I am an F-16 fan, I love the F-16 more than anything and have every size of it ready to fly in the hangar. I fly the F-16 on about 90% of my missions!
                                    • 5401
                                    The 8S 90 still has the best power out of the box though of course modified with a 10S and 12S it had even more, I did have a JetFan 8S in my first two but FreeWings new 8S 90mm fan is as powerful. They all, 70, 80, and 90 have plastic mounted very good gear and all have flaps. Cool to do this https://www.youtube.com/watch?v=0UtX...ature=youtu.be
                                    Which F-16 do you like best? I don't like the F-16 as much as the F-22 but have three of FreeWings new 64, one on 6S, their 70mm and the new V2 90mm 8S (I also had the V1 90mm). I also recently had the Eflite 80mm on 8S but didn't like how it flies. Do you have the 105mm? I was thinking of getting one, I like my 105mm L-39.
                                    • EDF-Jetpilot
                                      • May 2024
                                      • 135
                                      • Aarburg, Schweiz
                                      That may be, I'm happy to believe you.
                                      I had the E-Flite 64, but I sold it because it was too small for me. I currently have the E-flite 70 and 80 on 6S and the Freewing 90 V2 8S. I've ordered the HSD Belgian F-16 105mm with a 134cm wingspan, but unfortunately it won't arrive until March 2025. I can hardly wait. I like flying the E-Flite 80 in grey with flaperons and tailerons the most... I fly it almost every day in the evening after work during the season, using 5-10 batteries. I'm still in the process of testing and adjusting the 90 V2, but it's going well.​
                                      I'll have to get the new F-22 80mm too... I can hardly resist.​
                                      • shortround91
                                        • Nov 2023
                                        • 301
                                        • Princess Anne, Maryland
                                        Well can’t say I can agree with the 80 more power, I own 3 70’s a 90 6-8s. The 90 on 8s is so much more capable than on 6s but thrust wise I watched the speed run video of 117. My 70 Raptor box stock with tailerons runs 132 all day in a mild dive on a SMC hivolt pack with 90 Raptor doing exactly 117 on 6s then 127 on 8s again no steep dives. All GPS’d and witnessed by many club members. I love all the upgrades to the 80 but can’t see gear covers changing that much to handling or how much better it can fly. My second on this will be pack size, I run SMC 59/5100 hivolt packs in my 70’s all the way to the wall cockpit has been modified. If it’s tight with a admiral 5k I’m not sure I’d be able to get CG where I like it to be just my opinion and guys let’s make a 8s option on a 80 as well
