  • themudduck
    ^ That is so cool. It keeps the horizon level. Is that a setting on the camera? Can you turn that off and make it follow the roll?
    see above post.... its controlled by the software, you can play it back in stabilized mode or in regular mode.
  • themudduck
    That is truly amazing. How did you attach it to the pylon and how long is the battery good for? Very unique perspective, one that to me looks much better than the other cameras. Saw it on Amazon, about $195 right? What medium is it saved on and what type of batteries? Thanks, sorry for all the questions, just looks really cool and if I get a camera, I would like something like that.
    Hey guys, yeah it is really cool! My friend posted an edited video (3 videos in one) where I mounted the camera on the tail of the AL37 airliner - it looks like someone is following the plane.
    So this little camera comes with a small magnetic "docking station" that charges the camera and downloads the video. There are some electronics in the docking station and I guess that helps keep the camera small. I don't know for sure but the camera seems to use a capacitor instead of a battery, because it won't hold a full charge for more than a few days (I have to recharge it for each weekend). Maybe it just has a tiny battery!
    The longest video it can take is 5 minutes (it won't record longer than that). You can take several 5-min videos in a row. It saves the videos internally and then you download it to your PC using the docking station. You can also use it with your phone (Iphone or Samsung). It uses proprietary software (free download) that you have to use, but then you can save it in a standard format. So it does have some limitations but it is very small and takes this really cool video. It has two modes - the stabilized mode and an "FPV" mode which looks exactly like a regular video. The magic is in the software, its takes a 360-degree video and when you play it back it looks like you see in my previous post. You can play it back in either mode - but the neat thing about the stabilized mode is that you can mount the camera in any position and the video will play back "upright". With the "FPV" mode the camera must be upright. (FPV mode is not FPV, that's just what they call it)
    It will also take individual pics, and can be used to take "hyperlapse" videos (a string of pictures) but I got it for the video.
    What I did was to mount the camera in a custom-made 3D-printed plastic pod that mounts on a FW weapons pylon.. (I haven't uploaded the new one to Thingiverse yet but I will).
    Click image for larger version  Name:	20201001_221256.jpg Views:	0 Size:	54.6 KB ID:	283644Click image for larger version  Name:	image_63844.png Views:	3 Size:	124.1 KB ID:	283642
    I took a video today using an Insta 360GO camera mounted on the outboard pylon. Unfortunately the video timed out before the landing, but its still pretty cool. The 360GO camera stabilizes the horizon which produces some pretty cool effects when rolling and doing other maneuvers. I recommend turning the sound OFF because of the wind noise.
  • themudduck
  • Gringotuerto
    ... with enough altitude for an OMG event where I went the wrong way on the rudder ...
    A guy at the field suggested remembering this rule for entering a knife edge: if you see the canopy, push the stick toward the tail; if you see the wheels, push the stick toward the nose. Works for either direction of travel. I don't know if you find these kind of mental tricks helpful, but I do. Some people find it easier to mentally rotate the plane to the Tx orientation.
    Originally posted by Gringotuerto
    OK, I took the A-10 out last weekend. It was great as always! But I still didn't nail the knife edge very well. For one thing, those rudders are large, and it is very sensitive. I guess that is good, but it also means I can't just hold the stick all the way to one side like I do with the Avanti. Also I found it definitely pulled towards the canopy - as you say, needs some down elevator to track straight. Anyway, I'll get it eventually. I'm just happy every time I take it to the field and it comes home in the same condition, lol.
    Just keep at it, it will come as you get more confidence. Agreed that with the Avanti, it requires almost full rudder (have my rudder rates on high for that) but will also climb a bit with full rudder (so either reduce the power slightly or use less rudder). I get a lot of practice with knife edge on my fleet of Extreme Flight planes and it has taken a lot of practice but works well at 60% throttle and maybe about 40% rudder deflection (but then the amount of deflection on those aircraft in high rates is almost 75 degrees, so for knife edge reduce it to mid rates). You may want to try the knife edge on the A-10 with mid or low rates. I use mid rates which are 1/2 way between book rates and use about 80% deflection at 75% throttle. Doesn't always work perfectly but just need to keep at it with enough altitude for an OMG event where I went the wrong way on the rudder (even though I have to force myself to think ahead which direction I am rolling and which direction the rudder needs to go - I'm definitely not intuitive like many out there, I seem to need a que card in my face reminding me which way to go first and sometimes still go in the wrong direction depending if I'm going downwind or upwind to keep the top facing me).
  • themudduck
    Hey what Colt just said, move the CG back and land on the mains every time, no problem with the bucking bronco. Bouncing on the nose gear is a common problem in a nose-heavy setup.
  • Gringotuerto
    For some lucky reason, I've found that knife edge with the A-10 is surprisingly easy, requiring almost minimal down elevator to keep it tracking straight. ...
  • ColtPilot
    ​​​​​​Got another 7 flights in today on the A-10 along with 4 on one of my F-4's. Every time I fly the A-10, it just seems to fly better each time, which at this point is almost impossible to get better unless I let a decent pilot take her up for me! Would have got more but these 2 burned through my 18 RT 6250's and I refuse to waste time at the field charging, and I'm not going to buy any more batteries, 140 are enough (man, just think how many more actual planes I could of had instead).
    Anyway, interesting observation here: I fly off grass so upgraded the nose to the trailing link. We had 14-18 mph winds directly down the runway, but neither of them seemed to give a hoot about gusty winds (thankfully not a crosswind though). With jets, I always start out the take-off run with full elevator to relieve pressure on the nose gear which helps it get up to speed quicker on grass, then slowly release elevator just before lift off leaving just enough up to lift off smoothly. Since we had a strong headwind, just to see what happened, I started a take-off run with NO up elevator. The result was that it drove the nose pressure down so much that about 1/2 way down the run, the trailing link was fully depressed. Started over with my normal take-off procedure and that ended that experiment!. The twin "exhaust " thrust is directly over the elevator surface (and if you test it out on the bench you can see and hear just how much thrust the elevators directly influence), that if you use full or even 1/2-3/4 up elevator on take off, it REALLY forces downward pressure on the tail, thus keeping the nose "light as a feather". Probably not needed as much on asphalt, but on grass, wow, what a difference.
    The other thing I noticed was that for landing, downwind around 28-32% throttle, final glide after lining up runway reduced to 15% and then 8%, and about 4 feet off the runway throttle to 0 and then raise the nose before touchdown gets just a perfect somewhat high alpha landing with 0 bounce (actually have never experienced the bucking bronco effect yet ) resulting in a 10-15 foot roll out, at least on grass. Never thought I'd ever chop the throttle on a jet, but this is not your "grandmothers" EDF. Noticed GliderGuy on a post in the Mig 29 thread with almost the exact throttle positions for landing, so these both seem to be a little different than some of the others being a bit larger and able to glide easier without dropping like the proverbial rock.
    The only way to get bucking bronco is landing on the nose gear first. One of the reasons I went to oleo struts on the mains. No bronco effect at all.
    Yes it is a great flier, but I still don't take it out nearly as much as the Avanti just because the Avanti is so easy to put in the truck. But I'm planning to take the A-10 out this weekend. Have you tried knife-edge with the A-10? I do that with the Avanti all the time, but if I recall correctly I had trouble getting this stable with the A-10 (although I only tried a couple times).
    For some lucky reason, I've found that knife edge with the A-10 is surprisingly easy, requiring almost minimal down elevator to keep it tracking straight. I assume the twin large vertical stabilizers are part of this equation. I'm also flying at a CG of about 92mm instead of the book 78mm which probably also contribute to the lack of need of any substantial elevator mix (which I'm not sophisticated enough to figure out mixes with so all my aircraft that I do a knife edge with never have compensations in). The A-10 will also climb for me if needed during knife edge with only 80% throttle, but then I'm also using an extra 15% in high rates on rudder travel for knife edge. And I'm no "super experienced pilot", probably just relatively average like most of us, so I'm very impressed with the A-10's capabilities. I do fly knife edge extensively with my fleet of 60" Extreme Flight aircraft, and my Bi-Planes, but with those if you get a good CG point, all you have to do is "think" about doing a knife edge and it's there, with no mixing needed and they fly around the field in figure 8's or any pattern while in it.
    And I completely agree with you regarding the Avanti, it seems to almost prefer knife edge flight over the ho hum standard level flight. Still working on doing a flat figure 8 in knife edge with the Avanti but think I'll finish it soon if my nerves hold up and I have enough spare under shorts. Not sure I'll even attempt that with the A-10.
  • Gringotuerto
    ​​​​​​Got another 7 flights in today on the A-10...
    Hey, what's 3000 miles or so among RC buddies? I'll be there shortly, leave on light on!
    Consider it done!
    Originally posted by Aros
    Fabulous work Hugh Wiedman ! Wish we lived close, we could have some pretty cool tandems!
  • Dirty Dee
    Hugh Wiedman great work!
  • themudduck
    That is really spectacular work. I love those spirals on the fan cones.
ID:	279621Click image for larger version
  • James
    This thread has been a little "quiet" lately with everyone exploding the MIG thread ​, but after almost a month after I finished the Arctic build, I finally finished (although still need to apply the clear gloss spar urethane to it) the Dirty Dee cockpit. Good thing I bought a second cockpit to work on so I was able to maiden the A-10 and get about 30 flights on it while I "occasionally" worked on the cockpit. Chris's design is absolutely fabulous and everything fits "like a glove" once you get the foam cut out correctly. This wasn't an easy rebuild (especially cutting out the correct amount of foam), but then again nothing is easy for me, and I want to thank Chris for his incredible design and others who helped me out immensely with the parts. I used a JH Hobby 1/10 scale full body pilot, same as what I put in the F-18 Canadian and he fit very nicely. The finished cockpit weighed in at 274 g, which is 170 g more than the plain stock cockpit. In order to keep my CG at 92 mm (which I felt made it perform the best for me), I had to move the 2 RT 6250 batteries back another 2 1/2 inches and move the battery straps and extend the floor under the forward battery. I had already removed the circuit board and velcro-ed it to the back port fuselage wall, but at this point, I can't get the CG any further back without going to lighter batteries, which ain't going to happen since I love the 5+ minutes of flight time coming in with 35% or more left in the tank. I know I'm repeating myself, but I love everything about this jet, which I would have never guessed even at the point that I finally purchased one! I initially thought that this might end up as a "hangar queen" but it just refuses to be left at home when I'm heading to the field. It easily replaced the Avanti as my first EDF flight of the day and the poor little Avanti hasn't been out in months.
ID:	279601Click image for larger version
ID:	279602Click image for larger version
ID:	279603Click image for larger version
ID:	279604Click image for larger version
ID:	279605Click image for larger version
ID:	279606Click image for larger version
    Looks great Hugh! Any pics of the entire plane finished?
