1. With Spektrum, you must in the system setup, select "aircraft" (or wing) type as 1 AIL, 1 flap. This opens up the flap menu where you can properly select the switch and dial in your deflection, elevator compensation and deployment time.
2. When setting up the flaps, using servo sub-trim and/or manually placing the servo arm at the desired "starting point" for flap deployment, will better even them out. You know which way the servo arm moves to deploy flaps. When at level (or no) flaps, the servo arm should be at their starting position. You need to somehow put them there to begin with. A servo tester will come in handy to begin the process.
3. If you do #2, the rods should be of adequate length. Also, you need to measure all of them before putting them on. IE, it's possible that you used rods for one control surface that was meant for another.
1. I'm not sure what you mean...what Tx do you have? When you say "I can adjust the flap value" how are you able to adjust it? Anyway, since you mention switch D and this is a common switch for flaps on a DX18, I might guess you have Spektrum DX18 or similar. I have a DX18, and on that the switch is controlled directly from the "Flap System" menu, it is the next setting below the three positions, can select this and cycle through various switch assignments.Ok, so i have everything wired, calibrated etc.. I have my flaps and gear going thru mixing board.. Everything else thru rx..
The 3 issues im having is
1) i cant activate the flaps via switch, i can adjust flap value and see movement, but not when I activate flaps via switch D,
2) with regard to inside flaps, at power up they deployed to full throw in down position, while outside flaps are in neutral position.?
3) And Finally the control rod for inside flap appears to not be long enough as the control surface will not line up w/trailing edge.. At max adjustment it is still deflecting..
I really appreciate the hand/help fellas!
2. I think these should all be ganged together, receiving the same signal. And all are the same direction servo. Are you sure you didn't remove one of these from the control board? I think if they are all plugged into the control board, the signal wires are shorted together and therefore all get the same signal.
3. Two solutions I can think of :
(a) when you say "max adjustment" do you mean 100%? most radios have a separate travel adjustment where you can get >100%, which basically gives you more than 1ms-2ms range. For example my receiver seems to be able to output pulses from <700us to >2.4ms.
(b) otherwise you have to unscrew the ball link a bit to lengthen the rod. I often have to do this two or three turns on a new plane, they don't come pre-adjusted. I always get a bit nervous if the link is unscrewed so far that it becomes relatively easy to turn. To me that means it is a bit loose. In those cases I might apply a bit of glue after I'm sure I have the right position.
If I remember correctly I mixed up control rods while initially setting up the wing controls. Double check you have the correct rods in place.
I wish I could help you with the flap deployment issue but it is hard to troubleshoot a radio setup issue via the web.Leave a comment:
I really appreciate the hand/help fellas!Leave a comment:
Didn't realize you were going through the board with the throttle leads. Since the throttles don't need the ribbon cables as the motors are in the fuse, the board is not used. Not sure what you mean by "tie in the control box"? Do you mean how do you power it? The external BEC plugs into the RX and the RX then shoves power to the board through the other leads going out of it to the board. Some people even bypass the board for the ailerons but that requires extensions from the wings. The elevator and rudder go through the fuse and don't have to go through the board either.
Ok, so a techie at Motion gave me a hand.. I was using the board for the throttle to tx.. He said to bypass the box, y-harness the throttle, plug the batteries in, AND THEN plug bec in.. For whayever reason, he said the control box (expletive blows, and it will cause the delayed sync..I'm talking about the product page at MotionRC. In the support section, you will find the manual for the ESCs in this plane. Here, I've found it for you.
Factory default reset is item #7 in the beep tone list.
From the looks of your video, that is NOT normal. 1. The motor start ups are too far apart. 2. The throttle stick is way too high when one starts and shuts down.
Try the throttle calibration first. I also noticed in your video that your throttle trim is left in the middle. Not that there's anything wrong with this as some people do it that way, however, try to click the trim as low as it will go before you do the calibration. Give the following a try if you are able to do it by your self or if you can get a second person to help you.
1. Turn ON TX.
2. Move throttle stick to max. DO NOT have the throttle cut activated. The TX must send out a full throttle signal.
3. Now, plug in BOTH battery connectors as quickly as you can. This is where a second person can come in handy. However, if you are alone, it can still be done if you hold the plugs in such a way that you can plug them in very quickly one after the other.
4. (From previous power ups, you should know what the initialization sounds like normally when you plug the batteries in.) As soon as you hear the initial beeps end, pull the throttle stick to the bottom. At that time, the beeps should continue to the final 6 beeps telling you that you are using 6s batteries. If you are too slow in plugging in the batteries together or if you miss and go past the first, initial beeps, you are likely to set the brake ON to one of the ESCs and only calibrate the other.
If successful, unplug the batteries. Keep TX ON, throttle low and plug in the batteries (no need to hurry anymore). Now test the throttle to see if both motors start up together.
As soon as we did it w/o cb, immediately synchronized.. Dude was awesome...
Everyone gave me the right advice and I'mssuper greatful, except I didn't think to by pass the control box.. I wanted to use to take advantage of the ribbons to some degree..
So now I'm curious, If I'm bypassing the control box for the throttle, and go directly to rx, how do i tie in the control box??Leave a comment:
I saw a suggestion somewhere that I liked - fish out a BEC from a crashed plane, attach it to a battery, and use it as a standalone power source for your Rx. That way you can interact with the non-BEC ESC by itself, without hearing tones from the other one. It is not too hard to calibrate both ESCs at the same time if everything goes perfectly. But if anything needs debugging, you really want to be able to interact with each one individually.Look ma, no trim I had the same issue with my A-10. It took several attempts to get the calibration correct . xviper is giving you good advice above.
You could use any 5v source, but most people have a BEC from a crashed plane laying around. If you don't, you obviously don't fly enough
This is useful in general. For example if you are setting up a new plane, and want to power up the Rx (for example to center a servo), it is useful to have a small, movable, standalone power source.Leave a comment:
Look ma, no trim I had the same issue with my A-10. It took several attempts to get the calibration correct . xviper is giving you good advice above.Leave a comment:
Excuse me, i should have clarified, I downloaded the um from HW for the ESC, but that only went to 80a opto esc.. Maybe the 100 is different to program? Did you mean the product support page to the esc from HW, of the product support page from FW.. Tbh i didnt check FW fir um.. Let me do that now
1. Turn ON TX.
If successful, unplug the batteries. Keep TX ON, throttle low and plug in the batteries (no need to hurry anymore). Now test the throttle to see if both motors start up together.Leave a comment:
Excuse me, i should have clarified, I downloaded the um from HW for the ESC, but that only went to 80a opto esc.. Maybe the 100 is different to program? Did you mean the product support page to the esc from HW, of the product support page from FW.. Tbh i didnt check FW fir um.. Let me do that nowLeave a comment:
A video of my dilemma..
Im not really sure how to set 2 throttle channels and dialing in low throttle endpoints,ttbh, to bypass resetting the esc.. Im game though, I have. G2 DX8.. Ive downloaded the user manual, and i see no option for the the reset.. Maybe someone has some iside info on the reset?
How do you reset the esc? I've been read the manual and dont see a reset option..Leave a comment:
yes they should. If after resetting both esc to default and then calibrate both esc and they still do not start at the same time then do this.
Put both esc on separate channels and adjust the low throttle endpoint for each esc in your transmitter.Leave a comment:
Not really. Even if i star from zero throttle and idle up, if i do it gently i can get the one to spin slightly before the other.. I thought they should mirror one another, no?That seems to tell me that you have set the brake ON to one of the ESCs. Somehow, in the process of trying to calibrate the throttles, you allowed one ESC to go into programming mode. IE, you lowered the throttle on that ESC too late. I think you need to test it again to see if the brake is indeed ON. When you lower the throttle, does one fan actually stop itself fairly quickly? If so, the brake is ON. You'll need to find the instructions for the ESCs and take the brake OFF. Then I suggest you do the throttle calibration again, properly. Do one side at a time as it seems it doesn't work for you when you try to do it both together.Leave a comment:
So I believe I've eliminated the noise. Now I'm noticing 1 fan come on before another. Once spun up, if i drop it down to almost 0 throttle, 1 fan will stop while the other continues. However, once I raise throttle they both spin again.. Wasn't that covered by lowering the stick from top to bottom after plugging it in, during the process you explained to me??
Thanks Colt Pilot!Leave a comment:
Did you say your throttle trim is all the way down? I would put it back to center and recalibrate.Leave a comment:
No, not normal. Should have nothing at full down throttle stick. No noise nothing. The new ESC's you have to be quick to set. Had to on the AL-37. Had to go through the process 3 times and finally got it. Have to be quick on the first beebs.
Thank you for the reply ColtPiltot !!
Ok, so I opened up a new rx, and have them bound and synched, I believe lol.. I guess crashed reciever snuck past me ..However, they still beep? I have throttle control, but as soon a return to 0 throttle, they begin to beep again..Is this normal?Leave a comment:
Make sure you plug in the non bec connection first, then the bec connection. Repeat the process. The other would be the ESC line to the RX isn't connected properly. The ESC isn't receiving the signal from the RX. Then the rest of what you did. The only thing I can think of.
