Official Freewing 70mm F-16C Falcon V2 Thread
  • Bobaroo
    Great Flyer. Flies well loaded also. FFStabs on mine. Never flew it with the stock elevators.
  • MOFO1
    Check this out my Dirty Diana. Been flying her and enjoying every minute of it..
  • gooniac33
    Originally posted by The swede View Post
    Hi guys!
    Has someone a link to that afterburner some of you use? I think, I must have one :-)
    Thanks and happy new year!
    I have this set up in several of my planes. My F-16 was the second one to use this. PM me fore more details...
  • The swede
    Thanks purduephigam!
    I will definitely check this out)
  • purduephigam
    thercgeek.com
    Chris has the centerburner available for inrunners and outrunners. Take a look, I have a handful in my EDF's!
  • The swede
    Does it work with this https://www.rc-castle.com/index.php?...roduct_id=4825
    Or is it better with 64 mm?
  • The swede
    Hi guys!
  • The swede
    Sam CS, I have been flying Rc for ten years now, both warbirds and EDF. But never any EDF with landing gear. I have a few 70mm jet (4S) but it is belly landing on grass for those. Thats why I have all these quastons :-) Because I do not have much experience of that.
    So I am very grateful for all good answers I got :-)
    I always want to know as much as possible before I buy a new modell.
    So thank you, and the rest of you for taking your time to answer
  • Sam CS
    Ok, thanks for all good answers. Because here in Sweden its hard to find a nice and big asphalt court :-)
    How mutch flaperons do you have for take off and landing?
    And is it mutch unstable when using flaperon when you use it for landing or take off?
    I'm getting more and more crazy about this plan, the more I look at it hehe. It was a long time since I read so much good about an airplane, with few cons.
    Swede, i am forced to fly on the road. Its a dead end road but still, i get traffic and wife is watching for cars. My usual flying space is elementary school, nice parking lot. The only problem is the light pols that i seems to be attracted to ;) So, that said, i will go back to school when i feel confident landing F-16. So far it's been rough due to winter, snow and more snow.
    On flaps; i am not an expert but, i was told to use about 15 to 20 degrees. Be careful not to "blank out" your elevator with flaps down. 15 to 20 seem to work out pretty good for me, glides really nicely.
    Flaperons on landing: it's not that the aircraft is "unstable" during landing, it's more like "not as responsive" and that's because your ailerons act as flaps. First time i noticed that on su-35... i wrecked the plane lol.
    By the way, this f-16 handles very well with and without flaperons. I learned to fly it without and have few landings with flaperons but only when i felt comfortable landing it. I was also advised on this forum to use elevons when using flaperons, this makes aircraft more responsive during landing.
    I don't know what your experience level with EDFs or RC in general but, i would recommend watching lots of videos on youtube about the model.
    Gooniac33 has few vids on his youtube channel, pay attention how he lands. I learned a lot just by watching others land. Will save you time and effort in the long run.
  • The swede
  • Sam CS
    Hello guys,
    3. Are flaperones to be preferred?
    I use flaperones for take off and landing... works great in both cases. Plane handles different on landing though. Also, when flaperons are active, i use elevons as well to help with control. Works great, love this plane.
  • Jhnybgd
    Mine would not rotate from short grass....
    maybe this time of year when the grass is dead,but when its green and thick good luck.
    Welcome to Hobby Squawk Swede! If you get the 6S Pro version, it will indeed fly from short grass. Getting the upgrade landing gear is recommended for grass ops as well. I have found that flaperons really help shorten the take off roll, but are not needed for landings. If you choose to use flaperons, you will have to have at least a 7 channel receiver so you can put each aileron on its own channel. She's really good flying plane. :Cool:
  • The swede
    Hello guys,
    impressive work that many of you have done with painting and afterburner etc. very nice.
    Im thinking to buy this F16 for myself for Christmas presents but I have some questions after I have reading a lot of pages here.
    1. Is it possible to lift from short grass?
    2. What are the problems that many of you have/had with the elevator?
  • Sam CS
    Originally posted by gooniac33 View Post
    I use the Dr. Madthrust 2960 2200kv motor for the 14 blade rotor. If you are using a 12 blade you could probably go a little higher KV but I am not sure you wanna do 3400kv. 2600kv may be good but not much higher...
    Thanks dude, and after posting my question, i red the whole thread. I found your posts where you talk about upgrading to your current setup.
    By the way, i have 3400kv installed right now because i am doing 4S setup. It pulls crazy Amps and battery gets warm.
    I am about to test and see what my flight time will look like.
    I have a feeling i will have to swap my 4S setup for 6S and that's because most of you guys on this forum have great success with 6s.
  • Sam CS
    Originally posted by Rcfiddy1 View Post
    About to throw this f16 in trash. Any suggestions? Like I said it flew great at first but now she is a dog. Won’t pull any verticals, speed is drastically reduced.
    No, don't do that, just troubleshoot. Do what c17lm mentioned above and in my experience, after installing new fan, i did a test run on it. What i found out after checking the fan unit, is that my fan rotor came loose. so make sure all is good.
    You also mentioned you have access to program ESC. Does your ESC logs RPMs? If so, you could pull logs from the esc to see what rpms you are running at.
  • C17loadmaster
    Also, I could be wrong... but the retracts have shorted out in mine a couple times. Maybe unhook the nose gear in the down position, it may be drawing a bunch of power if it’s shorting out
  • C17loadmaster
    Take out the fan and motor and make sure the fan spins freely and doesn’t have a “hollow” blown bearing sound. If the motor smells bad, it probably is. Another thing to check is the power leads coming off the ESC.
  • Rcfiddy1
    Nothing obstructing intake or cheater grate. Battery is fine. I reset throttle calibration and no different. My nose gear just seems to get stuck in up position randomly. I just cycled it a dozen times and worked every time.
  • Flanker271
    Besides checking for obstruction in the duct, was the battery in good shape? Has any settings been changed in the transmitter that could affect throttle calibration? Does the landing gear rotate freely?
