    Originally posted by RC30Flyer
    I may be a little OCD with my wiring... ;)
    You have too many wires there.... LOL
    mine...
  • Bobaroo
    :Scared:That drives me crazy! Ship that here and I'll tidy that right up for you...
    LOL !!! ... .. TooFunny !!
  • RC30Flyer
    Originally posted by Bobaroo
    Possibly !! Hahahaha
  • Bobaroo
  • RC30Flyer
    Pull on everything to make sure it is secure and check it frequently. Mine had a bit of minor gatoring in places..nothing significant to me. As far as the CG goes I run mine around 180mm from where the large base of the canon mount and the flat on the wing root meet. Early on the reference point to measure the CG from changed. The manual online measures it from the same point I reference but places it back at 195mm which to me did not feel right on mine. Elevator was very sensitive and I almost lost the plane on it's maiden. I have had two more since and they both do well at 180mm.
  • RC30Flyer
    Thanks RCJetdude, I did talk with a guy on their online chat about some gator skin on the tail cone and he seemed to sorta blow me off by saying that's normal according to the batches they receive. Kind of disappointed with that answer after spending over $1400 with them in my last order. And the way the rest of the jet was almost flawless, but it is what it is I guess... Do you think the landing gear will be fine, or should I stress test them a bit? Also, been seeing a lot about this jet having a huge range for CG, is the 185mm the standard that most are using? Thanks again!
    Just purchased the A-4... awesome looking jet, but am I the only one that thinks the QC on these freewing jets is seriously lacking? The fit and finish is excellent, however, every single piece of wood to foam was either not glued in or has one little dribble of glue. The fan assembly was bouncing around on the mounts, the battery tray was loosey goosey, and the ESC hold down wood strap wasn't even tight. I'm now concerned about the retract assemblies and how well they are attached. I'm a fair modeler, and don't mind reinforcing things, but for the price I think these items need to be better installed at the factory. I have a 90mm F-16 waiting in the wings for assembly. Hopefully that one will be better.
    Welcome to HobbySquawk! I recommend entering a ticket with Motion so they can be made aware of the issues. All three of mine have been fine.
  • RC30Flyer
    Is the foam CNC'd in the prototype?
  • Evoman
    Thanks Alpha! It was really interesting to read about the determining factors that led to finding the ideal scale size.
  • e4dragongunner
    Great insight Alpha! Thanks for sharing. Love my Scooter. Need a second, "JUST CUZ"
    Originally posted by Evoman
    I am curious to know the main reasons that it was decided best to scale up the A4? Just want to know the determining factors in RC development.
    After testing the 70mm prototype, our development team all agreed that the overall behavior wasn't what we wanted in a mass market Scooter. Upscaling to 80mm resolved our concerns in terms of :
    Performace: The 70mm was fast, but the wing loading was higher and landings were less forgiving. The 80mm sized airframe was still quick but landed much more slowly and stalled more gently.
    Proportions: The rotating undercarriage required a thick wing, which looked badly disproportionate on the 70's wing. Even then, the 70's wheels were too narrow. An 80mm sized wing allowed both thicker wheels and better model proportions overall.
    Price: Short grass capable rotating retracts required a new design and be part which means added cost. It's easier to offset that cost with a larger 80mm sized airframe. Controlling cost while balancing feature set is always a critical consideration.
    Precedence: The foam A-4s from Blitz and LX in years past were 50mm and 70mm, respectively. Our development team wanted to do something different, so we chose the larger undercarriage, larger 80mm EDF, larger overall size, and the modular magnetic avionics hump.
  • thmprusmc
    Alpha-
    Thanks for sharing, Great to see the prototype!
  • EA-6B Geek
    Super cool Alpha! Thanks for posting those photos.
  • Evoman
    Your scooter is looking magnificent, Thmprusmc! As a bit of a "blast from the past", here are some photos of our later stage A-4 prototype back in 2016. This is after we had upscaled it from the initial 70mm prototype. Even back then, we knew that split flaps were a must-have, even though they were plastic and expensive. From this CNC'd foam prototype to your customized production bird, all of us at Motion RC are very gratified to see these labors of love find loving homes and hangars.
ID:	183158Click image for larger version
ID:	183160Click image for larger version
  • thmprusmc
    Getting some more work done. Painted the under side of the spoilers, added detail to a wing and added Naca vents on the nose area.
    Originally posted by thmprusmc
    My latest project.
    TM, Beautiful Work! Welcome to 'The Squawk'. Best, LB
