    • Nov 2013
    • 2794
    • Cody, WY
    Thanks, guys. It was a bit turbulent yesterday, not too bad. That might have had something to do with it. I will recheck the CG, though and see if that helps. I, too, have had to "add to cart" too many times, and know that this bird doesn't like to fly too slow, especially at my altitude (5500 feet). I have the flaps set around 3-5 seconds time for retraction/extension, and have a takeoff and landing flap setting. I already had to "add to cart" once on landing when it stalled right about the time it touched down and it rolled and crunched a wing, although it stayed on its gear. That could have been a TOTAL "add to cart" had it been a couple of feet higher when it did that!
    • seaviper
      ATC retired
      • Aug 2016
      • 1092
      • Philadelphia Mississippi
      Yeah i did that on flight # 1. Had to replace the fuselage and some other things.
      • Ron1950
        Retired ATC
        • Oct 2015
        • 887
        • brandon ms
        I made a mistake and cut the white 300 decals for the navy version...be glad to trade the marine decal sheet for the 2 300 white decals for the flaps or the hole sheet of navy decals either way...thanks
        • seaviper
          ATC retired
          • Aug 2016
          • 1092
          Hey Ron, didn't know you had a scooter! I have some of the white 300 decals from the navy sheet. I do not have an entire sheet though. several small things are missing. But I have 4 of those white 300 decals. I can put them in the mail for you tomorrow if you want.
          • Ron1950
            Retired ATC
            • Oct 2015
            • 887
            • brandon ms
            thanks pat just need 2 of em be glad to trade ya the marine sheet if you want
            • seaviper
              ATC retired
              • Aug 2016
              • 1092
              decals away! no need to trade sir. hope you can use them.
              • Ron1950
                Retired ATC
                • Oct 2015
                • 887
                • brandon ms
                thanks pat hope weather gets better soon so we can fly some jets
                • Pheonix
                  • Aug 2013
                  • 670
                  I have plenty of decal for this plane that I will gladly give to anyone that wants them. Just let me know where to send them. I used Callie Graphics and have some spare originals.
                  • sfninerfan69
                    T-6B Egress Tech/ Retired USN Chief
                    • Jul 2016
                    • 22
                    • Navarre, Fl
                    Phoenix, i sent you a PM......Jim
                    • e4dragongunner
                      Living the dream!
                      • 876
                      • Arlington Heights Il.
                      My nose gear mod and few other goodies.
                      • DCORSAIR
                        • 1918
                        • Selma, Ca.
                        Hey gunner, did you glue the plastic collar to the strut? if not does it stay in place or is it loose and slides up and down the strut? I have all the parts from my F-14 to make one, wasn't sure how you mounted the plastic collar. Thanks
                        • e4dragongunner
                          Living the dream!
                          • 876
                          Hey man! The collar is not glued. it floats a bit, due to the length of the track it rides in. The track is not long enough to allow a fixed point on the strut. Also, hog out the collar a bit with a dermal barrel sander, as its too small to fit on the A-4 strut.
                          It slides up and down only when the gear is going up and , when going down. so only during the retract action. when the gear is in the down position it's secured enough to maintain its angle .
                          Then there is this bit of excellence.......
                          • DCORSAIR
                            • 1918
                            • Selma, Ca.
                            Thank you sir, will give it a try. :Cool:
                              Started the RNZAF paint job today. Have the bottom done in "Duck Egg Green" or WWII British sea green... It is coming along. The upper colors are Dark Green, Medium Green and European 1 Grey. Ordering graphics in the AM from Callie!
                              • e4dragongunner
                                Living the dream!
                                • 876
                                Must post pics!! when complete!
                                • seaviper
                                  ATC retired
                                  • Aug 2016
                                  • 1092
                                  Work in progress. She will be a VT-7 bird.
ID:	121395Click image for larger version
ID:	121394Click image for larger version
                                    That is going to look amazing when done.
                                      Here is the start of what seems to be a simple paint job!!! LOL Aren't they all????? :Confused: Click image for larger version
ID:	121439Click image for larger version
ID:	121440Click image for larger version
ID:	121441Click image for larger version
ID:	121454Click image for larger version
ID:	121455Click image for larger version
ID:	121456Click image for larger version
ID:	121457Click image for larger version
ID:	121458Click image for larger version
ID:	121459 Now with the Sea Green bottom. Not scale that I can find, but the "wrap-around" Low-Vis camo was just too dark for me. So a little artistic license and here we go!!! I think it will be "pretty". Always loved this color on the British WWII birds!! :spitfire
