1/10th Scale Westcraft B-17G Electric Conversion
  • F22trainer
    Piper PhD
    • Mar 2018
    • 1484
    • Sun City, Az
    Great project and following your progress. Nice work.
      Its gonna be awesome to see this one take to the skys.
        Thanks you all for the kind words! I did some work on the project this weekend. Nothing to post pictures of though... I ordered another 5 reference books from Amazon. Three of them just came in today. I started to find and sort all the pieces and parts that I removed when I stripped it down for sanding and priming. I have several tubs with all the parts in them. I also started to organize and cut the main extension wires for the motors. After I do a little cleaning of the work table, I plan on continuing all the soldering for the motors and the remaining ESC's... :pop:) Also, the other orders I placed will be here tomorrow. The 13x12 Master Airscrews are coming today!! So another test this evening, and then all the data that I gather will be posted here!
          Well, I read the tracking data incorrectly on the Master Airscrew props... They are coming tomorrow along with a bunch of other stuff!!! So, no new test data reports today.... :( But it is getting close to quitting time anyway!! :Drinks:
          • JFandL
            • Jun 2013
            • 402
            Can't wait to see what you end up with.
              The deliveries have started. Received the order from Horizon Hobby. www.horizonhobby.com. Found wheels there, that are close to scale and almost the right size. The 1/4" aircraft ply was in the order for the motor mounts and ESC mounts. 36 inch receiver extension. 24 inch telemetry extension for a temp sensor. Amazon sent the B-17G pilot's manual. Waiting on UPS for the Master Airscrew props, and then FedEx for the mini table saw... :):Cool:
                I sorted my Tamiya paints yesterday evening to see what I have. I think all of the XF (flat) colors are covered!!!
                • JFandL
                  • Jun 2013
                  • 402
                  Sure is a lot of paint:pop
                    Good times?:Cool::pop
                    • fieldofdreamsflyer
                      Banned
                      • Jan 2013
                      • 289
                        1/3 is a huge project!!! Good for him for finishing it!!! :Cool:
                        • JFandL
                          • Jun 2013
                          • 402
                          I can't even begin to feel his kind of pain 17 years!! Now Mr. Hardway get back to work sir!!!
                          :pop
                            :pop
                            Roger!!! Working on a martini now.... Oh wait.... LOL :Scared::Drinks: Just having fun!!! Blessings!!! Jerry BTW, FedEx finally brought my mini table saw. Glad I paid 28.00 for two day shipping and ordered before noon last Thursday...…..:Angry:
                              Well still less than a weeks time, but two day shipping took almost a week and theres no holiday to hold it back with either.:Confused:
                              • JFandL
                                • Jun 2013
                                • 402
                                Maybe I'll join you!!:wacky:Drinks:
                                  Cheers my Brother!!!! CHEERS!!!
                                  • JFandL
                                    • Jun 2013
                                    • 402
                                    Ok party is over, what ya doing? :pop
                                    Just making sure you hit that dead line you know. Love seeing her updated.
                                      Ran a few bench tests this morning with the new props! Looks good so far!!! Eflite Power 60. 470KV. Master Airscrew 13 x 12 3 Blade. Admiral 5000 mAh 6S 50C. EC5 connectors. 10AWG motor extension 24" long. Starting battery voltage 25.17 V. Running at 1/2 throttle. 44.9 amps / 1175 watts. Running at Full throttle. 64.8 amps / 1501 watts. Also, I moved the watt meter from the battery end to the motor end of the extension, and the readings were almost identical... I guess that is a good thing!!! :Confused::). Heat is nominal. The wires are barely warm. The motor is the hottest, but the ambient air temperature here is 98F now. Ran for 1 minute at 1/2 throttle, then a short break, then another minute at the same setting. The battery had 80 percent remaining...
                                        Now I am going to drill the 13 x 12 3 blade REVERSE pitch prop and install it. Then, do the same readings. Do you guys think there is any benefit to reversing the direction via the ESC programming or just switch the two motor leads??
                                        • RRHandy
                                          Instructor Pilot
                                          • 893
                                          • Lilburn GA
                                          Just easier to switch two and be done, then color code the ends to match the change. R.
                                          AMA 424553
