Official Black Horse 2385mm A6M Zero thread
  • Trady37
    Thank you Dennis!!
    last question ... would a UMS 7 cyl 90 work in the zero? It’s only about 230mm.
    tom
  • SirAbuse
    The Saito FG73 R5 fits great with a ring-muffer and has enough power for the Zero.
    Spinner an prob are a minimum to long but you can use this part to mount the Saito:
    Viele Grüße
    Dennis
  • mavdriver
    Subscribe
  • Trady37
    Hello)
    Just bought the BH Zero ... first huge and first gas project. I’m looking to put in the Saito 5 cyl/75 .. reason I bought the plane. I have heard that this set up has been done, but that the prop/spindle stick pretty far out. Does anyone know of this has been overcome? Can it be? .. otherwise, I’m looking at the Saito 90.
    Any help greatly appreciated))
    tom
  • 1stflightdave
    just push the buy button looking forward to this build
  • James
    bananaman Funny, I didn't check the manual for the CG. Just used the provided CG machine in the kit (I love that so much).
  • bananaman
    I still have the model at the published CG and have a small amount of elevator/flap compensation, 1.5mm at full flap and it lands very level, almost hand free. The amount will change with the CG position and how much flap deflection you have. I altered the flap linkages to get more flap throw on mine.
    James suggestion to check the input power lead is worthwhile. I recall resoldering mine to the plug as it looked a bit crappy.
    The landing gear strut springs are fairly stiff, I prefer that to being too soft, mine is a little heavier with the Saito90. I haven't done it yet but will be fitting a nylon spacer to preload the springs to stop the clattering the gears make when taxying.
  • James
    Originally posted by weiss.peter014@gmail.com
    I finished my Blackhorse Zero today. I made the settings for all functions like it is written in the manual. Have somebody an experience. The second question is the Flap settings.
    Is there a trim change necessary for half and full Flaps. Thanks for help Peter
    Hello weiss.peter014@gmail.com and welcome to Hobby Squawk. I didn't add any sort of flap to elevator mix in mine. She slows down really well, so at the speeds I have been dropping flaps I noticed no ballooning or anything.
  • weiss.peter014@gmail.com
  • James
    Originally posted by RMatteson
    Has any one had trouble with retract control box? I put power to box, plugged in a retract and hit test, nothing.. I tried both plugs and even hooked rx to it and tried retract sw on tx, got nothing. I want to also lighten spring on retract, as it seems way to stiff. Any help here?
    Thanks Rick
    Do you have pictures of the setup? I assume you have plugged things into the proper ports? Does the blue light come on when you power it? Obviously the box could be broken, but also maybe the wire that you plug the power into has a bad solder joint.
    Could be a number of things that might be fixable, share more info and some pics.
  • SirAbuse
    Hello Rick,
    in Europe we have the blue/red control box with no test button.
    This box has no problems perhaps you buy an new one?
    High risk to land without retract out.
    Viele Grüße
    Dennis
  • RMatteson
    Thanks Rick
  • Jeffrey schueck
    Im buying the Black Horse Models 93" giant scale zero, does anyone know how well a Zenoah G62 with a spring starter and pitts style muffler would fly it, and how well would it balance out and roughly the weight when finished. Also the P40 aswell the same questions .
    THANKS
  • Spinny Testaverde
    Check out some air to air footage with the Zero from last week
  • James
    Originally posted by radfordc
ID:	279337 This is really a great looking plane! I'm wishing now I had gone with this one instead of the Seagull Zero
    Thats still a nice looking zero though radfordc. But it is hard to beat the covering that black horse has on some of these warbirds. The riveting, rust, and paint chipping is truly stunning. A few guys at the club yesterday were shocked that I didn't add myself. They asked if I weathered it.
  • James
    Congrats James!
    The Black Horse birds, like this Zero and the Gilmore, are in a real "sweet spot" size for giant scale. The are big enough to fly great with a good presence, both on the ground and in the air. Yet, they are still fairly easy to handle and transport.
    I agree TJ. It's funny I only mentioned that to Alex yesterday. She's quick to disassemble and didn't really take up much more space in the car with the fuse on a plane stand and the wings straddling the fuse. She's heavier to manipulate when she's built up and loaded with batteries of course, but that's to be expected.
    Taking her out for more flying tomorrow! Will show it all on the live show Friday.
  • James
    Well done James. It's huge did u use or need a gyro. Good looking plane. Still waiting 4 a 1600 zero. To rumble with my corsair. Re what's next alpha
    I did not bother with a gyro for this one. Actually haven't used one in any balsa models yet. Just feel at their size they are way less violent with high rates etc that I never felt a need yet.
  • radfordc
    Congrats James!
    Go Big or Go Home! Bigger Flies Better! Hmm, what other cliche slogans can I add? Oh yeah, "Nice Job James!"
