Official Nexa 2108mm P-38 Lightning ARF Thread
    • 8228
    Sage words from OV10.
    • StanBr
      • Jan 2021
      • 29
      • The Netherlands
      OV10 Thank you very much for your wise words! You don’t want to end up in an unrecoverable stall due to a tail heavy aircraft. Thanks again!
      • StanBr
        • Jan 2021
        • 29
        • The Netherlands
        Bato79 Hi,
        Great videos! Where did you get the servo arms? Looks like a great solution! 👌🏻
        Best regards,
        Stan
        • Bato79
          • Mar 2021
          • 13
          Originally posted by StanBr
          Bato79 Hi,
          Best regards,
          Stan
          Thanks. The servo arms are from lanxiang / banana hobby B-25 model...I ordered it from banana hobby spare parts kit long time ago.
          • StanBr
            • Jan 2021
            • 29
            • The Netherlands
            Fantastic, thanks for your reply! 👍🏻
            • bartje
              The boss when the wife is not at home.
              • Jan 2021
              • 20
              • Pelt, Belgium
              StanBR, Bato79,
              Any flights to report already or flap mods? 😁
              • JonjonC@shaw.ca
                • Nov 2020
                • 3
                Question for those with successfull maidens under their belt. How much weight did you end up adding and could you share where you placed it?
                • GIRARD JEROME
                  • May 2021
                  • 5
ID:	314205Click image for larger version  Name:	IMG_1486.jpg Views:	3 Size:	137.2 KB ID:	314202
                  Hello
                  I am French and I own this model P38 VQ from 2004. It's badly damaged. As I'm used to building, this shouldn't be a problem. Question, do you have the editing instructions and/or plans. My Pdf is too small and therefore not readable. Thanks for your contribution and I would regularly post the reconstruction after completing my two-seat 1600mm construction spitfire personally.
                    • 8228
                    Welcome to Hobby Squawk GIRARD JEROME ! You can find the latest instructions for this model here:
                    Hope that helps and good luck!
                    • GIRARD JEROME
                      • May 2021
                      • 5
                      Thank you very much
                      • StanBr
                        • Jan 2021
                        • 29
                        • The Netherlands
                        Not yet!
                        I disconnected the flap servos for now and will do the maiden without flaps. The flap servos where getting quite hot... 😬
                        Originally posted by bartje
                        StanBR, Bato79,
                        • Flash Jorden
                          • 77
                          I plan on starting my build this month. What's the general consensus on the wattage output for each motor. Is 2000 watts overkill? I'm planning on running with 6S batteries, hoping to use some of the 6S batteries I already have.
                          Thanks in advance!
                          • StanBr
                            • Jan 2021
                            • 29
                            • The Netherlands
                            Hi Guys,
                            Finally had my maiden today. The P-38 needed quite some elevator to get airborne but flew rather well. It lacked some power with the 2 x 4S LiPo setup (15 x 10 props) but when you compress the nosewheel there is not much room left for a bigger prop. As saïd in my previous post I disconnected the flaps because of hot servos and the poor flap design. The landing gear is not very strong for a grass strip. On the first landing one of the main gears twisted a bit. Tried to fix it but on the second take off it happened again and the main gear got stuck inside the wheel well. The second landing was on two wheels. Only the prop was damaged. 😅 I.m.h.o. this aircraft needs a lot of TLC and improvements to make it a good and reliable flyer. Not what you expect when you look at the price...
                            Best regards,
                            Stan
                              • 8228
                              Glad your maiden was a success! She's in one piece (well mostly) which is all that matters. Oh yes, this model indeed requires plenty of TLC but once that is out of the way, she really is a nice flyer. I enjoyed all of my flights with her.
                              • Flash Jorden
                                • 77
                                Hey guys/gals, how did you connect the flap servos in the center wing? If done as described in the manual, it doesn't work, as when the servo arm moves from the vertical position, it pulls down on the crossbar. This seems like a major flaw to me. Any ideas on a better way?
                                • GIRARD JEROME
                                  • May 2021
                                  • 5
                                  HelloAros
                                  Some pictures of the progress of the restoration. Have a great weekClick image for larger version
                                  • GIRARD JEROME
                                    • May 2021
                                    • 5
                                    • GIRARD JEROME
                                      • May 2021
                                      • 5
                                        • 8228
                                        Nice! It's coming along! Thanks for the pics!
                                        • Txmustangflyer
                                          • Nov 2021
                                          • 11
                                          Any word from Motion when the lightning will be back in stock?
                                          Gonna put two rcgf 10 cc re stingers in, spoke with Glen there, He'll set them up for scale rotation. 1.9 hp at 12k rpm..potential for nearly 4 hp
