Originally posted by Starck Mad
View Post
That's where the fun comes in! And if there gear height is scale (and it looks like it is) there should still be about 1/2" of clearance when the tail is up. Can any one who has it (Tony or Alpha?) please measure the maximum prop size with the tail held level? Otherwise I'll just have to bring a tape measure to Oshkosh..
Have you flown her with the 4000's? If so how did it do? I was amazed at how good the Spitfire flies with the heavier packs.Originally posted by xplaneguy View PostAdmiral 4S 2500 all the way forward, 6 minute flight and still had 51% power left in the pack. No weight added.Big time propeller head
Love flying scale and 3D
Currently building a GP SE5A
The Spitty flies great with the 4000's...Originally posted by Grossman56 View PostWell, I'm not going out and spending more money on batteries since I have 3600's and 4000's sitting around already. Didn't the Flightline Spitfire take a 4000?
Grossman56Big time propeller head
Yes, both my daughter and I prefer flying the Bearcat with the Admiral 4S 4000 pack. The additional weight and 12+ minute flight time make a perfect combination. I fly the 2500 to demonstrate the slow speed and vertical performance of the model, which are impressive!Originally posted by Starck Mad View Post
That's great! The Spitty is no speed demon on the 4000 but she still has some vertical legs and slows nicely into a three point landing. Really looking forward to the Bearcat! Glad miss Evelyn is still loving hers!!Originally posted by xplaneguy View Post
SM (aka Adam Stang)Big time propeller head
I'll be very interested to see how you make out using that HSD Skyraider prop. I have that bird and the prop is very thick & heavy so you probably won't have to add any nose weight to the Bearcat for CG purposes. I expect that FL is using the same motor shaft as is on the Seafury(which I have)/Spitty so the hole in that HSD prop is going to require some seriously thick bushing. Look forward to seeing your mod thread on getting the more scale look to the front end on that F8F.Originally posted by F106DeltaDart View PostSaw this one at Oshkosh and it looks great! Decided to pre order it, and I already have an HSD Skyraider prop on the way. Also got to see the full scale flying, which was certainly an impressive sight.Warbird Charlie
