    Sam flying the upcoming Spitfire today alongside Xplaneguy's Freewing 70mm F-16 V2. Smooth flying, guys!
    Taking off...
    Click image for larger version  Name:	DSC08628.JPG Views:	1 Size:	76.8 KB ID:	65125
    Click image for larger version  Name:	DSC08650.JPG Views:	2 Size:	36.6 KB ID:	65128
    Click image for larger version  Name:	DSC08652.2.jpg Views:	2 Size:	36.5 KB ID:	65127
    Click image for larger version  Name:	DSC08673.2.jpg Views:	2 Size:	33.6 KB ID:	65126
    Landing...
      • 8211
      Great shots! I assume there was a luxurious head wind explaining sans flaps on the landing? ;)
      • xplaneguy
        Clear Skies and Contrails
        • 558
        • Edwards AFB/Rosamond, CA
        Thanks Alpha!
          Less than 3 mph headwind, Aros. This bird is so floaty it doesn't need flaps for takeoff or landing whatsoever.
          • Shirty
            Hobby Squawk Water Boy
            • 1067
            • Perth, Australia
            Nice pics :)
            • MesRcPilot
              Hobby Squawk -Spitfire pilot
              • 163
              • City of Split ,Croatia ,EU
              Hi Alpha , Impressive....... is there a possibility for the video?....if you don't mind :Cool:
                • 8211
                Niiiiiiice...
                  • 7337
                  Looks great Alpha! Now, is that the preproduction version that you painted yourself or is that a factory painted version?
                  I assume that it will be coming with no decals applied so we can custom paint it without peeling decals?
                  • xplaneguy
                    • 558
                    It is the preproduction version.
                      • 7337
                      Was it painted or white?
                      • xplaneguy
                        • 558
                        It was white foam which Alpha painted.
                        • borntoolate
                          Bomber Bob
                          • Mar 2013
                          • 424
                          • California
                          Very nice, guys! The Spitfire is very cool! Nice job, Sam!
                          Bob
                          Tony, the jet is nice too!
                            • 7337
                            Anyone run the numbers on converting this into a 4s plane. All the modder out there must be thinking that they might get more bang for their buck on 4s like the FMS T-bolt??
                            Anything??
                              Anything??
                              Kinda think that question is just a little premature at this moment Gman because we don't have it in hand nor do we have any firm specs other than it is designed to run on 6S and has a 16 inch prop.
                              At a minimum to start the power mod process the AUW needs to be known. We don't even know presently what the size of the motor that is designed for it.
                              I would be willing to bet that a 4S mod is out classed on this bird based on the 1600mm span.
                              It is probably using a newly designed FL motor sized in the 5060 class to turn that 16" prop.
                              Just waiting to hear from Alpha as the time approaches the further details on it's power setup.
                              Comparing the 1500 Razor to this Spitty is not a par relationship. ;)
                              • SamC
                                • 25
                                • Los Angeles, CA
                                Thanks so much for taking those photos Alpha - that was some fun formation flying! The Spitfire handled it nicely, even though the air had been a bit rough earlier, she took it gracefully. Flew great the whole time, no flaps necessary for any phase of flight in our weather conditions yesterday. Hope to be out there again soon and log some more formation hours with Xplaneguy!
                                  This bird really won't like 4s with that 16" prop. We originally flew a 17" prop in early prototypes, but the speed was just too slow for what I think most pilots would appreciate, and the scale factor was too much of a compromise on RC size performance expectations. The 16" is a nice balance between thrust, duration, scale+ performance, and scale appearance. But all that said, the new motor we spec'd for it is a 6s motor only in the 5060 ~385-395kv range.
                                  Also, to those asking about disassembly and transportation, here are some photos:
                                  The two wing halves and spar attach together with two machine screws, and I suspect most pilots will leave the wing assembled as one piece like this for transport. A blue circuit box is included to consolidate wiring for the channels and lights to just three outputs.
                                  Four machine screws attach the one piece wing to the fuselage, screwed into machined inserts for durability, reliability, and longevity. A fifth machine screw attaches the chin scoop.
                                  The propeller is easy to remove, just unscrew the nose tip screw to access the spinner backplate/blade assembly as shown. Another note about this new backplate design, is that whereas the older backplates used loose washers from the back of the spinner, this Spitfire's backplate has eight machined inserts molded into the rear of the plastic itself. This allows easy adjustment on the fly of the blade's tracking while the entire assembly is mounted on the motor. The inserts are machine screws, so loosening and tightening and loosening the screws is repeatable without worry of wearing out the threads.
                                    Dang I like that bird...send me 7 or 8 of them.
                                    • dkalwishky
                                      Warbird Lover
                                      • Sep 2015
                                      • 1382
                                      • Des Moines, IA
                                      Looking good Alpha, any thoughts on when the preorder might open up?
                                      I'm asking now because the first post says "Slated for production in late February, ETA is early April time frame" :)
                                      • Beeg
                                        • 1335
                                        • Texas
                                        With those prop a power assemblies maybe a deHavilland Hornet is in the works? ;)
                                          • 7337
                                          Some sweet plane on the way! Getting closer and closer to release day, so many planes so little $$
