  • Oxotnik
    Actung, Spitfire!
    • 931
    • Huntsville, AL
    Been out flying all day (but unfortunately, not my Spitty). My gear pull-out looks almost identical to Aros'. I've used Gorilla Glue in the past for plastic-to-foam repairs (I like Foam Tac for foam-to-foam).
    One note of caution when gluing the gear box back into the gear well- remove the motor/trunion before gluing the plastic housing back in place. On my F-86, I was making this repair and left the trunion in the plastic housing. Some glue then seeped in between the plastic housing and the motor/trunion box, bonding it to the plastic. When I later needed to remove the motor/trunion box, it wouldn't budge after I'd removed the fasteners. I finally had to drizzle some acetone onto the trunion housing, to soften up the glue enough to pry the trunion box free. Doh!
    Warbirder
      • 8211
      Well Oxotnik, I was a casualty of that. I went to cycle my gear and the one I epoxied was glued open and would not cycle. DOH!!! :Loser:
      So I spent the flight with the gear down/dirty to practice more landings. Not looking forward to trying to get it working again after my epoxy douche job. :Dizzy:
      • Shirty
        Hobby Squawk Water Boy
        • 1067
        • Perth, Australia
        Nice vid mate. Spitty looks awesome. :)
        • TonyGagJr
          • 36
          I wonder if the gear issue will be addressed on the next batch of Spitfires.
          • Oxotnik
            Actung, Spitfire!
            • 931
            • Huntsville, AL
            Aros, I think that you're in for trouble since you used epoxy. One another gear rebond, I had some GG expand into the motor/trunion box. It got into the gears. I had to pull the guts out and pick all of the glue out of the gear teeth. Once that had been completed, the motor/gears worked just fine. I'm afraid that with the epoxy, you may into a new motor/trunion unit. :Confused:
            Warbirder
            • Oxotnik
              Actung, Spitfire!
              • 931
              • Huntsville, AL
              Every foamy that I've bought has had a crappy bond of plastic to foam. Every gear box has pulled out of the gear well, often on easy landings even, such as what Aros had described. On my Spitty, I'd set it down a little hard, but it shouldn't have been hard enough to knock the gear out. On my F-86, second landing (and it was a good landing on a grass field), and the gear pulled out.
              Warbirder
                • 8211
                I think you're absolutely right. Should have listened to the advice on the Foam-Tac. Sigh.
                • Shirty
                  • 1067
                  • Perth, Australia
                  3rd week in a row.... :(
                  • Beeg
                    • 1335
                    • Texas
                    Just put a little piece of tape over the holes that lead into the main gear mechanism. Epoxy rules! :Cool:
                    • Beeg
                      • 1335
                      • Texas
                      Ah! Winter in Oz!
                        If your a gambler.....place your bet on the NO. Every manufacturer including FL has had issues with inadequate glue usage on the e-tract plastic pockets.
                        There are individuals doing the glue, not robotics applications so the quantity/spread consistency of gluing is a variable from one operator to the next.
                        I learned over the years that continuous turf duty will eventually weaken that sappy/rubbery glue they use and a retract will pullout........some sooner :Scared:and some later :Thinking: and some maybe never. :Whew:
                        As a matter of principle anymore I inject the translucent white ( 1 hour cure) Gorilla down into the sides of these foam pockets at the plastic edges.
                        The Gorilla will seep into the nooks and crannies of the foam and voids left by crappy glue application and firm everything with no more issues.
                        Here's the dispenser I use:;)
                        https://www.amazon.com/QTY-100-Dispe...ispensing+tips
                        These dispensers slip neatly on the tip of the Gorilla nozzle. I make sure it stays put with a little wrap of 1" wide masking tape on the tip/needle joint.
                        • Brandon Moon
                          Fly, Enjoy, Have fun!!!!
                          • Oct 2013
                          • 335
                          Click image for larger version  Name:	IMG_1337.JPG Views:	1 Size:	108.8 KB ID:	90264
                          Cool...send some of that my way...we need it
                          Brandon Moon
                          • downwindleg
                            • 1279
                            • Friday Harbor, Washington
                            Just got back from a flight cut short from one of the retract housings popping out on landing. Was a nice greaser, roll out looked fine and then suddenly it tipped on a wing. Something to look out for. I am going to epoxy the housing to make sure that doesn't happen again.
                            Damn, that's a bummer.........especially with a greaser! Hope your back in the air soon. Hey I've got a question regarding the yellow leading edge decals. It looks like they're split in half. Which side, top or bottom, gets the wider part and how much overlap should they have or just be butted? Brad
                            • Beeg
                              • 1335
                              • Texas
                              I lined up the bottom one (narrow) with the leading edge then just barely overlapped the top one to cover the edge.
                              • Flyer Phill
                                Roo's on the strip again!
                                • 82
                                • Brisbane, Australia
                                Started the build..
                                  • 2137
                                  • On planet earth....right
                                  Man, you weren't kidding about that rain LOL. Wow!
                                  • guylookingup
                                    Hobby Squawk Intermediate Pilot
                                    • Jun 2017
                                    • 17
                                    • St. Augustine, FL and Titusville, FL
                                    Hey guys,
                                    Is there anything I need to be aware of when applying the lettering decals to the Spitfire? The roundels applied very nicely to the aircraft but I am having a problem with the lettering (primarily the "A") adhering. I got up this morning and the "A" had dropped off during the night. I just ordered the same decal scheme from Callie Graphics (not sure if they are making the ones that come with the aircraft) to see if they adhere any better. I did wet the surface of the foam before applying any of the decals. I suppose I can add a light/diluted coating of aliphatic resin glue (e.g. titebond) to the letter and apply...but just wondering if I am doing something wrong. Thanks for any guidance!
                                      • 2137
                                      Originally posted by guylookingup
                                      Hey guys,
                                      I don't have this plane, so hopefully someone who does can clarify what types of decals it comes with for specific parts of the plane. If the "A" happened to be self-adhesive vinyl, and you used water to stick it to the surface, then that may be why it didn't stay adhered to the plane. The vinyl decals would be applied with no water, liquid, heat, etc., just simply pressed lightly onto the plane.
                                      • TwistedGrin
                                        Hobby Squawk..... CLEAR!!
                                        • 376
                                        Pilots, I maidened my FL Spit Mark IV yesterday +(9)...no issues and an excellent flyer even in 10-15mph cross winds!!! Back at the hangar during pre-rack storage inspections I noticed both rudder and elevator control rods were possibly hitting the electrical connector junction box .......suggest snipping off the excess control rods when you get a chance!!
                                        TwistedGrin
                                        • franky
                                          • 56
                                          Sad to read the pilots lose their landing gears. Because the wings are 2 halves, the manufacturer can put a piece of plastic (square eg. 3 inch.) between the 2 halves and with 2 or 3 screws attach the
                                          outside plate of the gear. to the inner plate. I have done did before with the same kind of wing and gears. It will hold the landings.
                                          Because the wings are now glued-in (the 2 halves), i don't want to pull them from each other to do this procedure. I'm intending to inject with a needle ultra thin foam safe CA under the plate.
                                          Hoping this will give some strenght.
