    Originally posted by paladin
    Either would have worked. Joe
    Welcome to the Squawk Joe. Good to have another Aeros member here:Cool:. tj
    • franky
      • 56
      Thank you XVIPER2 for the advice concerning the failsafe.
      Today i had some time to instal and test the elctronics. I have some delay of 3 sec. with the landing gears, does somebody notice this also? and the upper white light don't flash , it stays steady. Will this flash when i'm connecting all the wires to the blue box?
      • Flyer Phill
        Roo's on the strip again!
        • 82
        • Brisbane, Australia
        Hey Flyer Phil, did those prop decals come with the plane ? I haven't seen them yet. Or did you print them up yourself? Brad
        I ordered the Spitfire 1/7 scale nomenclature from Callie Graphics...
        Custom Graphics for your R/C Models! Choose from stock sets or request a quote for a custom scheme.
        • Dewey H Lee
          WARBIRD JUNKIE
          • Apr 2015
          • 919
          • Fayetteville NC. US
          Hey franky i havnt hooked mine ip yet but if you ho to Captain Rayns build video he states that all the wires have to be pluged in before they work.Maybe in your case you need to trya different port.
          Dewey l
          • Dewey H Lee
            WARBIRD JUNKIE
            • Apr 2015
            • 919
            Boy my phone is acting up. What i type and it post is different. Hope you could make out what came up Franky. Sorry:Confused:
            Dewey l
            • Pogo
              • 452
              • Waterford, Ontario, Canada
              Here's a vid of my maiden of the Spitfire this last Saturday. Had to make the landing without flaps due to a way wrong mix with elevator. Started with 5% down and it looks like it's going to be 15% up before it's over. I can't post the link from my work computer but if you go to BP's Spitfire on youtube, it will come up. Maybe someone else can post the link after watching it. My friend Carlos did the video on his cell phone and added the music, Brad
              Beautiful first flight Brad- well done! :Cool:
              Tom
                • 8764
                If you look at the demo video, you will see that the gear has a delay of ~3 seconds. That's normal. Certain things on these planes (like servos and lights) get their power from that control box. The control box gets its power from the RX. Depending on how the control box is wired, stuff is powered from different leads coming from the RX. Lights coming on and flashing is done in the control box. If you are testing the lights with outside power or testing when not all of the connections are made, things may not work as they should. I also caution you about testing stuff like lights from outside power sources (like a servo tester or a receiver pack). This method can fry LEDs very easily as they aren't being provided with the correct amount of voltage.
                  • 2137
                  • On planet earth....right
                  Yep! Agreed. The LED's are supposedly (from the directions I've had) are for voltages between 3.5-4.5. People could be testing these out with the typical 4.8V-6V and burning the lights out.
                  • Shirty
                    Hobby Squawk Water Boy
                    • 1067
                    • Perth, Australia
                    Pretty cool phil, I'm guessing mine are in the mail? ;)
                    • downwindleg
                      • 1279
                      • Friday Harbor, Washington
                      Tom
                      Thanks Tom, coming from you, that means allot...thanks to Aros as well, might be the first takeoff, flight, and landing that worked out O.K. knowing there was a video camera on. Have to admit there was a bounce and go and landing abort that wound up on "the cutting room floor":Loser: Brad
                      • downwindleg
                        • 1279
                        https://callie-graphics.com/collecti...e-nomenclature
                        Thanks for the info, Brad BTW,a little surprised that the prop decals weren't included like the P-38 and others.....greatly prefer the water transfers so you can move them exactly where you want.
                        • franky
                          • 56
                          Thank you Dewey, No problem with your typing :Cool: I saw the video of Ryan and i will hooke all the wires before power it up, thats could be the problem.
                          • franky
                            • 56
                            Thank you, clear explanation, i'm keep learning here.
                            • aring32
                              • 9
                              Hey all, i'm thinking about making the finish of the plane have more of a slight shine to it, like this spitfire instead of dull foam. The product i'm thinking of using is Minwax Polycrylic waterbased clear Matte.
                              • Oxotnik
                                Actung, Spitfire!
                                • 931
                                • Huntsville, AL
                                I'd suggest the UV resistant Polycrylic
                                Warbirder
                                • radfordc
                                  • 375
                                  • Lansing, KS
                                  I think I'm going to try this spray: https://www.hobbysquawk.com/forum/rc...-acrylic-spray
                                  • paladin
                                    model customizer since 1968
                                    • 243
                                    thanks Tony
                                    good 2 b here
                                    • radfordc
                                      • 375
                                      • Lansing, KS
                                      Got my Spit in the mail today. I've got it mostly assembled and started putting on the markings. Waiting for batteries to arrive.
                                      • Beeg
                                        • 1335
                                        • Texas
                                        Welcome to Hobby Squawk Radfordc. Hope it all goes smoothly! :Cool:
                                        • Wesnc
                                          • 52
                                          • Orange NSW Australia
                                          Grey Nurse is progressing well, the finishing on this model is exceptional, beautiful hinging! Thanks again Flightlinerc!!!!
