  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    Thanks guys for posting about the prop, blades, nut and hub. I'll be really mindful of all of this tonight while assembling mine.
      • 8211
      Putting mine together on my lunch break and I had no trouble binding initially...Just throttle/Elev/Rudder to get those centered. Then I hooked up the blue box and then my RX and now all I get is the dreaded single beep out of the ESC. Usually it's from not initializing the ESC but I tried that and it still won't work. I've messed with the throttle trim in both directions, insured all the servo leads are in their proper ports with proper polarity, moved my radio far enough away, re-bound (didn't work this time)...Running out of ideas. Anyone?
      And yes, thank you all for posting about the prop hub assembly. I will be going over each piece very carefully.
      • Beeg
        • 1335
        • Texas
        I usually only get the single beep when I leave the bind plug in. I had issues initially with the blue box but then "Y" everything accept the lights and it all worked. Then one at a time moved the flaps. then the gear back to the box. I left the ailerons on a Y.
          • 8211
          Hmm, interesting...I wonder why there's issues with the blue box? We will have to look at that asap...Thanks for info!
          • Oxotnik
            Actung, Spitfire!
            • 931
            • Huntsville, AL
            No problems with my blue box nor prop assembly. Prop is balanced. Now, just waiting for Saturday. The wait is killing me.
            Warbirder
            • Dewey H Lee
              WARBIRD JUNKIE
              • Apr 2015
              • 919
              • Fayetteville NC. US
              Might i suggest that everyone test fit everything while going through the process of putting the assembly together for the prop. Test fit the backing disk before installing the blades and the metal cross. Then if the backing plate fits okay add cross tempararly and the the blades. I remember in somewhere i think the little pictures that Ryan posted one of the captions mention haveing to use a drill bit to help line something up with the cross brace during assy of the prop assy. Hey Ryan can you chime in on that for us please. This might be causeing an alignment problem resulting in the problem people are haveing. Im getting ready to go throught this process now as soon as i finish this. If i run into anything that might help ill post asap.:Confused:
              Dewey l
              • RRHandy
                Instructor Pilot
                • 892
                • Lilburn GA
                Ok folks, this is how I fixed the prop nut issue for I could only get it on about three thread before I got resistance and I stopped and untreaded it, looking at the threads on the adapter i could see like a nice in the fourth thread and I took a pointed round jewelers file and hit the nick then put the nut on, no good so I went from the first thread closest to the motor and started to file the thread lightly as I counter rotated the motor all the way to the end. I then blew the filings and put the nut on and there was no more binding. You have to remember that aluminum gulls very easy so if you feel tension go no more. Hope this helps . R.
                AMA 424553
                • ryramZ
                  Pilot Ryan
                  • Dec 2012
                  • 814
                  It wasn't me. I had no trouble with mine. If I had trouble I would have oversized the bolt holes by drilling them out. My back plate was snug and sat down and seated fully after tightening down the barrel nut.
                  Test fitting as Dewey mentions is a good idea.
                  • ryramZ
                    Pilot Ryan
                    • Dec 2012
                    • 814
                    Hows your esc to motor connections?
                    • bruceW
                      • 11
                      Just showed a pic of this bird with Private Ryan holding it on the Motion RC website to my Wifey....she said OH NICE......and then scrolled over to the pic with the young lady holding that beauty.......Oh my god ..you don't have room for that.............damn-it....grumble-grumble.
                      • ryramZ
                        Pilot Ryan
                        • Dec 2012
                        • 814
                        Sure I do honey the wing comes off for storage.
                          • 8211
                          That's what I like about ya Ryan, always thinking... ;)
                          I took the battery tray off and inspected and the connections are rock solid. I was able to get the ESC to initialize to finish it up but when I plugged her in again a few minutes ago back to the single beeping. I am at a loss. LEDs come on but that's it. So much for a maiden this evening.
                          :Angry:
                          • ryramZ
                            Pilot Ryan
                            • Dec 2012
                            • 814
                            :Angry:
                            Check your email. Call me.
                            • Plastic_Aviator
                              Pilot Anthony
                              • 108
                              • Brea, CA
                              Yes! Just got my Spitfires. I wish I could build tonight but the wife is taking up my entire evening again...
                              Really hope I got a smooth build ahead of me. :)
                              • bruceW
                                • 11
                                546 dollaros Canadian shipped to B.C. Canada...no way.
                                • Dewey H Lee
                                  WARBIRD JUNKIE
                                  • Apr 2015
                                  • 919
                                  As i was prefitting everything together i to ran into the same situation as Beeg. Using the nut to try to force the backing plate at this point is a disaster waiting to happen. As RRHandy mentioned both shaft and nut are aluminum and can be gaulled very easy. So instead of trying to force the issue i kept pulling the backing plate off and reseating it at different locations until i got the best results. It was still not all the way seated but almost. I then took a sharp razor blade and lightly scraped the inside of the hub until it seated so that there was no excess pressure while trying to tighten my nut. I hope this helps. I was a machinest for 22 years so please take heed and be very carful tightening this prop nut. There seems to be a little more slop in the treads than i have noticed on other prop nuts that only compounds the chance for gaulling. If when tightening and it feels like a little slip at the end your close to being to far. Just take your time and be careful and you will get it on without haveing to force it with the nut.
                                  Dewey l
                                  • Dewey H Lee
                                    WARBIRD JUNKIE
                                    • Apr 2015
                                    • 919
                                    Ryan im sorry i thought that was you. Please accept my apologies. I cant remember where but there was some mention of an alignment issue. I think it might have beem on the one from xtrem hobbies on this plane.
                                    Dewey l
                                      :Angry:
                                      Have you tried calibrating the ESC?
                                        • 8211
                                        Yeah that was the first thing I tried. Wouldn't even allow it. Just single beeps no matter what I do.
                                          Unhook the box...
