Official Flightline RC 1300mm Focke-Wulf TA-152H Thread
  • Johnboy384
    • Jun 2026
    • 13
    • New Zealand
    Spinner decal works fine, My Hobby or Tamiya or Micro Set and Micro Sol work fine, just take your time, when it was finished I gave it a satin coat out of a Tamiya rattle can, One litte chip on the spiral due to impatience, Took a few ours of laying it, setting it and then a half dozen coats of Mr. Mark Setter.
    Put a coat on, walk away, come back on 30mins dub it dry and recoat then repeat till you're happy. Click image for larger version
ID:	450305 Click image for larger version
    • Johnboy384
      • Jun 2026
      • 13
      • New Zealand
      Having a retract failure. Triple checked connections and even tried a second receiver and a servo tester.
      No luck at all.
      Would this be a 'blue box failure'?​
      Tried two receivers, two transmitters.
      Only way I can run the gear is to bypass the blue box.
      Can anyone help?
      Thanks in advance, John.
      • vrosi1963
        Hobby Squawk Pilot
        • Aug 2016
        • 76
        • Califorina
        I wounder if it is possible to turn the ta-152 into a D9 considering the d0 was derived for the 190 A center section
