    Motion RC is pleased to announce the release of the FMS 1400mm P-51D V8. This is the official message thread to post photos, videos, flight reviews and any questions about this iconic aircraft.
  • olwarbirds
    • Nov 2015
    • 139
    • NC
    I am going to attempt getting all the upgrades and fixes on one thread. All inputs will be very welcome. I am doing this to make it easier for all..... DJ
    [hr]
    Links and sources:
    [hr]
    Motors: Popular 4S http://www.motionrc.com/fms-4250-kv580-motor/ nothing xtra needed... http://www.motionrc.com/fms-p-40b-wa...ss-4258-kv650/ http://www.motionrc.com/fms-p-40b-wa...m-motor-mount/ this is a new setup and from what I am understanding you need to use this prop shaft/adapter to get the stock spinner spacing from cowl closer http://www.motionrc.com/fms-1400mm-f3a-propeller-shaft/ http://www.motionrc.com/ztw-mantis-8...-with-5a-sbec/
    5-6S http://www.motionrc.com/fms-4258-550kv-brushless-motor/ http://www.motionrc.com/fms-1400mm-f3a-motor-mount/
    Esc's: 5-6S will need a 100amp http://www.motionrc.com/castle-creat...-with-5a-sbec/ nice if you want data logging, this also nice to have if your using a castle esc http://www.motionrc.com/castle-link-...ogramming-kit/ http://www.motionrc.com/ztw-gecko-12...specifications http://www.motionrc.com/ztw-lcd-esc-programming-card/ http://www.hobby-wing.com/platinum-100a-v3-esc.html
    Bec's: http://www.motionrc.com/ztw-10a-bec-ubec/ I have been using these for awhile and have had no problems. http://www.motionrc.com/castle-creations-10a-bec/ This is a nice xtra, saves removing wire on esc http://www.motionrc.com/150mm-bec-eliminator-cable/
    [hr]
    Retracts: http://smallpartscnc.com/index.php?r...product_id=193 you will need 2 sets
    Struts: http://pw-rc.com/index.php?route=pro...product_id=159
    [hr]
    Props: Ramoser Varioprop 12C https://www.jb-hobbies.com/presta/pr...-rotation.html or direct http://www.ramoser.de/home_e/variopr...rioprop_e.html will add all the necessary parts once I am sure they are correct
    Prop adapters: http://smallpartscnc.com/index.php?r...product_id=161 This is for 4250 motors, no hex so you can use other props.
    Sound systems: http://www.diamondhobby.com/electron.../sense-ess-air http://www.motionrc.com/complete-sound-systems/
    Lights:
    Coatings: Varathane spar urethane outdoor with uv protectant (waterbased) minwax (WBPU)
    FMS: PT-17, Waco, B-25, P-40, P-47, J-3
    DF: P-51D, Spitfire, geebee, Skyraider
    Dynam: Grand Cruiser, A-10
    J-pwr P-38, FZ Beaver + too many more
    • olwarbirds
      • Nov 2015
      • 139
      • NC
      RE: ALL FMS 1450mm P-51's V8 +
      Lipos:http://www.motionrc.com/admiral-4000...-lipo-battery/ http://www.motionrc.com/admiral-pro-...tery-with-ec5/
      [hr]
      Pre-Flight checks: c clips on wheels, Cycle LG a couple times, check screws main wings and tail
      Maintenance: Clean and threadlock grub/set screws in LG, loctite 425 is safe for metal to plastic, dont use the red loctite. Clean tail retract housing and lubricate links, check grub screw, prop screws.
      [hr]
      Mods: Prop zip tie mod to change pitch. When doing this mod you will need to change the screws holding the prop blades, these work well http://rtlfasteners.com/RC/cm3020.html I would suggest getting some of these even if your not doing the mod, since the stock screws are phillips head and are soft and a bit short.
      • Brandon Moon
        Fly, Enjoy, Have fun!!!!
        • Oct 2013
        • 335
        Looks to be super...I'm going to start moving my stuff over from RCG to here, going to take a while though...lol
        Brandon Moon
        • olwarbirds
          • Nov 2015
          • 139
          • NC
          Hey Brandon, glad to see you joining in. I can relate on taking awhile, there is a load of info to get together. Look forward to all the pics etc being added. A lot of the others will be joining in soon too. I have no doubts it will eventually be very active on here :) .... DJ
            Hello Brandon and olwarbirds,
            Just wanted to welcome you over from RCG. I welcomed jiggz and wrongroad earlier over on this thread.
            http://www.hobbysquawk.com/Thread-Dynam-Tiger-Moth--1850?pid=15764#pid15764
            Same goes for you two about watching your threads over there on RCG and look forward to your contributions here.
            Best regards,
            • fhhuber
              • Aug 2015
              • 1476
              pw-rc.com/index.php?route=product/product&path=62&product_id=159
              Upgrade wheels/struts
              • olwarbirds
                • Nov 2015
                • 139
                • NC
                Best regards,
                Tks, I have invited a whole group of great modellers to join us here.
                [hr]
                Tks, I have added that to the links ...I am looking for alot more posts like yours.... DJ
                  • 8834
                  My 6s modded FMS 1450mm P-51 is still going strong. I've got the Olympus motor and prop, with a 130A ESC. I'll be going back to my stock 4-blade prop in the spring.
                  PS. I'm another refugee from RC Groups. Those mods have a terrible problem of God complex. Besides, all the new models reveals happen here first anyway.
                  • olwarbirds
                    • Nov 2015
                    • 139
                    • NC
                    Glad you joined us. When you have time, pls post pics of your upgrade...tks... DJ
                      Welcome to the Squawk xviper,
                      Your on the money about the reveals happening here first.
                      The P-38 announcement got over to RCG FMS Giant Warbirds thread by me via post#7787   http://www.rcgroups.com/forums/showt...P+40B&page=520    around the same time peterswolf opened up the P-38 thread   http://www.rcgroups.com/forums/showthread.php?t=2580046
                      Look forward to following your posts here and hope that Shirty follows you guys over.
                      Best regards,
                      • jiggz
                        • 25
                        Hey all good to see some familiar members here..
                        Here's my 51 .. sorry not a v8 .. but my pride..converted to polish RAF mustang iii ' wing Comdr .Jan Zumbach'
                        4250 580kv ..stock ESC ..no prop mod ..
                        Art.t p51.1400 p51b.1400 fw190.1400 f6f.dyn tiggy.dyn spit.dyn tempest.dyn at6 (harvard).dyn beaver.eflite yak54.df vamp.pz spit.pz bf109.pz fw190.pz mossi.pz se5.pz radian.pz visionaire.hch b25.pz p40.ne yak54.ne extra300.precedent highboy.fms 800 p40 .. Tony nijhuis tiffy
                          • 7430
                          Ahh, one of my favorite topics!
                          My P51B is stock except for the paint job.* I have ball links ready to go into her, but for now, she'll stay that way.* Actually the only mod I've done to her, to both Mustangs in fact, was to change out the plastic sides of the retract servos to all metal pieces through CNP Small Parts
                          **http://smallpartscnc.com/index.php?r...product_id=193
                          If you haven't already got these, they are worth their weight in gold!!
                          To my P51D, I've gone with the upgraded 580kv motor with a Mantis 85a ESC, changed all the links to ball links and*modified the cockpit to look more realistic and changed out the pilot
                          She's quite the sight to see fly.
                          Oh, if you're wondering, about 4 or 5 coats of Minwax. Varathane is a better way to go though.
                          • olwarbirds
                            • Nov 2015
                            • 139
                            • NC
                            jiggz, welcome and no sorry necessary. Thats a beautiful MkIII. I until recently did not know about the Malcom hood.
                            Grossman56, glad you joined us and I'm jealous ! You have both the Stangs I am wanting. They look great. I have been doing the Minwax for many years, but have never done the varathane. Whats better about the Varathane ?
                            • RCWASP
                              • 4
                              Great thread Olwarbirds! I have the P-40 motor coming for my P-51B DD (which is still a work in progress) and looking forward to testing it out!
                              Good to see you boys here! Let's hope Shirty signs up soon too. ;)
                              [hr]
                              Valathane sounds very similar to Carbothane which is what I use. I've heard Minwax can yellow slightly with age? (which it says it doesn't).
                              Learning to fly........FAST!!
                              • Shirty
                                Hobby Squawk Water Boy
                                • 1067
                                • Perth, Australia
                                RE: ALL FMS 1450mm P-51's V8 + others
                                Hello everyone, just joined the new forum from RCG also.
                                Firstly,
                                My name is shirty. I am a trouble maker and I like bikinis. ;)
                                • RCWASP
                                  • 4
                                  Firstly,
                                  Yay, SHIRTY! SHIRTY! SHIRTY!! Awesome to see you here mate! :)
                                  You are slowly becoming a folk legend over at RCG's! lol!
                                  • olwarbirds
                                    • Nov 2015
                                    • 139
                                    • NC
                                    Firstly,
                                    LOL ... Shirty really glad to see you here brother, this thread is all your trouble making fault :)
                                    [hr]
                                    Firstly,
                                    Good to see you both here, both of yours inputs are very valued here noseart and all ...lol.... DJ
                                      Firstly,
                                      Shirty, WELCOME to the Squawk and we LUV bikinis too!!
                                      Good to see a bunch of your buds have already migrated here too.
                                      I was mostly in the shadows over there on RCG but I did see what happened.
                                      Glad to have you!
                                      Best regards,
                                      • olwarbirds
                                        • Nov 2015
                                        • 139
                                        • NC
                                        I need some pics of how to do the zip tie mod pls and any other mods too...tks... DJ
