Discussion: Heng Long's 1/16 scale M1A2 Abrams RTR, Upgrade Edition!
  • Rubicon99
    • 3311
    Originally posted by Woohoo\o/
    I was wondering. How accurate would you say the paint color is on the HL Abrams? I see it to look a bit darker than it's true life counterpart.
    It’s actually not too far off. The weathering HL adds makes it look a little on the dark shade side.
    • Woohoo\o/
      • Feb 2020
      • 186
      • Cape coral Florida
      Yeah that's what I don't like to be honest. I may just do her over before applying decals.
      • Rubicon99
        • 3311
        I repaint all of mine. Best way to get exact what I want it to look like.
        • Woohoo\o/
          • Feb 2020
          • 186
          Are people really making subwoofers for the speaker? Does it really make a difference in bass etc?
          • Rubicon99
            • 3311
            Yes people make their own speaker boxes, usually this is seen more in full ground up custom built tanks. Does it help? Depends what value one places on sound clarity.
            • Woohoo\o/
              • Feb 2020
              • 186
              Because from what I remember from my first Abrams the sound wasn't really impressive. Felt like it needed more bass (lows). I'll be researching more about upgrades.
              • Narly
                • 52
                • Wunderful Wyoming
                Will MotionRC be importing the 2020 Premium M1A2 ????
                • Rubicon99
                  • 3311
                  The sound quality of the 6.0 tanks is vastly improved over the older 5.3 tanks. Sill not as good a Tamiya tanks but not to far off.
                    Narly Do you mean the "Pro Plus" that I've been helping Heng Long develop, and that's covered in my thread here?
                    https://www.hobbysquawk.com/forum/rc...brams-pro-plus
                    • Narly
                      • 52
                      • Wunderful Wyoming
                      YAH, that's the one & I want one!! after seeing the 3 youtube vids calling it the "2020 M1A2 Premium version" .... ....
                        Narly We're still working on the final configuration, including final title. There are a couple iterations of the prototype floating out there so far --mine has barrel flash and barrel LED, whereas one or two have barrel airsoft. There are still other changes being made behind the scenes, with an unfortunate delay due to the ongoing Coronavirus outbreak. When they're ready, we'll make a formal announcement, likely in the summer or so. In the meantime, post in that thread any questions you might have for it.
                        • Imladris18
                          • 21
                          Does anyone know if it's possible to swap the functions of the sticks? I see there is a way to have the throttle on the left and steering on the right, but I am essentially looking to have the stock setup, but switched: with the throttle/steering on the left and the turret/gun on the right.
                          • Rubicon99
                            • 3311
                            The sticks are set there is no way to swap them around.
                            • Imladris18
                              • 21
                              Okay, I kinda had a feeling that would be the case. It's not a huge deal, but for some reason it doesn't feel natural to me the way it is.
                              Thanks!
                              • Davy101
                                • 68
                                • East KS, USA
                                I've found press and holdng the G button while pulling the left stick down moves the throttle (forward/back) motion to the left stick. Rudder (right left) stays on the right stick. No way I've found to move that. Having the steering split from the throttle doesn't interest me however.
                                • Woohoo\o/
                                  • Feb 2020
                                  • 186
                                  What's the stock gear ratio on the abrams?
                                  • Rubicon99
                                    • 3311
                                    It’s either 33:1 or is it 29:1. Been a while since I counted them and did the math.
                                    • Woohoo\o/
                                      • Feb 2020
                                      • 186
                                      I'm receiving mine from motion tomorrow. I will have a look.
                                      also, does the upgrade version come with axle support bearings? If not, what size bearings do I need? I saw some shaft support bearings being sold but are sold out everywhere. The only ones available cost a ton. Can I just use some flange bearings?
                                      • Rubicon99
                                        • 3311
                                        It does not come with the bearings. I will have to check on the size when I get home. Yes you can use flange bearing too.
                                        • Woohoo\o/
                                          • Feb 2020
                                          • 186
                                          O7 thank you.
