Modular, readily available IR target that I cooked up. It is compatible across all board types, including but not limited to Tamiya, Taigen, IBU, OpenPanzer, and HengLong. Can be powered through any battery that is 3V - 5.5V.
This allows a wide range of batteries to be used, including but not limited to: 1S (3.7V) LiPo, 1S 18650 Li-ion, CR2032/2016 coin cell, 3AA, 3NiMH.
Depending on your application and size needed, you can choose the battery pack and capacity to fit.
Available now at https://www.etsy.com/shop/LegoDEI.
Shown here it is connected to a 3.7V 1000mah LiPo battery. The module itself measures only 1.5" x 1.5", or 40cm x 40cm.
Multiple units can be strung together, either next to each other or with long jumper wires, allowing a whole string of them to use one power source.
Shown here we use short two pin header jumpers to create an array.
