Hiya, AB. The Pershings are few and far between. They probably shouldn't be the first tank to build up - mine I had to cobble together from many sources. A static tank from Toucan, a Multi Function Board and a speaker from a buddy, IR bulb and receiver from sellers, decals and stores from other sellers, and quite a few other details. But they are cool looking!
Each tank will be different, but here's the way I added the IR receiver to the M26:
The way it comes, with the commander.
A hole drilled in the well, wires routed from the MFB, plugged into the IR Rx.
The Rx, with the PVC pipe segment, fits into the well. I don't glue it, so I can remove and use it in another tank
