M26 Pershing
your right just bought a tiger lolAs keilau said, it's an early Heng Long brand M26 Pershing. HL called it a Snow Leopard, hence the decal. You'll need a HL transmitter and main board. A new HL version 7.0 setup can cost $80 to $100 in the US. HL version 6.0 setup can cost $60 or so, but they're getting scarce. You then will need to do your own wiring. You can find schematics online, or if you buy a new setup there'll be an instruction sheet with it. The board includes the receiver, and will control the two movement motors, the rotation and elevation motors in the turret and if your tank is a pellet shooting version, the airsoft gun. A piece of advice, don't buy anything earlier, such as 5.3 version or RX18 I think it's called. They're much cruder and you wouldn't be happy.
I recommend you buy the bare minimum components for now. No need for metal upgrade tracks or aftermarket gearboxes until you know what you already have works. The plastic gears can become brittle, the motors could have burned out, and even the body itself may have degraded and could break under use. Also, before you start spending money to renovate this tank, compare the costs involved with the price of a new one. You may find that a renovation isn't cost effective. It appears that some of the external details like a hatch and stowage bins missing.
Now, if you're intent on making this a "scrounge project", you can always look for used stuff online. I'm guessing based on your post you're in the UK. A UK forum called "RC Tank Warfare" would have good local resources for your project. However, they're often focused on "rivet counting" scale accuracy, so you may encounter some condescending responses.
If you persevere, the Pershing can make up into a real gem. Just be warned, tanks are like potato chips, you can't ever have just one! However you proceed, good luck.
It is strongly recommended that you get a good electrical schematic of your current Pershing wiring before you start. Heng Long do a very good job making their tank backward compatible. I upgraded from a 2005 Snow Leopard with discrete receiver board to RX-18 27MHz MB to v5.3 2.4GHz to V6.0S 2.4GHz without losing any turret function and greatly improve the driving quality. The V6.0S MB is cheap and has very good proportional speed control. I see no reason to go with the more expensive 7.0/7.1.
Heng Long use M3 self tapping crews for gearbox mounting. My Pershing was purchased in 2005, After 18 years, 2 of the mounting posts crack making it impossible to tighten the screws. The gearbox came loose and causing the track to wobble. I drilled through the bottom of the post and tap the inside for M3 machine thread. I mounted the gearbox with 6 pair of nut and bolts. There is no question that the posts are still stronge enough to hold the gearbox. The nut and bolt set make it very stable.
I cannot blame HL for the post cracking problem. Over the years, I went through the HL original plastic gear, Tamboy (German store) cast metal gear, Heng Xin steel gear and the Torro steel gear. I am happy that the HL chassis holds up as well as it does.Comment
i hope you mean me. im putting in a 7.1 version board got all the connectors plan thank youIt is strongly recommended that you get a good electrical schematic of your current Pershing wiring before you start. Heng Long do a very good job making their tank backward compatible. I upgraded from a 2005 Snow Leopard with discrete receiver board to RX-18 27MHz MB to v5.3 2.4GHz to V6.0S 2.4GHz without losing any turret function and greatly improve the driving quality. The V6.0S MB is cheap and has very good proportional speed control. I see no reason to go with the more expensive 7.0/7.1.
My latest upgrade on the historic 2005 HL Pershing is the HL metal barrel recoil BB shooting unit.
A few days ago, I posted on a Heng Long Metal Barrel Recoil BB shooting unit for 3838 Pershing upgrade kit that I purchased for my 2005 Snow Leopard. I said that over 18 years, HL changed the cannon mantle mounting plate enough that the kit does not fit my Pershing. I contact the Toucan seller (build-for-u) to request a return. They got back to me in a few days after talking to the HL technical team. They came up with the idea of swapping the old mounting plate to the new unit. It works, but it is not a simple direct drop-in replacement. It took me 2 days of careful griding and cutting. .
The Metal Barrel Recoil BB shooting unit works with TK-6.0/7.0 without any electrical modification. Just connect the recoil motor to CN6. I have upgraded the Pershing with a TK-6.0S MB which works together very well.
If you have a very old Pershing like I do, the upgrade is not recommended because it requires too many try and fit steps. If you have a newer version of Pershing, the "metal barrel recoil BB shooting unit" kit should fit as is and is highly recommended. You can see that the upgraded tank has the longer, more correct barrel.
Working on another Pershing myself....I did a respray with Tamiya XF-62, going for early Korean war era. Normally I would cut off the fenders as I like the look a lot better, but this is going to be more of a "loaner" tank for my small tank club here in FL, so decided to keep things simple. Also blacked the metal tracks with Birchwood Casey "Brass Black" (my favorite method), followed by a rust wash and then sealed with dullcoat. I let the tracks wear naturally after that and I htink it gives a pretty realistic look without going overboard and it's a very easy process.
3 PhotosComment
A new Pershing project. The turret is 90 percent painted, next will be the hull. Painting straight lines on complex curved surfaces is taxing!
The side skirts are staying on this one (probably) because most of the images I used for resources have them. As far as the stripe pattern, since the real tanks were field painted, I feel free to make my own interpretation.
A side point though. Since this was intended to be primarily an art project, I bought the Heng Long version with plastic suspension, except for the sprocket and tracks. Mistake! There are no bearings or even bushings at all. I'll have to add them on at more expense than buying them as part of the kit if I intend to run this one at battles...which I will!
Edit: After looking at my photos, I decided the face needed to be more pronounced.
The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
a suggestion, get a cheapo laser level and stick it above your bench/workpiece and project the line on your tank where you want the paint line, should be a good guide regardless of the surface curvesComment
