Well, started on the proces of turning the Heng Long Sherman M4A3 105mm into... a Firefly? Actually, that is kinda fluid. Still waiting for some stuff to come in, and the plan might change. But there's a lot I can do before that anyway. Already gathered a lot of stuff that will let me start with some of the work -I- think needs doing.
What I've gathered thusfar in parts and stuff is;
Spare plastic hull (with the leds for the front and rear lights already installed)
Complete spare turret (V6.0 with all the electronics and BB stuff, alltho no 360 conversion)
Metal engine deck grill (Mato)
Metal horn and cover (Mato)
Metal .50cal for the turret (Mato)
Brass barrel and etch details for the .50cal (Aber)
Metal .30cal for the turret (Mato)
I've already made a cable from the battery compartment to the rear of the hull for a Voltage Alarm to keep an eye on the battery. Those voltage alarms are cheap (about a dollar) and they are great for the health of your LiIons.
Now, the "Plan" for now is;
All the stuff (sofar...)
Started with coding all the wires. Saves me a lot of hassle later. Back right the new wires I strung from the battery compartment for the Voltage Alarm. The new metal grills will let me switch it off when it goes off (and ya kinda need to... it's rrrreally annoying). You can also see the repair I had to do on the wires for the rear lights. They got pinched when the hull was closed up in the Heng Long factory, and the insulation was damaged. The copper itself was fine, so it was just a matter of popping the metal bits from the connector and sliding on some heatshrink.
Speaking of bare wires...
...not all that impressed with the soldering on the various LEDs. I think I will do a neater job on the spare hull. I've got plenty of wire and heatshrink and some Dupont connectors coming in. Already have a set of those little white connector (forgot the name) and the crimping tool to use them.
Meanwhile I am cooking up some ABS glue, slurry and putty with some Lego blocks and some MEK. MEK itself is fine for glueing ABS that makes good contact, but it is nice to have a thicker version. And the putty makes great stuff for adding weld lines and casting texture.
To Be Continued...
TTFN,
Rob
- Remove plastic engine grills from the top of the hull and replace with metal grills and hinges. This for easy access to the innards, like the smoker for refueling and the Voltage alarm for settings and turning it off.
- Remodel the spare turret to look like a Firefly turret. I know this involves another barrel as well, and I have ordered one from Toucan's store on AliExpress. They are shipping it along with the Panzer IV I may or may not have bought... The barrel I bought willl still let me shoot BBs.
- Ordering (or scratchbuilding) the british style commander's hatch. Loader's hatch is going to be scratchbuild.
- Remodel the (spare) hull to resemble a VC Firefly hull. This means a different type of driver hatch and eliminating the front .30cal. Which means I have a MG firing led going spare. Which I might move to the top .50cal. Because... why not?
- Remodeling the gear box covering to resemble an early type. Or buy the excellent resin one Forgebear sells. Not sure on that one yet. There's an awful lot of variants around anyway.
- Change IR stuff to LegoDEI's system. As soon as I figure out how to get the purchase not get killed by the new stupid tarif laws in the EU.
To Be Continued...
TTFN,
Rob
