Panzer IV Torro problem
tanks for us I'm glad my video was helpful to you.
For those asking about what's inside the Panzer IV, I don't have mine at the moment but here is a peak inside my M4. I hope it helps.
Camp my Instagram @Alpha.MakesComment
My Panzer IV arrived today. I found out that in order to open the upper hull, while pulling the switch at the bottom to the left, I lifted the upper hull up and to the right of the tank. It came right off. The two metal hooks inside are pointed to the right. If I slight the switch underneath the lower hull to the left, then I must pull the upper hull to the right, so there will more room to release the latches. Any body has his tank arrived with the winter track set installed? Mine came with winter tracks. Very cool!! ISoCal RC Tank Club Facebook Group
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
I bought the last one of the unpainted version from MotionRC as I wanted to paint it myself. Now that it comes with the wider version winter tracks, I need to do some researches in what other scheme I can paint it wiht. Do you like your winter Panzer IV. Can you post a picture of it? Thank you!SoCal RC Tank Club Facebook Group
I don't have a picture handy but this is exactly what I have https://www.taigentanks.com/collecti...-metal-edition
It runs well, and the Taigen version came with 390's, which I changed out to Tami 380's cause the 390's feel a bit much for a small tank with that factory gearbox.Comment
[QUOTE=sclui56;n319340]I don't have a picture handy but this is exactly what I have https://www.taigentanks.com/collecti...-metal-edition
It is the winter camo version,but it doesn't have the wider winter tracks like I have:
Nope. It didn't matter to me either way. I bought the previous tanks from Taigen/IMEX b/c they are the importer for NA, they also stock most of the parts when needed. They were also very quick in replacing failed parts, I had a dead speaker in the PZ4 and problematic MFU in a Leo 2. I only bought motors and batteries from Motion thus far, but may get the KT from them once I get over with the "bouncing" barrel.Comment
my PanzerIV did come with the wooden box. always thought it was a European thing since I never got 1 before from IMEX/TAIGEN/TORRO but Motion RC sent it. the European marketed tanks are set up differently with different charging etc.Comment
Those are for attaching a 6 channel receiver to the Torro controller so you can use a different transmitter for the tank.
The jumper is used to switch between the Torro system and the other TX/RX.
They kind of go over it in the manual, but not very well.
I might try it, but it will probably be a lot of trial and error since they don't mention what channel controls what function.
SteveComment
