Got it! but unfortunately I don't have any small 2 pin plug that would fit. I have to go get some.
Toro/Taigen switching transmitter
Thank you so so much! I didn't realize about that little plug. It was in a different box. My tank runs now with the Spectrum DX controlling it. I took out the smoker plug. You are the best
. I will order 9 more orange receivers for the rest of my Torro/Taigen tanks.
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
Glad you got it sorted out, driving experience should be smoother in acceleration/deceleration. Not to be off-topic, I still have to sort out a separate issue on a T-34 I just p/u, it somehow was fitted with a Tiger sound card instead of the JS-2, and I am still trying to figure out how to mod the smoker, hate these connections to the top deck.Comment
My channel 6 is the on/off switch. Channel 5 is the fire of the main gun. The other 4 are for the gun elevation, turret turning, and direction of tracks running. So I need to have all 6 channels plugged in. Hope you sort out the right sound for your T-34.SoCal RC Tank Club Facebook Group
Hope you got the module faster than I got the receivers. The 6 channel receivers finally arrived. I have replaced the use of my Toro/Taigen transmitters for just 1 DX9 spektrum
Any input on what to do with these transmitters?
Regarding the machine gun to function, what should I do?
Do you plan to attend the LA battle this Saturday?
DavidN A member over on RCU actually sent me 2 of the correct sound modules for free so I am kind of sorted in the T34 (had to beef-up the suspension as it's one of the least robust ones from Taigen). Glad you got all your Rx's in, using 1 single Tx certainly beats feeding all the OEM ones! I still have the same problem with the HL's using individual Tx's, haven't figured that out short of changing MFU's. BTW, just did the magnets on the KV-2 last night, not bad once you made the 1st cut. That's another thing I missed on HL's - quick release.
As for Taigen Tx's. I started storing them all in 1 box with unused accessories+manuals, may be someone will need replacement later? Still trying to find solution for MG's, the one company that sells on HK stopped supplying the ones for the tanks several months back, seems like they are focusing on higher profit ones for planes. It surprised me to no end that no one seems to know the hard-coded mix off CH 5 used by Taigen, even IMEX didn't appear to know. Can't really ask directly as Taigen/Torro does not have direct internet presence. Hopefully we can get the "mix" from Taigen at some point.
I may stop by later this Sat as I have to see our "friend" to p/u a Pather G. Too bad he only carries airsoft.....Comment
I am glad we have the same "friend". I picked up my Panther G from him a few months ago. It kinda "suck" that it was an airsoft :-( Hope to see you on Saturday.SoCal RC Tank Club Facebook Group
Sorry, I won't. None of my tanks is setup for battle. I will just enjoy observing the fleets. I will bring you some of the clear acrylic rods though, all you have to do is use a snipper to cut down to size..Comment
I would trash all those taigen transmitters. They aren’t good for anything.RC tank parts and accessories I make
www.RichardSJohnson.net/id28.htmlComment
I have a pair of 1:16 scale Taigen Tank T-34/85 metal track that I cannot use. https://www.taigentanks.com/collecti...5-metal-tracks
Make me a sincere offer, it is yours. Good for Taigen Tank T-34/85 only. It has 70 pieces of tracks, same as Heng Long, but is too short for the Heng Long tank.
I will also include 10 extra pieces of track link and the Mato sprockets and idler wheels, free.
I am in the process of converting a Heng Long T-34/85 to full metal. I foolishly assume that the Taigen is the same dimension and thus interchangeable. I was wrong. The Taigen track is too short for the Heng Long.
Before the track, I install the Heng Xin gearbox with 390 motor which works perfectly with the HL tracks. But the gearbox install takes some work. I use Taigen sprocket and idler wheel.
I did not run the T-34/85 enough to form an opinion on the Heng Long TK 7.0. On paper, it looks good with expanded functions.
I have TK 6.0S and 6.1 for a Pershing and a German Leopard, respectively. Both are huge improvement over the old TK 5.3. The improvement is important because I run fast (>22,000 rpm) motor with metal gearbox and tracks. The new throttle control is more linear.Comment
I made a mistake. The shorter Taigen and Torro metal track length are actually the correct one for heavier, metal chassis T-34/85 1:16 scale RC tank. See the real life tank, Heng Long and Torro tank pictures below. I will post my result when I finish my upgrade.I have a pair of 1:16 scale Taigen Tank T-34/85 metal track that I cannot use. https://www.taigentanks.com/collecti...5-metal-tracks
