That's looking real nice!
Heng Long M26 Pershing Build Log
Thanks Guys. Here is how I made the brackets Actually, the testors bottles are the way to go. Using just a pliers will make kinks in it.3 PhotosDon't just fly--WREAK HAVOC!!!Comment
My first attempt (s) at creating weld beads with Tayima Putty is going OK. This is really hard. Took me about five attempts to get the picture below. The Night Shift guy Kovac makes it look so easy. The putty sticks to everything except the tank when applying it. LOL I do recommend you use lots of water and to roll the bead and then cut off androll some more. It is easy to get too big a piece.
Weld seams or weld beads or just welds are one of the most important details on armor models. Because if you think about it, every tank is made from thick st...Don't just fly--WREAK HAVOC!!!Comment
2 PhotosDon't just fly--WREAK HAVOC!!!Comment
Are you going to be doing the tool box handles? Schumo makes a set for the Pershing, but it's been out of stock forever. Andy from Special Ops Models makes the same handles in resin, but sells them for the Abrams in a pack of 8. The Schumo set is a pack of 14. I asked Andy if he had any plans to sell a set of 14 for the Pershing as I'm also working on one and he said I could just buy two sets of 8 and have two left over. Wasn't exactly the response I wanted as that would be $28 for handles.
Funny that the handles have been the same since WW2. Makes me wonder if the NSN part number has been the same since WW2. The Abrams only needs 8 of them, the M41 Bulldog also uses 8 of them, and the Pershing needs 14.
https://www.ebay.com/itm/11368025917...sAAOSwxklchIlG
https://www.scalemates.com/kits/schumo-kits-ph0013-handle-set-storage-box-m-26-pershing--1028478
thanks tank me. I didn't even know the 3 d versions existed. I was going to wait and see if Schumo would ever come back. The 3 d seem even more fragile.Don't just fly--WREAK HAVOC!!!Comment
Couldn't take the lousy Harbor Freight Airbrush so I bought a decent one off E bay. What is difference. So much easier to use. Like butter compared to the siphon style I had before and clean up is a breeze. Mixed up a base coat of Olive Drab using Martin Kovac's formula and have to say it matches the Model Masters enamel. I needed Arcrylic for the base in order to chip it later/4 PhotosDon't just fly--WREAK HAVOC!!!Comment
I highly recommend the one I got. The little airflow control valve that comes with it is something that has me learning to change the pressure to change the pattern. Clean up is a snap. Not like the Harbor Freight one.G233 Pro Set Master Gravity Airbrush Kit 3 Fluid Tips, Hobby Auto Paint Nail Art 885458753407 | eBayProfessional Master Performance Multi-Purpose Model G233 Pro Set Master Airbrush. gravity fluid cup. Master Airbrush Model G233 Pro Set Airbrush with 3 Tip Sizes. Airbrush features a cutaway handle that allows you to grab the needle chucking nut to quickly flush and clean the needle passage ways.Don't just fly--WREAK HAVOC!!!Comment
Well, I put on the decals and then sprayed it with Tamiya x-24 satin clear varnish. I think I did a bad job in the Turret. I put the airbrush too close and puddled the satin in a few places. I also think the satin darkened most of my Olive Drab that I spent tons of time highlighting and airbrushing to look slightly weathered and am sort of disappinted in the results. I can always fix it and now the tank has a durable base coat so it isnt a total loss. If I were to do it again I would lighted the Olive Drab even more before vanishing. These tanks barely got into combat in April of 45 so the weathering isnt really an issue and in some way you could over weather a WWII Pershing. This particular tank is a blend of Fireball and Eagle 7 from the 3rd armor division. I will take her to LA Tanks to battle and then go back and maybe mud her up a little to hide some of the imperfections/mistakes I made. The new airbrush was a big help and I learned a lot from doing this Tank. I really need to get VMS Varnish that was highly recommended, but I couldnt find it. I think that would have helped. I would also modify the Tamiya blend of paints that I used as a base coat. I would add more buff color immediately and go lighter.2 PhotosDon't just fly--WREAK HAVOC!!!Comment
Tanks aren't perfect and once there is a coat of dust on it, it will lighten up. You can also take and put a very light coat of buff (and I mean VERY light) that can add a dusty effect to it. Personally I've taken a liking to the Alclad varnishes.Comment
The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
I quickly wiped it off. No harm seems to have happened except my barrel got paint on it. I can sand that off..
