MATO Tanks
  • Zippersnapper
    Insane Unknown
    • Mar 2021
    • 502
    • SW Texas
    Originally posted by sclui56
    Hi Zip, now that you have stripped the Mato down, what do you think? Any issue with the suspension and/or other concerns? I keep reading about issues on quality but still thinking about a Stug.
    I havnt driven it at all.....My work has me on the road allot lately. In all hoenesty, and as Rich has pointed out-Its not worth the money. If I could have put my hands on a Taigen Stug, I would have gone that route for sure. The suspension seems ok at first glance, but thats not saying allot with no road time. The + side, I did buy it $90 cheaper than asking price.
    • sclui56
      • Mar 2021
      • 415
      • LAX
      Got it, yes, just too much bad press on Mato. There's no Taigen Stug, I was even considering a Taigen upper alone but no dice, not even from outside the U.S. I may just build one up using HL upper and my Taigen PZ3 lower.
      Thanks & good luck.
      • Zippersnapper
        Insane Unknown
        • Mar 2021
        • 502
        • SW Texas
        Wise move. The MATO still sits on the bench, stripped. My tank room is in a total disaster, not having the time to get anything accomplished....maybe mid August.
        • 761st
          • May 2022
          • 392
          That bridge kicks a$$ !!!!
          • DavidN
            • May 2021
            • 3203
            • Los Angeles, CA
            I got home from work and jumped right into finishing my KT. I got the IR bulb inside the barrel. The IR receiver was slid up to the commander hatch. Re-tested it again and it is all ready to battle. It is supper heavy :-)
            • 761st
              • May 2022
              • 392
              Looks like a beast!!
              • DavidN
                • May 2021
                • 3203
                • Los Angeles, CA
                18 pounds without the battery :flushed:.
                • Zippersnapper
                  Insane Unknown
                  • Mar 2021
                  • 502
                  • SW Texas
                  Thats pretty Bad Ass. !
                  • sclui56
                    • Mar 2021
                    • 415
                    • LAX
                    David, looks good. Do the turret and barrel bounce like the Torro? Got to fix that on mine.
                    • 761st
                      • May 2022
                      • 392
                      How to you plan on fixing that?
                      • sclui56
                        • Mar 2021
                        • 415
                        • LAX
                        Not entirely sure, the turret itself is not difficult, the top deck is a bit thin for the gap between turret and ring, which can be shimmed. The barrel mount is another story and I have seen some very elaborate rebuild that I am incapable of replicating, so short answer - not sure ATM.
                        • DavidN
                          • May 2021
                          • 3203
                          • Los Angeles, CA
                          No it doesn’t. But it does jerk a lot when I fire. Maybe I should cut 1/3 off the spring inside the air-soft unit.
                          • 761st
                            • May 2022
                            • 392
                            I can't quite give an accurate description but, as I recall someone had placed counter weights along the plastic mechanism mounted to the barrel. I wish I had taken pictures. Seems if there is a fulcrum that may work.
                            • sclui56
                              • Mar 2021
                              • 415
                              • LAX
                              Not to be off-topic, but I think this is what you read https://www.rctankwarfare.co.uk/foru...+tiger#p314783
                              Well it was a while ago now that I got my first tank, a Torro Pro-Metal Edition King Tiger and I have been meaning to start this thread for a while but always s
                              • DavidN
                                • May 2021
                                • 3203
                                • Los Angeles, CA
                                I was able to use my Sony TV remote and follow the instruction from the Clark's board website. I fixed the reloading times to 9 seconds instead of 13. The hull jerks very slightly when the cannon fires. No need to cut the spring inside the air soft unit :-) The KT is good to play.
                                • 761st
                                  • May 2022
                                  • 392
                                  How do you shut-off track recoil?
                                  • Sureshot
                                    • 235
                                    From what I understand there is a tiny switch on the control board that controls the track recoil either on or off. I tried to see it on my Sturmtiger but think you have to remove the outer case to see it.
                                    Steve
                                    • DavidN
                                      • May 2021
                                      • 3203
                                      • Los Angeles, CA
                                      I bought the SONY remote control from DAKRC. I have the transmitter off. I plug in the jumper into port J2 (top and middle pins). I turn the board on. I press the "increase volume" (red circle) until the light on the IR LED only flashes 1x. It does go up to 16x. I then turn off the board and unplug the jumper. Done.
                                      • Zippersnapper
                                        Insane Unknown
                                        • Mar 2021
                                        • 502
                                        • SW Texas
                                        David, Im assuming your KT is a MATO? If so, will he metal hold a magnet? Or is it non ferrous like mine? 18lbs without a Batt has me curious.
                                        • 761st
                                          • May 2022
                                          • 392
                                          David, Correct me but, the tank has to have IR to use the remote? Also, is this a standard Sony remote? In other words is the same model remote compatible? Thanks.
