Been wanting an M60! glad to see this.
M60 Tanks coming soon. But not from Heng Long
Inkor just released his 3D printer STL files for a Churchill on Cults3D. DKLM RC also has one so if he's going to build it, he is going to have to price it and detail it well enough to sell.Comment
Review the coolbank models threadRC tank parts and accessories I make
www.RichardSJohnson.net/id28.htmlComment
pretty nice model didnt like that all the accessories had to be glued on but been wanting a M60 very happy with this tankComment
Yes but this was the first time everything had to be glued to keep them in place HL just needed to keep from losing them still I really like this tank recommend highlyComment
I have 2 HL from 2005 and 3 more in the last 2 years. Regular plastic cement does not work on HL. I use SA super glue only. That's the only way to avoid loosing small parts on a HL tank.
Rubber cement, RTV, and even ABS cement from plastruct work great for glueing the parts on tanks.
Personally, CA or super glue, is the worst glue to use as it’s brittle and has absolutely no sheer strength at all. I refer the plastruct glue myself because it melts the parts together like building a plastic model.
if you think you might want to make changes later, the rtv is a great product. It’s black gasket maker for automobiles.RC tank parts and accessories I make
That is what I use too. Plastruct plastiweld for any thing that is to be permanent and a synthetic rubber cement for things I may take apart later and dont want the plastic damaged.Rubber cement, RTV, and even ABS cement from plastruct work great for glueing the parts on tanks.
if you think you might want to make changes later, the rtv is a great product. It’s black gasket maker for automobiles.Comment
Plastruct Plastiweld in the white bottle is pretty good stuff. I also use Tamiya Thin and it works on some items. If nothing works then it goes to the Weld-On number 4 (MEK) and that also works on PETG for my 3D printed tanks. Just be really careful with MEK as it is very toxic stuff.
DerekComment
Here ya go just for you- https://youtu.be/blxDBwzbHk4
Ugly yes but that is subjective. Failure yes with a grade of "F"...
Only 13 miles ever run in that tank in that YouTube video - unbelievable. Another "Bradley".
Ugly yes but that is subjective. Failure yes with a grade of "F"...Comment
