Coolbank Models
  • quitcherbitchen
    • 928
    • Altadena, CA
    Originally posted by Zippersnapper
    I ordered the Pershing Metal Barrel with recoil-It just arrived, Its allot longer than the stock barrel, although the muzzle break appears to be the same.
    Toucan-China Fleabay
    Do you have any pictures of your purchase? Can you put a ruler next to it?
    • Zippersnapper
      Insane Unknown
      • Mar 2021
      • 502
      • SW Texas
ID:	361190 Tip of Muzzle break to entrance to mantlet:
      Stock: 6.5"
      Metal Recoil: 9.5"
      Its hard to tell from this angle, but yea, Its about 3" longer..
      Make that 10"....
      • Rubicon99
        • 3316
        Click image for larger version  Name:	20221113_121117.jpg Views:	7 Size:	157.9 KB ID:	361190 Tip of Muzzle break to entrance to mantlet:
        Stock: 6.5"
        Metal Recoil: 9.5"
        Make that 10"....
        Click image for larger version  Name:	20221113_123627.jpg Views:	0 Size:	127.7 KB ID:	361195
        Just for comparison the Tamiya M26 Pershing barrel is 8 1/8” in length from the mantle to the end of the muzzle brake.
        Click image for larger version  Name:	CF644D0A-4884-4A92-862E-2466100AA0A6.jpg Views:	0 Size:	175.6 KB ID:	361199
        • DavidN
          • May 2021
          • 3203
          • Los Angeles, CA
          Here are my Pershings. The Hs really need the long barrels to match with those Tamiyas.
          • DavidN
            • May 2021
            • 3203
            • Los Angeles, CA
            • Zippersnapper
              Insane Unknown
              • Mar 2021
              • 502
              • SW Texas
              My Pershing is the T26E4 "Super Pershing"
              • Rubicon99
                • 3316
                Was thinking that might be the direction you were going. 👍👍
                • SoCalBobS
                  • 2754
                  • Southern California
                  Saw an M60 update on Facebook. There's a video clip showing one running (can't copy it, unfortunately) on a slippery marble floor, but it's running. Anyway, DKLM RC chimed in there. He says he will be carrying the line when it is released. No date, though.
                  • tank_me
                    • Feb 2022
                    • 1197
                    Bob, do you remember which group on FB or profile it was on?
                    • SoCalBobS
                      • 2754
                      Coolbank Wang on FB.
                      • RichJohnson
                        • 1276
                        Where did you see it, I look at his page and see his latest post was nov 9th about fun driving rc toys and not a class status.
                        • Delta_19
                          • Apr 2021
                          • 170
                          Coolbank wangs profile post on October 26th
                          • SoCalBobS
                            • 2754
                            You have to follow the comment and reply trees a few levels down.
                            • tank_me
                              • Feb 2022
                              • 1197
                              The direct link Delta posted works. Thanks.
                              • SoCalBobS
                                • 2754
                                (I hate FB) To see DKLM RC's comments I noted earlier, go to his FB page and start with the M60 photo dated 10/26, and check the comments connected to it.
                                • Delta_19
                                  • Apr 2021
                                  • 170
                                  Some new posts from coolbank
                                  • SoCalBobS
                                    • 2754
                                    Here's a photo I pulled from the DKLM RC website. He states he'll be posting the tanks for sale on his site "soon".
                                    I'm guessing it's early pre-production.
                                    Four posts to connect top and bottom hull.
                                    Turret components appear similar to Heng Long - rotation motor, ring gear, airsoft gun.
                                    MFU looks similar; plug-in slots are in generally the same locations as HL.
                                    Smoker looks similar. Seems to be bolted on to a post.
                                    There is a unit near the top rear that looks like a combined on/off switch and balance tap charging port.
                                    Front hatch opens.
                                    Speaker is like HL's compact unit.
                                    There seem to be LED's in front, although earlier Wang said they were eliminating headlights for cost savings.
                                    There may be a tension adjuster on the idler.
                                    Looks like the road wheels are secured with bolts inside the hull.
                                    The biggest unknown is how or whether the MFU, speaker and battery are secured. Maybe a plate over the torque rods? If not, one will have to be added.
                                    Anything else you can see?
                                    • Delta_19
                                      • Apr 2021
                                      • 170
                                      Well that battery is concerning. No bms just balance right to battery. Atleast the it's balance charging and not the mains.
                                      • RichJohnson
                                        • 1276
                                        Once those tranys eat crap your on your own. They are mounted from the side and it does not appear HL units will fit in despite the claims Coolbank Wang alleged.
                                        • SoCalBobS
                                          • 2754
                                          Someone on DKLM RC's Facebook alleges he bought one from an importer in Germany. Here's his comment:
                                          "its garbage! Got it from one of the tank dealers in germany which imported a small number and regreted it. The electronics are bad. The plastic is to thin. The roadwheel arms will break easy. The gearbox is the only good thing."​
                                          My only caution is if he had unreasonable expectations, like a Tamiya product at Heng Long prices.
