Official Tongde US M60A3 1/16 Scale Battle Tank Discussion Thread
  • Rubicon99
    • 3324
    Originally posted by MaverickTank
    So, I had the track kink several times today, and I took a good look at it when it happened. It only happens to one track, and only when turning into the side that kinks. The track doesn't seem to be catching on the hull. Instead, it looks like it is wrapping around the sprocket and not letting go. Perhaps the track needs to be tightened? None of my 10 other tanks has done this.
    Yes that does happen where the track does not disengage the sprockets. Two things, one check your track retention it may need to be a notch tighter. The second is to increase the torque on the torsion bars for the last road wheel.
    • SoCalBobS
      • 2774
      • Southern California
      tdriver, have you tried the AK Easy Cast on any 3Dprinted surfaces? I'm thinking of having a Super Pershing turret made, and a "cast" texture would be preferable to the usual fine line surface.
      • tank_me
        • Feb 2022
        • 1211
        Since I have done a lot of texture over 3D printed parts, I can say that 3M Red or Bondo spot putty will stick just fine to the 3D printed parts. I apply it and once sanded down a little it gives you very nice texture to simulate casting. It can also be thinned with acetone and applied with a paintbrush to fill in layer lines. Acetone and wood filler also works for filling layer lines. With either method it may take multiple coats to acheive the desired affect.
        • MaverickTank
          • Nov 2023
          • 82
          Will do. Thank you!
          • tdriver113
            • Apr 2023
            • 111
            • Peoples Republik of Illinois
            I used it on a Sherman turret before. It's easy to work with. Have not tried anything 3D printed yet.
            • AFT-CAP21
              • Feb 2024
              • 22
              • Tennessee-North Carolina Border
              Has anybody Click image for larger version
Name:	M60A3 Left Rear Quarter.jpg
ID:	404462 else out there tried to do anything about those awful grille-doors that come on the TD M60s out of the box? I made some new ones on Tinkercad and 3D Printed them, but they're not quite a perfect fit. Was wondering if there's something better to be had out there?
              • Rubicon99
                • 3324
                Originally posted by AFT-CAP21
                Has anybody Click image for larger version  Name:	M60A3 Left Rear Quarter.jpg Views:	0 Size:	120.8 KB ID:	404462 else out there tried to do anything about those awful grille-doors that come on the TD M60s out of the box? I made some new ones on Tinkercad and 3D Printed them, but they're not quite a perfect fit. Was wondering if there's something better to be had out there?
                Yes DKLM RC has a detailing kit for the TD M60 which includes a completely new rear exhaust grill/panel. It's not listed on their web site as a stand alone detailing kit, you have to email them and ask for the kit separately.
                Shown below on my M60A2. The lower "box" on the grill panel is specifically an A2 part attached to the grill. The grill does not come with the A2 part attached.
                • AFT-CAP21
                  • Feb 2024
                  • 22
                  Thanks much, Rubicon99.
                  • MaverickTank
                    • Nov 2023
                    • 82
                    Love the tank model. The transmitter for mine is just awful though. I have had continuous connection issues at 20 feet. The diesel sound is awesome, and I will be sad to lose it when I switch to the Heng Long 7.0 receiver.
                    • MaverickTank
                      • Nov 2023
                      • 82
                      Well, the tank went from glitching at 20 feet to shutting down altogether. In case anyone else has an issue, here is what happened:
                      The transmitter inputs would be delayed by several seconds. Sometimes, the tank would receive a transmitter signal and continue the action for several seconds after input was halted. For instance, a nudge on the steering would cause the tank to spin, or a small turret turn would cause the turret to spin to its limit. This would happen at about 20' from the transmitter. If I walked toward the tank, the problems would subside.
                      Now, the tank shuts down at random intervals and all of the radio settings are reset. And no- not a battery issue.
                      I am going to replace the control module with a Heng Long 7.0 and use one of the many HL radios I have stashed.
                      • RichJohnson
                        • 1301
                        The TD radio systems while appear the same as HL are really just toys and not the same quality
                        • MaverickTank
                          • Nov 2023
                          • 82
                          Rich, I appreciate that you are going through the effort to supply tank parts to the community. Thanks!
                          • tdriver113
                            • Apr 2023
                            • 111
                            I had the same intermittent connection problem. I switched to a Heng Long 7.1 system with the Leopard 2A6 diesel sound and I think it's a good sound compromise. I also upgraded the speaker to an aftermarket one which made a big difference.
                            • MaverickTank
                              • Nov 2023
                              • 82
                              I installed plastic tracks on the M60, and so far I like them better than the metal tracks.
                              The tank itself is heavy enough to roll well on the suspension without the weight of the tracks. I expect my battery times to increase with removing all that weight.
                              The new tracks were so tight that they compressed the first and last road wheel, so I added a link to each side. The pins are easy to remove- so easy that I worry about them walking out. One of the pins on my metal tracks walked out.
                              Adding one link appeared to be the perfect tension, but I saw that the track was buckling in reverse turns and the idler wheel was not always turning; the track sliding across it. So, I popped the top off the tank and adjusted the tensioners two notches. The nut that Tongde used puts stress on a relatively small area of plastic, so I added a wide washer to each side. This will also keep the nut from cutting into the plastic. I can see how the hull would get damaged over time by the tensioner nut.
                              I was surprised by how bowed the hull top is! I had to put the front screws in first, then clamp down on the rear half to make sure the screw holes were aligned. There is no way I could use magnets.
                              So far, so good. I agree with the others on this thread that the plastic tracks + metal gearboxes are the way to go.
                              • samuellindsey
                                • Jun 2024
                                • 14
                                • Central Illinois
                                If you had a choice between an m-26 or m-60. Model which would you choose
                                • keilau
                                  • Mar 2021
                                  • 1849
                                  • Windy City
                                  The M26 Pershing, M48 Patton and M60 Patton are all post WW2 US Army MBT that share many design heritage. M60 is the most mature design and my favorite.
                                  At the 1/16 scale, I have a 2005 Heng Long Snow Leopard and a 2023 Tongde Patton. Both are very good running RC tanks.
                                  • samuellindsey
                                    • Jun 2024
                                    • 14
                                    • Central Illinois
                                    So between the hens long m26 professional or the tonged m-60 professional model which would be a better model
                                    • Rubicon99
                                      • 3324
                                      Both are relatively even with plus and minuses. The M60 "metal" edition has a better suspension (real torsion bars) and has full bearing through including the gearboxes. The M60 can be turned into a better model with more functionality (servo elevation and servo recoil) easier then the M26 Pershing.
                                      Both need aftermarket detailing and new paint to look decent.
                                      • samuellindsey
                                        • Jun 2024
                                        • 14
                                        • Central Illinois
                                        Thank you I was considering the m-26 but after seeing the m-60 something just grabbed my eye really thinking about picking one up
                                        • RichJohnson
                                          • 1301
                                          I just received my restock shipment of plastic tracks for the Tongde M60 series. Both types hexagon and Chevron pads. $45 a set.
