Originally posted by keilau
View Post
Challenging, Challenger for Keilau.
Not even the Tamiya tracks would be helpful being run as shown with all that "grass" gumming up the works. Wet "tall" grass or even wet "medium" grass is a track killer especially if one is doing a number of turns in it. It's almost as bad as mud.
Grass and mud are two thing I have learned to avoid if turns are going to be needed.
Originally posted by MrChef View PostExcellent post sharing your many trials and finally tribulations with your Challenging Challenger Mr, Rat.👍👍👍 I'm sure your information shared will be helpful to others and at the very least console others who may experience similar issues.
Originally posted by Meter Rat View Post
My tank has been built, modified, and adapted to cope with the terrain I have available. And to look good on the shelf. This tank runs very well, even with the drive sprockets and road wheels clogged up as shown. Even with the grass cut short in the garden, it drags grass up, when running straight. This seems a problem with all rear drive tanks, but does not affect my two front drive Tigers. I now run standard course, which is approximately 1km. This has a mixture of terrain from long grass, short grass, mud, water, stones, and woodland. I am happy when they are able to run this without de-tracking. I realise there are many solutions to problems, and this was mine, working alone and isolated, without access to assistance or support from a club, or group, or either a decent model shop. If you do not believe how well it runs, I will try to get a video of it on the course I use.
By all means post a video here or Instagram or YouTube it's alway nice to have live action content of ones tanks. I post mine on Instagram at Fsttanks and on YouTube as Fsttanks1 (although that channel is fairly new so not much there fight now).
How about a modified toothbrush/brass brush just over top of tread, angled as to push grass off tread. I’ve been considering some sort of tread cleaner at the top rear of my Abrams sprocket. I’ll experiment and report back👍🏻 something like this but refined
I plan on running into/over/through whatever gets in front of my tank 👍🏻🏴☠️👍🏻 scale of course 😂
Originally posted by Handy Lance View PostHow about a modified toothbrush/brass brush just over top of tread, angled as to push grass off tread. I’ve been considering some sort of tread cleaner at the top rear of my Abrams sprocket. I’ll experiment and report back👍🏻 something like this but refined
I could tell you what exactly is going to happen with your idea of using a brush, but half the fun of this hobby for many of us is experimenting with ideas. So have at it and you will learn first hand to what degree it will work or does not work.
Originally posted by tank_me View PostYou are a glutton for punishment aren't ya? The Challenger is another tank that is not great with track retention. It seems those are your favorite tanks...
I’m not sure how to gauge this response, so I will assume nothing.
thanks for your input
Guys/girls/none gender specific. Please don’t fall out, or get arsey with each other. This is exactly why I like this hobby. Experimental engineering. Handy Lance, please give it ago and show us your results. Good or bad. A lot of tanks in WW2 had equipment to remove excess build ups around the tracks.
so you have seen it? You know what will happen?
The problems associated with sprockets and "debris" sucked up by the tracks (grass, sand, mud, dirt, snow and such) is on the inside side between the sprockets and tracks not the outside. Brushes add complexity to an already complex system of moving parts in an area that is not the typically the problem.
I still say experimenting is half the fun and learning the information first hand is far more valuable then just reading about it. Honestly there is very little that has not been tried by the RC tank community. Some of it works well and has become common to see as modifications, other stuff is hit or miss. Then there is the stuff that well was fun trying but ultimately did not improve anything and sometimes made the things worse.
Originally posted by keilau View PostI do not have the extensive experience of yours. I learnt the importance of using the correct sprocket with the track. By that I mean that the length of each individual track link must match the spacing of the sprocket tooth. Yes, I agree that even a perfectly matched sprocket/track pair still pulls grass and trap dirt, but they are much less likely to throw track. Looking at Meter Rat picture, it seems that the grass dirt may be pushing the track away from the sprocket to cause the mismatch and eventual detracking. I have not seen this before since there are lots of room between the sprocket middle and the track surface. I never run my tanks in mud, but did in backyard lawn.
Removing the inside ring will greatly reduces the packing issues and is highly effective for sand, mud dirt or other loose free flowing debris. With wet grass it will still pack the sprocket but it will take longer to do so.
This is a standard modification many of us have been doing for years. Not something we discovered, but something borrowed for real tanks. Seem some real tanks like the T72/90 for example have the same issues.
Inside ring removed. Shown here on one of my M60.
Originally posted by cmdrcody View PostI see you've also drilled holes in the drive sprocket. More debris relief ??
Managed to put the Challenger on my garden test route, with out the track guide. Far less build up of grass on the drive sprockets, and no de-tracking issues. Plenty of debris trapped around the transmission. All trapped in by the side skirts.
Debris in the sprockets.
Took out one of my Tigers, on the same route. And in the same conditions. This is the advantage of a constant route. It can be used to evaluate any model in different weathers. No build up of debris around the Tigers running gear..
- Likes 2
To keep this on track. (Or being a Challenger, probably detracked). And so as not to hijack another’s post. I have posted it back in this thread. I have ordered a pair of 3S batteries. £19.95 for one, £22.95 for two, with free delivery Go figure? So not the best quality then from Amazon. But I’m not paying £22 delivery on a good quality battery that was £30 despite the price including free delivery to the main land. Ah! But you come under Highlands and Islands sir. We are an hour outside of Glasgow, so hardly remote. I have also taken into account that as these are probably not the best quality, I will ensure they are in charging bags, only charged when I am present, on a suitable charger, and charged at low current.
Anyway, this will be a little experiment to find the speed differences between, batteries, 2S, high speed, 3S low speed, and 3S high speed, using the setting on the controller.
Given the warnings of others, and the work I put into it, I feel confident, that if driven sensibly, and not driven flat out over unstable terrain it will survive, the odd high speed dash in a straight line.
Mr Chef wrote.
Ohhhh you go with your bad self Mr. Rat! I totally look forward to your experiment, hopefully cool pics and vids and of course the obligatory results/repair posts...😉
I’m sure there may be some.
Originally posted by Meter Rat View PostTo keep this on track. (Or being a Challenger, probably detracked). And so as not to hijack another’s post. I have posted it back in this thread. I have ordered a pair of 3S batteries. £19.95 for one, £22.95 for two, with free delivery Go figure? So not the best quality then from Amazon. But I’m not paying £22 delivery on a good quality battery that was £30 despite the price including free delivery to the main land. Ah! But you come under Highlands and Islands sir. We are an hour outside of Glasgow, so hardly remote. I have also taken into account that as these are probably not the best quality, I will ensure they are in charging bags, only charged when I am present, on a suitable charger, and charged at low current.
Mr Chef wrote.
I’ll do it once my correct 7.1 gets here and start a new thread 👍🏻
rules
1. Mark off 10m (dry asphalt,tarmac probably best world wide similarity?)
2. rolling start wherever before start line, as full throttle as you are comfortable run the 10m twice
3. Have a buddy keep time
4. Report back times with
chassis weight
tranny used
Battery used
film it (if possible)like I said I’ll go first next week if people are game?
I definitely think we should do a 10m speed comparison (not competition) it would be interesting to see all the different tank setups times 👍🏻
rules
chassis weight
tranny used
Battery used
