Alpha, on my 500 Apache, I just opted to put it on a slider. I treat it almost as if it's a retract switch. If I'm hovering, it's down and in fwd flight I put it up. I thought about mixes, and honestly the interaction is just a bit too complex to program at this scale with a lot of work.
A collective is a good starting point, but it really needs airspeed as well. Otherwise, you might have the H stab come down at high speed or in a fwd flight climb where the same collective (or more) than hover is required. And although airspeed systems are available for RC, calibration of a helicopter airspeed system is a MAJOR headache. Even on the full scale, it's very easy to end up with bad data.
