New to the forum with a UH1-D 800 series
Personally, I’d try a set of tests slowly removing components from the mechanics. First try removing the blades and running it up. If it’s still present, you can eliminate the blades as a possibility. Next, remove the head and run it up. If vibrations are still present, you can eliminate the heads as a cause. That should help narrow down the options.
Beautiful Vario choppers by the way, that’s some excellent craftsmanship!Comment
Hello F106DeltaDart
That's exactly what I did.
Balanced blades
Verified Center of Gravity: Vibrations still present blades removed.
Head removed: dittoComment
Yes PawPAw
The Jeti Box allows you to read the parameters in clear:
- Rotor/motor ratio 1:13.8
- Rotor rpm mini/max: 1160/1240rpm
- Number of poles: 10 for the Hacker engineComment
Ok, I have no experience with Jeti…only Castle Creations, Hobbywing, and now Scorpion Tribunus which all require poles/2. I do know that setting up the wrong number in that category will induce heavy vibrations as I have experienced on one occasion.Comment
I see that. I also see 14 poles listed for another A50-12L V4. My suggestion would be to count the poles in your motor to be certain, due to the very strong possibility your vibration issue is due to an incorrect ESC pole number entry. I got that number wrong on a 600 heli build several years ago and the vibrations were dramatic.Comment
On my 212 600, with the same tail drive (slightly smaller)
The drive shafts to the tail rotor I have both aligned in a lathe and both were not perfectly straight
I also placed a ball bearing on the short shaft and 2 bearings on the long shaft. I also secured the bearings of the 45 degree teeth on the gears, tail had no vibrations on 1st flight. See video made in my backyard , tail doesnt shake at all
