Official 3DP Thread
    Originally posted by Dustman
    So I need to go back to post #761 and recopy that file? All of the files up to post #745 I just sent off to get made a couple of days ago. I should be getting them back in about a week or so.
    DM, No, the only files that were changed were in Set 10a. I inadvertently placed the Shortened RH/LH Console IPs in to the file that should include the Forward Canopy Frame/Bow. If you're referring to the Modified Tub and the Shortened RH/LH Console IPs to send to your 3D Printer guy/gal, either Tub works fine and If you Contact your 3D Printer provider, they can download the newer parts from the forum. Just open the page where the files are and send them the URL of that page, so they can download the files. The newest files are 10a, 10b, and 10c, otherwise nothing else has changed, just a different version of the Tub and shortened IP Panels to fit that design and One (1) new part, the Forward Canopy Bow by Radar-Guy and myself. All is good, Sir. There will probably be some exterior parts coming, we'll see how that goes. Best, LB
  • Dustman
    You mean post #756 and recopy that file? All of the files up to post #745 I just sent off to get made a couple of days ago. I should be getting them back in about a week or so.
    Originally posted by Radar-Guy
    Thanks, you may get those in #752
    Dustman and Radar-Guy , My mistake :rolling_eyes: on the contents of the Forward Canopy Bow STL File. I have corrected the 10a Zip File in the original post #761, which now includes the right parts. Sorry. Best, LB
  • Radar-Guy
    RG I would like a copy of your canopy bow design to. You can never have too many parts........
  • Dustman
  • Dustman
    I have just commissioned Dirty Dee from RC Groups to do all the previous parts listed. I guess I will have to go back to him and get these done; no biggie........ I can't wait to get my hands on them! My thanks to you to LE.
    Ooh, just in time! I'll print these tonight. Thanks, Elbee!
    F-18C Hornet Owners' Society, This set, Set 10c contains the LH/RH Console IPs that have been shortened in length to fit the "Tub v2". Confused? Well I am. Anyway, trust me if you print Tub v2 you'll want these or you'll be cutting the others, which is fine. Send some pictures of your prints and builds. Best, LB
    [ATTACH]n219259[/ATTACH]
Name:	LH RH Shortened Console IPs.JPG
    Hello Some-more Hornet Owners, This is Set 10b (See 10a in previous post) for the Freewing F-18C and contains the "Modified Tub", If you've already printed the v1, no sweat, as this part only adds a deck behind the Ejection Seat and lowers the center supports for the Front IPwhich adds some forward space in the OEM battery compartment (Note: The v1 does not require different batteries, there is room there) and slightly lowers the center support for the Front IP and Lower Center IP as these are 2 parts. IF needed you can easily 'clip' these your self as the tolerance is close. I will also post the shortened, LH RH Console IPs as two additional files as these are large and cannot be sent in one single file. Any questions/comments, please post those here. Best, LB
    Zip Freewing F-18C 11th Scale Cockpit STL Files Set 10b.zip
    Click image for larger version  Name:	F18 Tub Enhanced Capture.JPG Views:	0 Size:	117.5 KB ID:	219257
    Please Note: 15/11 1600 CST. The STL File for the Canopy Bow is being modded for a better fit to the foam. See Post #773. Back ASAP. Best, LB
    Please Note: These STL FIles "Set 10a" have been corrected as of 14/11 12 00 CST to include the parts shown. Best, LB
    Okie Dokie, Gents & Gentlewomen, These are some more Freewing F-18C Cockpit STL Files, read Set 10a, see 10b in the next post, the parts are the Forward Canopy Frame which turned out to be quite a collaborative effort between Radar-Guy and myself. I would like to see more of this in the 3DP Community. RG shared a file with me and I twisted it a bit, he approved it, and "Viola" we all benefit. The part can be built either as a whole or in separate pieces, nifty, huh! Enjoy. Best, LB
    Click image for larger version  Name:	Set 10s.JPG Views:	27 Size:	104.1 KB ID:	219252
    QUOTE=Elbee;n218924]
    Frank, You are a gentleman. I thank you, Sir. Best, Steve
    It's my pleasure, Steve. Here is another file you may want to look at. It replaces the stock coaming and accepts 'my' HUD. I'd like to check how your HUD fits into it, but my printer is currently u/s. Perhaps you could check and I will adjust the "HUD tray" accordingly.[/ATTACH][/QUOTE]
    Frank, Unreal gorgeous. Great minds think alike is all I can say. I'm just finishing a partial shroud replacement to fit my HUD base. Yep, I'll give it try. Also, I am working an enhanced version of the "Tub" that takes up more space in the Cockpit and less space in the Battery area. A bit closer to scale-look as a benefit. Just hadn't looked at that CAD file for awhile. Post something when I can. Best, LB
Name:	F18 Shroud Capture.JPG
ID:	218961Click image for larger version
  • Radar-Guy
    Frank, You are a gentleman. I thank you, Sir. Best, Steve[/QUOTE]
    Click image for larger version  Name:	coaming.jpg Views:	0 Size:	58.8 KB ID:	218932
    Here are the files for the canopy bow plus mirror (print 3) and handles (print 2).
  • Radar-Guy
    Originally posted by Elbee
    RG, Radar-Guy, Yeppers, I am very interested! I started designing one on Saturday, and frankly so far, yours looks better. LOL. Would like to print your design. Best, LB
    Freewing F/a 18C Owners' Society et al, This is the last set of STL Files (#8) for the LB Cockpit Set. These are small parts for the Non-Ejection Seat; parachute straps, Cylinder for the Frame, Filler Panel for the Front Frame between the seat and headrest. All are mostly 'window dressing' but fun nonetheless, I think. Note: "X-ed Out" part is not required and there is not an STL File for it. Very much looking forward to seeing some of your prints and reading some critiques/comments, either good or bad. Happy Printing, Lads & Lassies. Best, LB
    [ATTACH]n218907[/ATTACH]
Name:	Small Parts LB Cockpit Set.JPG
    Hornet Owners' Society, This STL File attachment is a few small bits and the "Pit Mesh" which I had forgotten to include in an earlier file. I had printed the Joystick vertically with "Support Everywhere" BUT it's a pain to clean without breaking. So, iffin' I was y'all, I print it in another plane. Let us all know. The pic are the parts in Set 7. The list is all that I have built thus far and will post the remaining parts once I get the Throttle Handle to print without looking like a blob of filament. LOL. Best, LB
    Zip Freewing F-18C 11th Scale Cockpit STL Files Set 7.zip
    Click image for larger version  Name:	Zip 7.JPG Views:	0 Size:	162.1 KB ID:	218894 Click image for larger version
Name:	F-18 STL File List.JPG
    LB, great work. I'm still working on mine. If anyone is interested I will share my canopy bow design. It shouldn't be a big deal to add it to your cockpit.Frank
  • Radar-Guy
    Frank
    Originally posted by PeterVHS
    Great work there Elbee !! Well thought out break downs and printing manners so they can be done viably and well.
    I think the set of items you have posted are missing the rear cockpit 'mesh' section? It is in your pic just above, but not in the STL of the file set. Maybe taken out to be a separate part later? Or there is a new 'complete' Canopy Rails part to come still ?
    Painting the myriad of details will be a big task on its own! LOL
    Thanks for sharing that hard work/time you have made!
    PVHS, I'll run a complete check of parts comparison tomorrow. As you might guess, when designing and test printing one gathers many files. I've written a parts list, but not compared that to STL files I have posted. I have another set to post, as well. Thanks for heads up and of course the 'devil is in those details'. Looking forward to seeing painted cockpits, as I have yet to start my own work. Best, LB
  • PeterVHS
