What did you fly today?
    • 2715
    Thanx guys good honest fun(something missing these days)
    I'll even settle for a little good DisHonest fun! :smiling_imp:
      • Nov 2013
      • 2783
      • Cody, WY
      After a week's hiatus from flying due to cold weather, snow, and winds, this morning was prerfect, (for up here. ) Temp was about 28 degrees, calm winds, beautiful sunny morning with no clouds. The blanket of snow at the field, about 1-2 inches deept was perfect for flying from with my Timber on floats, which excels at this type of flying. Just a true joy and relaxing to fly under these conditions. I had it hung up in my garage for a year, but I'm going to keep it downstairs, ready for the next snow to come down to get some more fliying in.
      Cheers
      Davegee
ID:	417544 Click image for larger version
      • f4u ausie
        • 1241
        • Melbourne
        Looks fun dave
        • jetfool
          • Nov 2022
          • 1360
          • Crawfordsville, Indiana
          Davegee,
          Snow and floats make great winter flying. Couple club members flew yesterday after our 3" snowfall. lots of fun.
          Your plane and floats look great, but look at that great view you get to fly in. Beautiful
          Best Regards, Rex
          P.S. Is that Indian smoke signals asking for warmer weather or just clouds.
            • Nov 2013
            • 2783
            • Cody, WY
            Either that, or grizzly bears that live up there! Summit height around 9000 feet MSL.
            • JohnVH
              • Nov 2017
              • 259
              • Lynden, WA
              My son and I having fun with my new MD500! His very first heli flight!
              https://www.youtube.com/watch?v=c0d0oka8paA
              • kamillenielsen
                • Nov 2023
                • 4
                First flight of the new year on the Dynam 1300mm F4U Corsair.
Name:	Dynam F4U Corsair V2.png
                • f4u ausie
                  • 1241
                  • Melbourne
                  I'm sure it's 1270 mm.. anyway great learning warbird. Have fun. Mine had 650 kV 4 s well Fast Enuff looks great
                    • 2715
                    Got out the other day with some aircraft that can handle higher winds, our norm for "winter". Winds were 15-20, gusts to 25mph but directly down the runway. All 4 of these have the RX upgraded to Plus, and with those winds, all were rock solid, quick take offs, and perfect landings, at least for me. In fact with plus and higher winds, it was easier to land than dead calm winds.
                    On the SU-27, I used 2 of the new V2 SMC 6S HiV 4900's for the first time and got 7 minutes of fairly aggressive flying, wwoo who! Mig is on 2 SMC HiV 5900's for over 5 minutes, next time I'm trying 2 SMC HiV 6700's. The Corsair gets over 10 minutes.on the 5900 and the F4 is on an 8S SMC HiV 5900 for 6 minutes. Life is Goooood (as long as I can fly)
ID:	421346 Click image for larger version
                    • jasmith41
                      EDF-obsessed
                      • Sep 2021
                      • 317
                      • AZ and NE Ohio
                      Lately, it's been more accurately what did i crash today....
                      This goes out to whomever would like to render an opinion. All will be appreciated.
                      I am flying with Spektrum ix20 (5 years old) and using Spektrum smart receivers in all my planes and i use SMC HV Lipos in everything. Recently, I've had a few losses of beloved aircraft. I'll be flying along as normal and i just lose the connection with the plane - it's like the plane went dead - no throttle, no control surfaces, nothing. A couple of times it happened under load taking off (i'm usually the wide open throttle type of guy...). Everything just seems to go dead.
                      In one of the cases, i suspect the battery was the culprit, as it was older and questionable so it may not have been able to handle the load of take-off throttle and the ESC just shut everything off...???
                      In the other two cases, both batteries were only a few months old, so I don't think they're to blame, but again, I do not know what's going on here...
                      Anyone care to take a stab at it, please advise... and thank you in advance...
                      j.
                      • f4u ausie
                        • 1241
                        • Melbourne
                        Can't hurt to git the ix20 serviced.... see if they come up with anything if they all have many flights
                        Transmitter is the common denominator.
                        Sorry for ya losse
                          • 2715
                          j.
                          I use an IX14 upgraded to 20 channels and all my RX's are the Ar637T-8-or 10 channel upgraded to Plus and all with SMC HiV packs.
                          With those RX"s telemetry is included giving you constant info on in flight pack voltage, allowing you to absolutely know in flight when to land. So I recommend that highly. But doubt your issue is with the packs.
                          Secondly, in all my EDF's, I also install a satellite RX with 2 more antennas about 6-12 inches from the main RX, giving me 4 antenna oriented in 4 different planes. After landing, check in your TX (one of the info screens you scroll to off main) the signal history for frame losses and holds. Frame losses of 50 or less OK, any holds of 1 or more, very bad. The satellites help tremendously and I always have frame losses of 0 to 5 and 0 holds, quite excellent. Older Spektrum RX"s without satellites gave me occasional black outs. The new RX's with twin antennae and AS3X, along with satellites have cured that as their reception and signal is much stronger than the previous ones. Keep the active end of the ntennas away, if possible, from any carbon fiber and especially away from the battery.
                          Reception of the antenna active end is like a doughnut around it, with a dead zone directly in front and behind, so orient the other antennas to cover that.
                          So I believe your problem is with the RX signal, one I battled with extensively in the past, but cured with these new RX's and satellites and antenna placement, not the packs or your TX. Of course installing the in flight battery voltage call outs with the T RX's is IMO a must so you don't have to rely on your timer alone and how you handled throttle management from one flight to the next.
                          Hope this helps in some small way.
                          • jasmith41
                            EDF-obsessed
                            • Sep 2021
                            • 317
                            • AZ and NE Ohio
                            thanks guys - i appreciate it. i do use one satellite rx in every plane usually. in these 3 dumps, all of them had satellites... and i have custom reports set up for flt pack voltage call out as well...
                            i'm suspecting the tx at this point. i'm going to send it in i guess. no faith at this point though...
                            • Lon
                              • Jul 2014
                              • 1202
                              • Miles, Iowa
                              My first flights with the FW 90mm V2 was in Florida this year. A livery change to the Iowa ARNG 132 FW.
Name:	DSC02784 (1024x681).jpg
                              Lon
                                • 4868
                                Beautiful work, Lon.
                                Best, LB
                                  • 7415
                                  Hi Lon!
                                  Looks great my friend!
                                  (Dangerous Dan)
                                  • f4u ausie
                                    • 1241
                                    • Melbourne
                                    ​ ​ Hi to all. Flew my 90 Avanti and 1400 Pitts this morning. Sunday.. 20 C. Around 70 f clear sky and no wind... was fun... More importantly. I'me finally a club member(have moved house 20 minutes). So meeting some new and like minded people...seems to b a balance between foamies large scale and jets...(Will get my teeth into some new stuff). Here's a pic of this absolutely beautiful cub 40 percent 120 cc gass.er.. new exciting stuff coming for me... Only one dilemma $$$$
                                    • f4u ausie
                                      • 1241
                                      • Melbourne
                                      Lb. Don't mind squashing a 3d printed part.. at least U can post just 1 pic.. unlike the dumb Aussie
                                        Elbee commented
                                        Editing a comment
                                        You're the best Aussie I know.
                                      • 2715
                                      Got out yesterday for some EDF highjincks. All have the upgraded Plus RX's and are flown on SMC HiV packs. F4, 8S 5:45 on 8S 5900. F18, 6:00 on 6S 5900. SU-27 7:00 on 2 6S 4900. Mig 5:40 on 2 6S 6700 or 5900. How sweet it is!
                                      Click image for larger version  Name:	20250401_145802.jpg Views:	0 Size:	244.6 KB ID:	423038 Click image for larger version  Name:	20250401_145831.jpg Views:	0 Size:	241.0 KB ID:	423037
                                        • 4868
                                        Hugh Wiedman
                                        Beautiful stable, Sir.
                                        Unbelievable flight times.
                                        You are "The Man".
                                        Best, LB
