New project... Boredom is a curse... Lol
  • fhhuber
    • Aug 2015
    • 1476
    Aircraft Spruce is cheaper than hobby shops (per sq inch) but then you have shipping. I order enough to make it worthwhile. Plus I need the 2 ft X 4 ft sheets while the hobby shop only goes as large as 1 ft X 4 ft (and usually only stocks 1 ft by 1 ft or smaller)
      Yeah that's true. My priorities at this point are to get everything sanded and get the ribs glued in place. Then work on servo pockets, retract pockets, and motor mounts
        The ribs are in, I'm gonna do sanding a little later, just started feeling crappy so I'm done for the day
          Aaand still haven't done anything. It's hard to get going on it with some life stuff getting in the way.
          • doctormike
            HobbySquawk Moderator
            • Oct 2013
            • 1260
            • Santa Fe NM
            I maidened my wing that I made from Dollar Tree foam board, the fold over method, today. I figured out how to use this method and taper the wings. I used the guts from a RocHobby Swift. I can't believe the thing actually flew, much less, straight as an arrow. It really moves along or glides forever. It's about a 40"w.s. I used a c.f. arrow shaft for the spar. The ailerons are full length and I lifted up the outer 3" about 1/16" to counter tip stalling. This apparently works as well as washout, which is difficult to do. I also put vortex generators on the outer 4" It never tried to tip stall. Now that I've had a successful prototype, I'm going to start on a Horton 229. Dang!...This is FUN!!! Doc
            • Ole-Timer
              Warbird Enthusiast
              • Dec 2017
              • 344
              • New Brighton, PA
              It’s shocking how well cheap foam flies with some careful construction.
              Well done! :Cool:
              • doctormike
                • Oct 2013
                • 1260
                • Santa Fe NM
                Thanks, Doc
                  Absolutely my first success was my P39. So I'm hoping for success with this project finally
                  • mr.frankenjet
                    Eat, sleep, FLY FLY FLY !
                    • 448
                    • Virginia, USA
                    sweet,well done. Horton 229 SO on the list :Cool:
                    rc flyin addict
